Darranking
Node.js with i2c one wire
Mon Jan 08, 2018 8:18 pm
Hi
I am exploring using 1-wire temp sensors on an i2c interface.
I have one of these
https://www.modmypi.com/raspberry-pi/se ... ion-module
Now I can see the i2c device, in the os using i2cdetect address 1b. But my question is can someone point me in the right direction of a good tutorial for talking to the sensor attached to this using node.js
Re: Node.js with i2c one wire
Mon Jan 08, 2018 8:30 pm
Google is your friend. A quick search for "raspberry pi i2c" turns up tons of modules for using i2c from node.js and a lot of tutorials and blogs about it.
This looks like the best bet: https://www.npmjs.com/package/i2c-bus
Includes an example and wiring for a one wire sensor.
Darranking
Tue Jan 09, 2018 3:00 pm
Thanks for the reply
I have searched the internet and can find lots of examples using different packages, but they have one thing in common, the temp sensor is connected using the 1-wire implementation on the GPIO (4) pin.
I have the temp sensor attached to the i2c interface via the board. in my original post.
The link provided also shows a directly connected implementation.
I have also tried several of the packages on NPM and cannot get them to install properly, they fail when compiling.
I have RASPI-I2C package installed correctly and using the example code on the NPM site I am able to read the first byte of the sensor at address 1B on the i2c bus but I am not clear on how I can read the temperature from this.
If someone could point me in the correct direction from here I would appreciate it. In the meantime I will keep searching the net for examples.
zassx
Tue Jan 16, 2018 11:52 am
Check out my topic, I am doing exactly this. The topic contains a link to my source code so feel free to check out which libraries I am using and how am I reading temperatures and displaying everything on i2c OLED.
viewtopic.php?f=91&t=202603
