dave_uk_2018
Upgrading Qt 5.7.1 to 5.10
Sat Mar 17, 2018 10:39 am
I've installed Qt 5.7.1 on a Pi 3 by using
sudo apt-get install qt5-default
sudo apt-get install qtcreator
That is working fine but now I need to use some features from Qt 5.10.
How do I do an upgrade to 5.10 ?
Or how can I install 5.10 from scratch ?
Thanks.
Dave
Re: Upgrading Qt 5.7.1 to 5.10
Sat Mar 17, 2018 6:32 pm
This is an endless problem with Raspbian, Debian and other Linux distros.
They package well tested and stable versions of everything, which is a good thing. But then you find you want some latest cutting edge feature of whatever program/library it is.
Generally I find that the way to do this is to build the latest version of whatever you want from the upstream project sources.
Such was the case when I wanted Qt5 back when Raspbian only had Qt4. The only thing to do was download the Qt5 sources and build it myself.
Problem is, finding instructions as to how to do that was very hard, most did not work.
Actually doing it took many hours.
Times have changed since then but you could start from here: https://wiki.qt.io/Native_Build_of_Qt5_ ... spberry_Pi
Sat Mar 17, 2018 6:44 pm
Thanks.
Dave
ArchLinuxArm is a Rolling Release and has the newer packages you desire:
https://archlinuxarm.org
adieu
My other Computer is an Asus CS10 ChromeBit
