Nannapaneni
How to run a raspbian terminal command using javascript?
Wed Mar 07, 2018 11:33 am
If I want to run a command in raspbian terminal using p5.js with the click of a button on the console, what would be the command in js?
topguy
Re: How to run a raspbian terminal command using javascript?
Wed Mar 07, 2018 12:48 pm
Ask the P5.js guys. :-)
In general I would be very surprised if there was such a command in standard Javascript. Code running in a browser should not be able to run system commands because that would totally be a violation of security.
Is p5.js code running on host/server or in the browser ?
Nannapaneni
Wed Mar 07, 2018 1:33 pm
Thank you for your reply.
p5.js code is running in the browser. :o
Wed Mar 07, 2018 3:55 pm
p5.js runs in the browser. As such it cannot run any terminal commands.
You could have the Javascript in the browser communicate with some more Javascript running as a server under node.js. That Javascript can then run shell commands when requested by the browser and return any results back to the browser.
