clarkDriller
node-red scan ble with Tile trackers
Tue Jan 09, 2018 1:22 pm
Getting inconsistent results with the scan ble node. It appears to have a mind of it's own regarding when it scans and obtains location info from the Tile {Mate version} equipment I'm interfacing with.
The node-red Scan Ble node info tab indicates you can send: msg.payload.scan=false to turn off scanning, and msg.payload.scan=true to turn it on.
I've tried including the following in a function node linked to the input of the scan ble node:
if (msg.payload === 'on') {
msg.scan = true;
} else {
msg.scan = false;
return msg;
It creates a error like:
"Incorrect input, ignoring. See the documentation in the info tab. "
Has anyone been successful at controlling the scan rates and the process to do it with the 'scan ble' node?
emme
Re: node-red scan ble with Tile trackers
Sun Sep 30, 2018 4:35 pm
Ciao,
I do...
I have a scan BLE (noble node) that it is activated and deactivated every minute.
to toggle it I use a flow context variable and this code:
var msg = {};
msg.payload = {};
flow.set('scanStatus', !flow.get('scanStatus'));
msg.payload.scan = flow.get('scanStatus');
return msg;
your error is that you indicate msg.scan = true, but it has to be msg.payload.scan = true
ciao
M
rnowacki
Sat Oct 19, 2019 4:53 am
Similar issue here trying to use the
msg.payload.scan=false to turn off scanning, and msg.payload.scan=true to turn it on but get
I've tried a bunch of different ways of setting the .scan value and always get the error. What is the best way to do this?
https://drive.google.com/open?id=1-WCeE ... VGFfhzSAtq
