node-red at startup
Posted: Fri Dec 15, 2017 3:07 pm
by paolojo
I would start node-red at the boot of my raspy pi3.
I've tried the following command:
udo systemctl enable nodered.service
but it doesn't work.
Someone can help me?
Thank in advance
Paolo
Re: node-red at startup
Posted: Fri Dec 15, 2017 4:19 pm
by topguy
Thank in advance
Paolo
I assume you meant "sudo" not "udo" ?
If you only "enabled" it then its not started until next boot or until you do "sudo systemctl start nodered.service.
Posted: Fri Dec 15, 2017 4:26 pm
by paolojo
Yes!
Sorry, I meant "sudo". But unfortunately, it doesn't work at the next boot
Posted: Fri Dec 15, 2017 5:28 pm
by DirkS
Can you post the full output of
sudo systemctl status nodered
Posted: Sat Mar 31, 2018 9:55 pm
by thr
I too have written some nodered code that I would like to auto start when Pi boots.
How do we do this?
FYI my overall plan is to run my Pi in kiosk mode, displaying a nodered dashboard. To do this I need to auto start nodered when my Pi boots.j
Posted: Sun Apr 01, 2018 8:36 pm
by thr
Bump.
I would like to know how to start nodered on startup.
My plan is to boot my Pi to kiosk mode and open a browser that will display a nodered dashboard, with the nodered app running on my Pi in the background.
Posted: Sun Apr 01, 2018 9:10 pm
by topguy
The question asked by DirkS needs answering.
We need to know the status of the node-red service.
Posted: Sun Apr 01, 2018 9:58 pm
by mattmiller
I've got a old 8.0 Jessie install (PiZero o vanilla - only had a single python prog on it) that I upgraded to v0.18.4 that I updated yesterday using the curl script here
https://nodered.org/docs/hardware/raspberrypi
to change from python prog to a node-RED one
It was all working fine so to check out your problem I did
sudo systemctl enable nodered.service
then
and tested it was working
then I rebooted and its automatically loaded following reboot
