FeersumEndjinn
MySQL: Writing trigger that uses custom function
Thu Nov 15, 2012 4:07 pm
I am teaching myself MySQL by writing a database for a craft business I run, hosted on my pi.
I am trying to write a MySQL trigger that, upon update of a row, will call a custom function (which works fine outside of the trigger) and update a column in the table the trigger is on.
BEGIN
UPDATE candles
SET can_materials_cost = (SELECT calculateMaterialCost(NEW.can_id)
WHERE candles.can_id = NEW.can_id);
END
I've written basic audit style triggers that upon update save the old value into a different table, but for some reason when trying to use my custom function I receive an error stating:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'WHERE candles.can_id = NEW.can_id);
END' at line 4
The custom function performs:
BEGIN
-- This function assumes that the raw wax cost is for 20kg bags only - BEWARE!
DECLARE result DECIMAL(10,2);
SET result = (
(select calculateWaxCost(_can_id))
(select calculateDyeCost(_can_id))
(select calculateScentCost(_can_id)));
RETURN result;
END
Please can anyone shed some light on where I'm going wrong?
Many thanks.
Morrolan / FeersumEndjinn
"And the lord God said unto John, 'Come forth and receive eternal life', but John came fifth and won a toaster."
tufty
Re: MySQL: Writing trigger that uses custom function
Thu Nov 15, 2012 4:21 pm
Looks like an error in your trigger definition, not the custom function. The error message looks like you might have an extraneous closing bracket.
BlackJack
Fri Nov 16, 2012 1:02 pm
@FeersumEndjinn: Looks like the closing parenthesis for the SELECT expression is missing or rather moved to the end of the next line. Untested:
BEGIN
UPDATE candles
SET can_materials_cost = (SELECT calculateMaterialCost(NEW.can_id))
WHERE candles.can_id = NEW.can_id;
END
while not self.asleep():
    sheep += 1
Who is online
