Yorgi
First Step With Raspberry And C#
Sun Nov 18, 2012 3:11 pm
Hi Everyone!
I totally new in developing on Raspberry Pi - I have to make application for project in my school on this little thing.
Because I can't access to RPi in home, I download QEMU with wheezy-raspbian and I'm trying to do anything what would work using C#.
Long story short - I just wrote couple lines of code to check how it works
using System;
using System.Windows.Forms;
namespace program
    static class Program
        static void Main()
            Application.EnableVisualStyles();
            Application.SetCompatibleTextRenderingDefault(false);
            Application.Run(new Form1());
    public partial class Form1 : Form
        private System.Windows.Forms.Button button1;
        private int i = 0;
        public Form1()
            InitializeComponent();
        private void InitializeComponent()
            this.button1 = new System.Windows.Forms.Button();
            this.SuspendLayout();
            // button1
            this.button1.Location = new System.Drawing.Point(12, 12);
            this.button1.Name = "button1";
            this.button1.Size = new System.Drawing.Size(75, 23);
            this.button1.TabIndex = 0;
            this.button1.Text = "0";
            this.button1.UseVisualStyleBackColor = true;
            this.button1.Click += new System.EventHandler(this.button1_Click);
            // Form1
            this.ClientSize = new System.Drawing.Size(120, 60);
            this.Controls.Add(this.button1);
            this.Name = "Form1";
            this.Text = "Form1";
            this.ResumeLayout(false);
        private void button1_Click(object sender, EventArgs e)
            Button btn = (Button)sender;
            ++i;
            btn.Text = i.ToString(); ;
I build it using command:
mcs -r:System.Windows.Forms,System.Drawing program.cs
which returns nothing - built without errors.
I run it by
mono program.exe
and there's my problem: I'm getting an error
[email protected] ~ $ mono program.exe
Stacktrace:
  at System.Drawing.Font.CreateFont (string,single,System.Drawing.FontStyle,System.Drawing.GraphicsUnit,byte,bool) <0x00143>
  at System.Drawing.Font..ctor (string,single,System.Drawing.FontStyle,System.Drawing.GraphicsUnit,byte,bool) <0x0007f>
  at System.Drawing.Font..ctor (string,single,string) <0x00057>
  at (wrapper remoting-invoke-with-check) System.Drawing.Font..ctor (string,single,string) <0xffffffff>
  at System.Drawing.SystemFonts.get_DefaultFont () <0x00073>
  at System.Windows.Forms.Theme..ctor () <0x0002f>
  at System.Windows.Forms.ThemeWin32Classic..ctor () <0x00013>
  at System.Windows.Forms.ThemeEngine..cctor () <0x0009f>
  at (wrapper runtime-invoke) object.runtime_invoke_void (object,intptr,intptr,intptr) <0xffffffff>
  at System.Windows.Forms.SystemInformation.get_MenuAccessKeysUnderlined () <0x00007>
  at System.Windows.Forms.Control..ctor () <0x001f3>
  at (wrapper remoting-invoke-with-check) System.Windows.Forms.Control..ctor () <0xffffffff>
  at System.Windows.Forms.WindowsFormsSynchronizationContext..cctor () <0x0002b>
  at System.Windows.Forms.Control..ctor () <0x0004b>
  at System.Windows.Forms.ScrollableControl..ctor () <0x00013>
  at System.Windows.Forms.ContainerControl..ctor () <0x00023>
  at System.Windows.Forms.Form..ctor () <0x0006b>
  at program.Form1..ctor () <0x00013>
  at (wrapper remoting-invoke-with-check) program.Form1..ctor () <0xffffffff>
  at program.Program.Main () <0x0002b>
Native stacktrace:
Debug info from gdb:
Cannot access memory at address 0x0
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
[New Thread 0x40935460 (LWP 2148)]
0x400faf30 in read () from /lib/arm-linux-gnueabihf/libpthread.so.0
  Id   Target Id         Frame
  2    Thread 0x40935460 (LWP 2148) "mono" 0x400f9d84 in [email protected]@GLIBC_2.4 () from /lib/arm-linux-gnueabihf/libpthread.so.0
* 1    Thread 0x40059000 (LWP 2147) "mono" 0x400faf30 in read () from /lib/arm-linux-gnueabihf/libpthread.so.0
Thread 2 (Thread 0x40935460 (LWP 2148)):
#0  0x400f9d84 in [email protected]@GLIBC_2.4 () from /lib/arm-linux-gnueabihf/libpthread.so.0
#1  0x00195a40 in mono_sem_wait ()
#2  0x000ea384 in ?? ()
#3  0x000ea384 in ?? ()
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 1 (Thread 0x40059000 (LWP 2147)):
#0  0x400faf30 in read () from /lib/arm-linux-gnueabihf/libpthread.so.0
#1  0x400fa770 in __pthread_enable_asynccancel () from /lib/arm-linux-gnueabihf/libpthread.so.0
#2  0x00000000 in ?? ()
Got a SIGSEGV while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
Aborted
What cause that? Why it won't work?
I'm tried find something in google but I can't find anything what can solve that.
And another question:
Is there possibility to build whole project, that with .sln extension? (I'm writing in Visual Studio)
3gws
Re: First Step With Raspberry And C#
Sun Nov 18, 2012 5:57 pm
Yorgi, you need to use the soft float very of Wheezy 08-08-12, it wont work with the hard float version.
They (Mono) home to have a hard float version before xmas(their quote).
I am using VS2010 to compile and trasferring across using to the RPi using winSCP.
Set your project to be any CPU and Dotnet 3.5.
I have managed to get the GPIO working with C# using a library from David's Blogg http://www.codehosting.net/blog/BlogEngine/?tag=/Mono.
I also have a FTP client working also.
I am very please with C# and had great help from Edwin here on the site getting up and going with Mono C#.
The best of Luck and if you need any help just ask, I might not be able to answer all of your questions !.
Regards
3gws.
Yorgi
Wed Nov 21, 2012 10:39 pm
Thank You very much for Your answer.
But still don't know how to bulid whole C# project.
Should I put all .cs files in parameters of mcs or what?
Yorgi
Thu Nov 22, 2012 12:34 am
Ok, nevermind.
I found out that I need to use "xbuild" command.
MattSwarbrick
Fri Nov 23, 2012 1:20 pm
There is the hard float patch found here:
https://github.com/directhex/mono-1/tree/armhf-port
To clone the source and get the amhf port code do the following:
git clone git://github.com/directhex/mono-1.git
cd mono-1
git checkout remotes/origin/armhf-port
This is talked about in the raspberry pi forum: http://www.raspberrypi.org/phpBB3/viewt ... no#p218815
