pi4j and $CLASSPATH
Posted: Mon Nov 19, 2012 12:01 pm
by Squidward
Hi ,
Bit of a noob to java. What is the correct way to compile and run a program using pi4j ? What am I doing wrong in the following example ? Many thanks.
[email protected]:~/java$ ls
pi4j-core-0.0.3-SNAPSHOT.jar  Test.java
[email protected]:~/java$ cat Test.java
import com.pi4j.io.gpio.*;
public class Test
    Test () {
    GpioController gpio = GpioFactory.getInstance();
    public static void main ( String [] args ) {
    Test t = new Test ();
[email protected]:~/java$ javac Test.java
Test.java:2: error: package com.pi4j.io.gpio does not exist
Test.java:7: error: cannot find symbol
  symbol:   class GpioController
  symbol:   variable GpioFactory
3 errors
[email protected]:~/java$ javac -cp ./pi4j-core-0.0.3-SNAPSHOT.jar  Test.java
[email protected]:~/java$ java Test
Exception in thread "main" java.lang.NoClassDefFoundError: com/pi4j/io/gpio/GpioFactory
	  at Test.<init>(Test.java:7)
	  at Test.main(Test.java:11)
Caused by: java.lang.ClassNotFoundException: com.pi4j.io.gpio.GpioFactory
       at java.net.URLClassLoader$1.run(URLClassLoader.java:366)
       at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
       at java.security.AccessController.doPrivileged(Native Method)
       at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
       at java.lang.ClassLoader.loadClass(ClassLoader.java:423)
       at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:308)
       at java.lang.ClassLoader.loadClass(ClassLoader.java:356)
       ... 2 more
[email protected]:~/java$ java -cp ./pi4j-core-0.0.3-SNAPSHOT.jar Test
Error: Could not find or load main class Test
Re: pi4j and $CLASSPATH
Posted: Mon Nov 19, 2012 1:26 pm
by xranby
To run it, remember to add the current directory to the classpath where you keep the Test.class, first add a : to indicate that you want to add one more path and then a . that equals the current directory!
java -cp ./pi4j-core-0.0.3-SNAPSHOT.jar:.  Test
Posted: Mon Nov 19, 2012 4:22 pm
by Squidward
Excellent !
Thanks.
Posted: Thu Nov 22, 2012 2:53 am
by savageautomate
Also make sure to use the "sudo" command in front of the "java" command to start your java program with super user rights. Pi4J will need root permissions to performs some of its tasks.
Here is a complete example including the command lines to compile and execute the example code.
http://pi4j.com/example/control.html
Thanks, Robert
Posted: Tue Sep 03, 2019 12:17 pm
by angelomastro
Hi guys, this is happening to me too. but I think I am doing the right thing you said.
Test.java:
import com.pi4j.wiringpi;
public class Test {
   public static void main(String[] args) throws InterruptedException {
      if (Gpio.wiringPiSetup() == -1) {
          System.out.println(" ==>> GPIO SETUP FAILED");
          throw new Exception("Gpio.wiringPiSetup() failed");
       System.out.println("    > init pints in BOARD mode");
       wiringpi.Gpio.piBoardRev();
       wiringpi.Gpio.pinMode(7, wiringpi.Gpio.OUTPUT);
       wiringpi.Gpio.pinMode(11, wiringpi.Gpio.OUTPUT);
       wiringpi.Gpio.pinMode(13, wiringpi.Gpio.OUTPUT);
       wiringpi.Gpio.pinMode(15, wiringpi.Gpio.OUTPUT);
       System.out.println("    > move forward");
       wiringpi.Gpio.digitalWrite(7, wiringpi.Gpio.LOW);
       wiringpi.Gpio.digitalWrite(11, wiringpi.Gpio.HIGH);
       wiringpi.Gpio.digitalWrite(13, wiringpi.Gpio.LOW);
       wiringpi.Gpio.digitalWrite(15, wiringpi.Gpio.HIGH);
        // etc etc ... other operations
Then I compile with :
javac -cp classes:libs/* -d classes /path/to/Testjava
where "classes" contains the classpath and output class path (always works in other projects), and libs contains the jar file to use, for intsance pi4j-core.jar. Note: the * character is not an issue, I can point -cp directly to the jar and the same thing happens.
And in return I get
/path/to/Test.java:xx: error: package com.pi4j does not exist
/path/to/Test.java:xx: error: package wiringpi does not exist
    if (wiringpi.Gpio.wiringPiSetup() == -1) {
// ... etc etc for all commands
