eiya
RaspberryPiDotNet Install
Wed Sep 19, 2018 7:29 am
Hello
I'm a beginner in Linux and Raspberry.
I tried to build the RaspberryPiDotNet.csproj from https://github.com/cypherkey/RaspberryP ... ryPiDotNet but i the build failed.
I already installed mono-complete.
When i try to build the .csproj file i just get all these Errors:
XBuild Engine Version 14.0
Mono, Version 4.6.2.0
Copyright (C) 2005-2013 Various Mono authors
Build started 19.09.2018 09:27:06.
__________________________________________________
Project "/home/pi/RaspberryPi.Net/RaspberryPiDotNet/RaspberryPiDotNet.csproj" (default target(s)):
Target PrepareForBuild:
Configuration: Debug Platform: AnyCPU
Target GenerateSatelliteAssemblies:
No input files were specified for target GenerateSatelliteAssemblies, skipping.
Target _GenerateTargetFrameworkMonikerAttribute:
Skipping target "_GenerateTargetFrameworkMonikerAttribute" because its outputs are up-to-date.
Target CoreCompile:
Tool /usr/lib/mono/4.5/mcs.exe execution started with arguments: /noconfig /debug:full /debug+ /optimize- /out:obj/Debug/RaspberryPiDotNet.dll DS1620.cs GPIO.cs GPIODebug.cs GPIODirection.cs GPIOFile.cs GPIOMem.cs GPIOPins.cs GPIOResistor.cs MCP3008.cs MicroLiquidCrystal/RaspPiGPIOFileLcdTransferProvider.cs MicroLiquidCrystal/RaspPiGPIOMemLcdTransferProvider.cs MicroLiquidCrystal/ILcdTransferProvider.cs MicroLiquidCrystal/Lcd.cs PinState.cs Properties/AssemblyInfo.cs TM16XX/TM1638.cs TM16XX/TM16XX.cs obj/Debug/.NETFramework,Version=v4.0.AssemblyAttribute.cs /target:library /define:"DEBUG;TRACE" /doc:bin/Debug/RaspberryPiDotNet.XML /nostdlib /reference:/usr/lib/mono/gac/System/4.0.0.0__b77a5c561934e089/System.dll /reference:/usr/lib/mono/gac/System.Core/4.0.0.0__b77a5c561934e089/System.Core.dll /warn:4
CSC: error CS0518: The predefined type `System.Object' is not defined or imported
CSC: error CS0518: The predefined type `System.ValueType' is not defined or imported
CSC: error CS0518: The predefined type `System.Attribute' is not defined or imported
CSC: error CS0518: The predefined type `System.Int32' is not defined or imported
CSC: error CS0518: The predefined type `System.UInt32' is not defined or imported
CSC: error CS0518: The predefined type `System.Int64' is not defined or imported
CSC: error CS0518: The predefined type `System.UInt64' is not defined or imported
CSC: error CS0518: The predefined type `System.Single' is not defined or imported
CSC: error CS0518: The predefined type `System.Double' is not defined or imported
CSC: error CS0518: The predefined type `System.Char' is not defined or imported
CSC: error CS0518: The predefined type `System.Int16' is not defined or imported
CSC: error CS0518: The predefined type `System.Decimal' is not defined or imported
CSC: error CS0518: The predefined type `System.Boolean' is not defined or imported
CSC: error CS0518: The predefined type `System.SByte' is not defined or imported
CSC: error CS0518: The predefined type `System.Byte' is not defined or imported
CSC: error CS0518: The predefined type `System.UInt16' is not defined or imported
CSC: error CS0518: The predefined type `System.String' is not defined or imported
CSC: error CS0518: The predefined type `System.Enum' is not defined or imported
CSC: error CS0518: The predefined type `System.Delegate' is not defined or imported
CSC: error CS0518: The predefined type `System.MulticastDelegate' is not defined or imported
CSC: error CS0518: The predefined type `System.Void' is not defined or imported
CSC: error CS0518: The predefined type `System.Array' is not defined or imported
CSC: error CS0518: The predefined type `System.Type' is not defined or imported
CSC: error CS0518: The predefined type `System.Collections.IEnumerator' is not defined or imported
CSC: error CS0518: The predefined type `System.Collections.IEnumerable' is not defined or imported
CSC: error CS0518: The predefined type `System.IDisposable' is not defined or imported
CSC: error CS0518: The predefined type `System.IntPtr' is not defined or imported
CSC: error CS0518: The predefined type `System.UIntPtr' is not defined or imported
CSC: error CS0518: The predefined type `System.RuntimeFieldHandle' is not defined or imported
CSC: error CS0518: The predefined type `System.RuntimeTypeHandle' is not defined or imported
CSC: error CS0518: The predefined type `System.Exception' is not defined or imported
Task "Csc" execution -- FAILED
Done building target "CoreCompile" in project "/home/pi/RaspberryPi.Net/RaspberryPiDotNet/RaspberryPiDotNet.csproj".-- FAILED
Done building project "/home/pi/RaspberryPi.Net/RaspberryPiDotNet/RaspberryPiDotNet.csproj".-- FAILED
Build FAILED.
Errors:
/home/pi/RaspberryPi.Net/RaspberryPiDotNet/RaspberryPiDotNet.csproj (default targets) ->
/usr/lib/mono/xbuild/14.0/bin/Microsoft.CSharp.targets (CoreCompile target) ->
0 Warning(s)
31 Error(s)
Can anyone help me?
grimreaper_40_uk
Re: RaspberryPiDotNet Install
Tue Sep 25, 2018 6:31 pm
Looks like Mono didn't install properly, or it can't find the base system files?! Not a lot else to go on from that build output.
I find it easier to compile on a PC and just transfer the compiled output to the Pi - have you tried it that way round?
Who is online
Users browsing this forum: No registered users and 1 guest
