Running Flutter, Google’s Portable UI Toolkit, on a rpi
Posted: Tue Jan 22, 2019 8:18 am
by seb42
Haven't had a play with Flutter yet on my rpi, might get a screen this week and give it a go.
Flutter currently only has official support only for andorid and ios devices, it has also been used for UI stuff on Google's new OS, Fuchsia. So am interested to see where they go with Flutter this year.
Here is article about getting a flutter app running on the pi.
https://medium.com/flutter-io/flutter-o ... 24c5e7dcb1
IF you aren't across Flutter, here is a 11 minute recap of the Flutter live 1.0 event from December 2018.
https://youtu.be/D-o4BqJxmJE
Re: Running Flutter, Google’s Portable UI Toolkit, on a rpi
Posted: Wed Mar 20, 2019 2:47 pm
by Robbiedobbie
Did you happen to try this?
I'm currently trying to write an app for the raspi in flutter. I managed to get it up and running, however display elements keep disappearing at random. To me it looks like the gpu can't handle the amount of textures (Running on raspi3, with a 50/50 memory split, so it should have enough memory).
Maybe we can exchange notes?
Posted: Wed Mar 20, 2019 3:24 pm
by Andyroo
The OP has not been back here since Jan. You can check by clicking on their user name in the post.
Posted: Thu Mar 21, 2019 7:48 am
by Robbiedobbie
Always worth a try. He might have a subsciption on this topic, with an email alert...
Posted: Sun Apr 07, 2019 3:14 pm
by gedw99
If anyone gets a GitHub repo up with the build of flutter on rasp pi please list it.
I run flutter on desktops with golang and can help port plugins etc to get it all ticking along on a rasp pi.
Pretty exciting stuff btw !
Posted: Mon Apr 08, 2019 7:48 am
by Robbiedobbie
It's not too hard to start from scratch. Basically you just use your hello triangle example but link against a self build (Which is the hardest part) libflutter_engine.so, and call the FlutterEngineRun function with a config for opengl backends. You then implement 5 callbacks that should refer back to opengl functions, et voila, it runs. (If you try release mode builds for the engine, you'll also have to prepare an AOT binary blob from your app, and map that into (partly executable memory).
I'm currently working on a photobooth in this framework, and will be releasing it as opensource when it's finished. It will have the code to run on raspberry pi, but I'm not sure that it will actually run on it. I still haven't managed to solve the texture issue, but it sure looks like it's just a limit on the very limited gpu of the raspberry pi.
I suspect that a raspi clone with a more modern (mali?) gpu would work much better for flutter.
Posted: Fri Jun 07, 2019 9:08 am
by ardera
Got it working too, including mouse support (but not mouse cursor support!). Code for the embedder is here: https://github.com/ardera/flutter-pi
And I, too, got the same weird texture problem; could be that it's because I didn't implement the make_resource_current callback, but that should be optional.
I don't think it's the VRAM either, cause the behaviour is the same with 64MB or 256MB VRAM. There are definitely points where all textures are loaded and visible, so maybe it's not the amount of textures that's causing this. I really hope it's just some kind of inconsistency in the raspberry pi's graphics implementation that we can hack around.
Performance is not that bad, 50-60fps with the default "flutter create" app, and I didn't even compile the engine in release mode yet.
Posted: Fri Jun 07, 2019 9:12 am
by Robbiedobbie
I did implement make_resource_current since I also thought it might be related to that. It is not :(
I still think it is either memory related (It does seem to display just a little bit more with more vram). However, it might also have to do with the lack of power of 2 textures, however, I haven't looked into this...
Posted: Fri Jun 07, 2019 8:04 pm
by ardera
I still don't think it's memory related. You can get the amount of free gpu ram usage with
vcgencmd get_mem malloc
vcgencmd get_mem reloc
(Which is the amount of free-mem in the VideoCore malloc heap + VideoCore reloc heap)
For me, there were always 10MB (of 12MB total) malloc heap and ~190 (of ~245MB total) reloc heap free.
Also, there are a lot of basic OpenGL games that run under the VC IV. They probably use more textures that the basic "flutter create" app. So I don't think (and hope) it's hitting a VRAM limit here.
But how do you even start debugging this? I thought of hooking the procedures returned by the proc_resolver callback to trace the GL calls, but that's so much work.
EDIT: added VRAM numbers
Posted: Tue Jul 09, 2019 3:19 am
by bbt
Hi, I'm apologize to bring this topic up.
I'm trying to get the flutter to work on a RPi 3B without the desktop, it ran, but the touchscreen is not working (It works under desktop)
Here's what I have so far in the video
https://www.youtube.com/watch?v=3hmxaH_z7mY
Can someone give a idea what I should try next? Many thanks!
Posted: Tue Jul 09, 2019 8:19 pm
by ardera
I assume you built the flutter engine & flutter engine embedder using https://medium.com/flutter/flutter-on-r ... 24c5e7dcb1 and https://github.com/jwinarske/flutter_embedded/. I say that because that's definitely not the only way to get flutter running on Pi. Flutter on Pi is HIGHLY experimental. It's not at all production-ready.
The only reason the flutter_gallery app doesn't crash like 1 second after it's started is because flutter for raspberry pi is so unfinished, the callback that'd enable the app to talk to the platform-side is not implemented. If you implement it, that app crashes because it tries to talk with the platform side but there is no platform side. (I didn't test it, but that's my hypothesis)
In your case though, I think the fix is simple. You need the specify which input device flutter should use. Do
TSLIB_TSDEVICE=/dev/input/event0 ./run.sh
If that doesn't work, try with /dev/input/event1, etc until you find a number that works.
You can also avoid the trial-and-error if you execute
evtest
and use the input device path where it says ... memory-based driver ...
EDIT: Rewrote my response after I found out which embedder you were using.
Posted: Wed Jul 10, 2019 9:06 am
by bbt
Hi, ardera thanks for reply!
Yes, I'm using the guide and jwinarske's Github as reference.
I did try
, but still nothing happened, also re-compiled libts and the touch testing works under CLI.
Would you mind to share the compiled flutter binary and libflutter_engine.so and the sample you're using for me to test?
Here's the output from the console:
LOG: ../flutter/main.cc:66: Display Size: 800 x 480
[ERROR:flutter/shell/platform/embedder/embedder_surface_gl.cc(95)] Could not create a resource context for async texture uploads. Expect degraded performance. Set a valid make_resource_current callback on FlutterOpenGLRendererConfig.
flutter: Observatory listening on http://127.0.0.1:32935/Skd_3ihL700=/
[ERROR:flutter/lib/ui/ui_dart_state.cc(148)] Unhandled Exception: Exception: operation failed
#0      ShaderWarmUp.execute (package:flutter/src/painting/shader_warm_up.dart:90:5)
<asynchronous suspension>
#1      _WidgetsFlutterBinding&BindingBase&GestureBinding&ServicesBinding&SchedulerBinding&PaintingBinding.initInstances (package:flutter/src/painting/binding.dart:25:20)
#2      _WidgetsFlutterBinding&BindingBase&GestureBinding&ServicesBinding&SchedulerBinding&PaintingBinding&SemanticsBinding.initInstances (package:flutter/src/semantics/binding.dart:22:11)
#3      _WidgetsFlutterBinding&BindingBase&GestureBinding&ServicesBinding&SchedulerBinding&PaintingBinding&SemanticsBinding&RendererBinding.initInstances (package:flutter/src/rendering/binding.dart:29:11)
#4      _WidgetsFlutterBinding&BindingBase&GestureBinding&ServicesBinding&SchedulerBinding&PaintingBinding&SemanticsBinding&RendererBinding&WidgetsBinding.initInstances (package:flutter/src/widgets/binding.dart:252:11)
#5      new BindingBase (package:flutter/src/foundation/binding.dart:56:5)
#6      new _WidgetsFlutterBinding&BindingBase&GestureBinding (package:flutter/src/widgets/binding.dart)
#7      new _WidgetsFlutterBinding&BindingBase&GestureBinding&ServicesBinding (package:flutter/src/widgets/binding.dart)
#8      new _WidgetsFlutterBinding&BindingBase&GestureBinding&ServicesBinding&SchedulerBinding (package:flutter/src/widgets/binding.dart)
#9      new _WidgetsFlutterBinding&BindingBase&GestureBinding&ServicesBinding&SchedulerBinding&PaintingBinding (package:flutter/src/widgets/binding.dart)
#10     new _WidgetsFlutterBinding&BindingBase&GestureBinding&ServicesBinding&SchedulerBinding&PaintingBinding&SemanticsBinding (package:flutter/src/widgets/binding.dart)
#11     new _WidgetsFlutterBinding&BindingBase&GestureBinding&ServicesBinding&SchedulerBinding&PaintingBinding&SemanticsBinding&RendererBinding (package:flutter/src/widgets/binding.dart)
#12     new _WidgetsFlutterBinding&BindingBase&GestureBinding&ServicesBinding&SchedulerBinding&PaintingBinding&SemanticsBinding&RendererBinding&WidgetsBinding (package:flutter/src/widgets/binding.dart)
#13     new WidgetsFlutterBinding (package:flutter/src/widgets/binding.dart)
#14     WidgetsFlutterBinding.ensureInitialized (package:flutter/src/widgets/binding.dart:994:7)
#15     runApp (package:flutter/src/widgets/binding.dart:785:25)
#16     main (package:example_flutter/main.dart:23:3)
#17     _runMainZoned.<anonymous closure>.<anonymous closure> (dart:ui/hooks.dart:216:25)
#18     _rootRun (dart:async/zone.dart:1124:13)
#19     _CustomZone.run (dart:async/zone.dart:1021:19)
#20     _runZoned (dart:async/zone.dart:1516:10)
#21     runZoned (dart:async/zone.dart:1500:12)
#22     _runMainZoned.<anonymous closure> (dart:ui/hooks.dart:208:5)
#23     _startIsolate.<anonymous closure> (dart:isolate-patch/isolate_patch.dart:305:19)
#24     _RawReceivePortImpl._handleMessage (dart:isolate-patch/isolate_patch.dart:172:12)
evtest
Posted: Wed Jul 10, 2019 8:03 pm
by ardera
I don't have a working "flutter binary" either. I use my own embedder
I can share my libflutter_engine.so with you but im 200% positive we got the exact same one, and even if we don't, the engine is not responsible for fetching touchscreen input.
Are you really sure you tried not only with
, but also with
TSLIB_TSDEVICE=/dev/input/event1
and
TSLIB_TSDEVICE=/dev/input/event2
and so forth?
I'm 95% sure it has to do with configuration. Could you please execute
evtest
and show me the output?
