3gws
Tutorial to install Eclipse (for Java) on the RPI
Sat Oct 20, 2012 10:50 am
Hello everybody, I have just received my RPi with 512MB and I want to use eclipse on it I am coming from an Android coding back ground I would like to use Java on the device.
I had a go at installing it last night but it failed I am sure I missed something it seemed that it was unable to find files required over the web to complete it.
As I have only just got the device and have the bare OS installed I can easily start from scratch again.
So if there is anybody out there who can point me in the right direction I would very much appreciate it.
Thanks in advance
3GWS
xranby
Re: Tutorial to install Eclipse (for Java) on the RPI
Sat Oct 20, 2012 7:46 pm
3gws wrote:Hello everybody, I have just received my RPi with 512MB and I want to use eclipse on it I am coming from an Android coding back ground I would like to use Java on the device.
Thanks in advance
3GWS
For best out of the box experience, install the Rasbian/Debian built eclipse package by running the following two commands.
sudo apt-get update
sudo apt-get install eclipse
Xerxes Rånby @xranby I once had two, then I gave one away. Now both are in use every day!
twitter.com/xranby
3gws
Sun Oct 21, 2012 12:36 pm
Thanks for that I have installed it and it is very slow to load or do anything with it.
I have nothing else running so it has all of the ram it requires to run.
I appreciate we are ruuning it on a 700mhz Single core processor so my next question is can I use a cross compiler for the R-Pi on a windows PC in the same fashion as Android, is there Raspberry Development Tool like ADT?.
Having an extreamly fast laptop with loads of everything has spoiled me, so waiting 10 mins approx for the IDE to load is going to be its downfnall for me.
Regards
3gws
savageautomate
Sun Oct 21, 2012 4:45 pm
3gws wrote:Thanks for that I have installed it and it is very slow to load or do anything with it.
Regards
3gws
I do all my Java development in Eclipse on a laptop or other computer and then just transfer (SCP) the compiled/packaged JAR down to the Raspberry Pi when I want to run/test it. Since you are using Java, there is no cross-compiler needed. Write once - run anywhere ... and all that ..
If you are interested, check out this open source project: Pi4J.
https://github.com/Pi4J/pi4j/
In this project, I am using Maven to automate the build, package the JAR and then copy the resulting JAR over to the Pi via SCP. It is very fast and once it is copied over, I can just switch to my Putty SSH console and execute the Java program for testing. See the POM.XML files for details on the Maven script.
If you start creating native code for JNI, then you would have to cross compile or compile those parts on the Pi itself. The pi4j-native sub-project is just that and the Maven script is copying all the native C sources to the Pi and carrying out the compilation on the Pi hardware. Eventually I'll switch to a cross-compiler, but this was easy to setup and get started.
Robert Savage | Follow me @savageautomate
http://www.pi4j.com | http://www.pislices.com
http://www.savagehomeautomation.com
savageautomate
Sun Oct 21, 2012 4:50 pm
Also, if you need to get better Java runtime performance, you may want to switch to the Oracle JDK instead of the OpenJDK.
See comparison benchmarks here:
http://www.savagehomeautomation.com/pro ... marks.html
Installation instructions for the Oracle JDK 1.7.0u6 here:
http://www.savagehomeautomation.com/pro ... -170u.html
Note, to use the Oracle JDK, you do have to use the Debian "wheezy" (soft-float) distribution on the downloads page and no the Raspbian (hard-float) distribution.
Glollum
Mon Jan 21, 2013 5:16 pm
You can still use the hard-float distro if you install JDK8 from http://jdk8.java.net
R-Pi Model B 512MB
Dell monitor 1280x1024
Raspbian Wheezy
JDK 8 (http://jdk8.java.net)
andrei001
Mon Nov 18, 2013 2:43 am
I installed it via apt-get, but now what? How do I start the program?
xranby
Mon Nov 18, 2013 10:33 am
andrei001 wrote:I installed it via apt-get, but now what? How do I start the program?
First start the X11 gui after you have logged in.
startx
Inside the graphical user interface locate the eclipse launcher inside the lxde application menu or open a "terminal" window and type
eclipse
twitter.com/xranby
tobiz
Mon Jan 27, 2014 1:16 pm
I've installed Eclipse on my RasPi after updating to all the latest s/w releases (using Synaptic). Eclipse runs, slowly but what would you expect @ 700Mhz. However if I try to run "Help->Install New Software->Work with All Available Sites" it does run to completion, however if you then try to filter this (I want to install Django) it seems to just hang. Is there an issue here?
tobizpi
Tue Feb 11, 2014 10:55 am
To install django on Eclipse you just install PyDev. To install PyDev do Help-->Install New Software, then do Add (by rhs of Work with) put http://pydev.com/updates. Then w a i t, in the box below it will say 'Pending', but eventually a list will appear listing several versions of PyDev for Eclipse. Select one of these, probably best if not the latest and then w a i t again. Then do just as specified and if you're luck you should find PyDev is available under the Window-->Preferences-->PyDev-->Interpreter Python and it should show PyDev in the upper box. If the lower box is empty then press 'Auto Configure' by the upper box and w a i t. Eventually a list of libraries will appear. In the lower box you probably need to enter these two String Substitution Variables "DJANGO_MANAGE_LOCATION" "/manage/" and "DJANGO_SETTINGS_MODULE" "/settings/. Afterwards you may be asked to restart Eclipse. After all this you may be able to do File-->New-->Other--PyDev Django Project. I say may since I've got this far but after this is seems to think django is not installed but I know it is since python import django works. The above sequence works on ubuntu but for some unfathomable reason seems to fall at the last hurdle on RasPI. If anyone knows why then please publish!
ghatch2
Tue Jul 22, 2014 7:16 pm
Does anyone know how to have an updated version of Eclipse on the RPi board? I've used the following commands:
sudo apt-get update
But this gave me a Eclipse 3.8 version and my Windows PC has a more up to date version.
riklaunim
Tue Jul 22, 2014 7:35 pm
It would be more handy to do programming remotely and not battle with Eclipse on RPi ;) I got remote Python executable in PyCharm and I can remotely execute code I write from my laptop.
ghatch2
Tue Jul 22, 2014 8:30 pm
So you are suggesting to do it remotely with Python? I know that the RPi board comes with Python (IDLE) on it, but I've heard that a lot of people suggest using Eclipse. My main reason for asking is because I am also using the Rapiro robot (which is designed to be used with the RPi Board)
Note: If you are familiar with Rapiro that when you typing something like this in the terminal:
echo "#M6" | sudo minicom -b 57600 -o -D /dev/ttyAMA0
makes the Rapiro move, but I'm looking for a more solid (save-able) method of coding these type of commands.
hactic
Tue Jun 09, 2015 3:39 pm
Hi all,
I had Eclipse 3.8 installed on my Raspi 2B with apt-get but now want to have the latest and greatest.
So when I download "Linux 32 bit" Luna (eclipse-jee-luna-SR2-linux.gtk.tar.gz), put it in /opt/eclipse and try to launch /opt/eclipse/eclipse, I get a "bash: ./eclipse: cannot execute binary file". The file itself has all execution flags (-rwx-r-x-r-x) set, and I chowned it to belong to pi:pi.
Do I need a another version for the arm architecture?
Ist there another way to start the IDE e. g. directly via a jar?
I tried ...
java -jar plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar org.eclipse.equinox.launcher.Main
... but no success. Error message says:
org.eclipse.m2e.logback.configuration: The org.eclipse.m2e.logback.configuration bundle was activated before the state location was initialized. Will retry after the state location is initialized.
Log reports a java.lang.ClassNotFoundException: org.eclipse.swt.SWTError
This is contained in plugins/org.eclipse.swt.gtk.linux.x86_3.103.2.v20150203-1351.jar, but adding it to the start classpath (separated with a colon) does not help either?!
Tue Jun 09, 2015 9:21 pm
That is Java for you. Write once, run anywhere :)
g_madness
Mon Sep 21, 2015 12:15 am
My raspberry pi installs eclipse 3.8
Does anyone know how to possibly update it?
Wed Sep 23, 2015 9:18 am
hactic,
I don't know if you are still following this thread but:
The answer to your problem is in your own post:
Notice that "x86" in there? It's no use trying to run code built for an Intel x86 processor on a Rasperry Pi. The Pi has an ARM processor. A totally different architecture and instruction set.
In my experience Eclips is huge, slow, complex and clumsy to use even on a PC I can't imagine how lame it is on the Pi.
Even if you like Eclipse I can image that getting any version installed that does not come as a standard raspbian package is going to be a non-trivial task.
