kikeroga
HSP3Dish for Raspbian
Sat Apr 07, 2018 5:03 am
HSP (Hot Soup Processor) is a scripting language system that can be used by anyone with ease.
Write a script by text, easy to operate on Windows, the game program with the image, you can build an application such as tools and practical software.
The HSP, has the following features.
- You can start using it right away in the all-in-one development environment
- Also handle a beginner by the instruction set that is easy to remember
- There is actually used a lot of user assets for over 20 years
- Interpreter performance specifications are published as open source
HSP can be used in various situations depending on your ideas.
- The game create a variety of genres from visual novel to a full-fledged 3D shooting
- Prototype of the screen layout, the instant tools such as conversion of image data
- Program launcher, menu, CG collection, in the media browser, such as Music Collection
- Others, also can be developed full-fledged application
https://github.com/kikeroga3/OpenHSP
Original is here.
http://github.com/onitama/OpenHSP
Kikeroga.
kikeroga
Re: HSP3Dish for Raspbian
Thu Apr 12, 2018 10:53 am
kikeroga
Thu Apr 12, 2018 2:45 pm
kikeroga
Sat Apr 14, 2018 4:11 pm
Example of using support module "Picot"
Source
https://github.com/kikeroga3/OpenHSP/tr ... /mod_picot
kikeroga
Mon Apr 16, 2018 11:41 pm
Raspberry Pi's GPIO I/O
Besides the devprm instruction, the Raspberry Pi version is extended with GPIO I/O by devcontrol instruction. When controlling GPIO output, write as follows.
devcontrol "gpio", port number, output value
For port number, specify the GPIO port as a numerical value. The output value is controlled by specifying 1 (ON) or 0 (OFF) as a numerical value. When inputting, write as follows.
devcontrol "gpioin", port number
0 or 1 is assigned to the system variable stat after execution of the instruction. (If an error occurs, a negative value is assigned) GPIO I/O can be used not only from hsp3dish but also from hsp3cl.
kikeroga
Sun May 13, 2018 4:57 am
About the introduction of HSP 3 for Linux / Raspberry Pi, the page "Introductory beginner HSP programming raspberry pie version by JBOYSOFT" which is described for beginners is released. For Raspberry Pi users, please try it.
https://junji.jp/hspenglish/
