MickTheGeek3
Julia Programming Lang. Installation On Pi 3
Tue Dec 12, 2017 3:27 pm
Good Day. My name is Mike and I need some help installing the Julia programming language on my Raspberry Pi 3. The Pi is running the latest version of Raspian Stretch. Here is the error message I am receiving:
[email protected]:~ $ julia -e 'Pkg.build("IJulia");'
INFO: Building MbedTLS
INFO: Building Conda
INFO: Building ZMQ
INFO: Building IJulia
INFO: Found Jupyter version 5.2.2: jupyter
INFO: Installing Julia kernelspec julia-0.6
=================================[ ERROR: IJulia ]=================================
LoadError: could not spawn `jupyter-kernelspec install --replace --user /tmp/julia-0.6`: no such file or directory (ENOENT)
while loading /home/pi/.julia/v0.6/IJulia/deps/build.jl, in expression starting on line 103
=================================[ BUILD ERRORS ]==================================
WARNING: IJulia had build errors.
- packages with build errors remain installed in /home/pi/.julia/v0.6
- build the package(s) and all dependencies with `Pkg.build("IJulia")`
- build a single package by running its `deps/build.jl` script
If anyone has a solution to this issue, please let me know. Thanks for the help.
/Mike Biel
Re: Julia Programming Lang. Installation On Pi 3
Tue Dec 12, 2017 6:33 pm
INFO: Building ZMQ
/Mike Biel
You do not state what guide you are following, but this is the Official Blog:
https://www.raspberrypi.org/blog/julia- ... pberry-pi/
adieu
My other Computer is an Asus CS10 ChromeBit
MickTheGeek3
Wed Dec 13, 2017 4:36 pm
The guide I followed is the official Raspberry Pi Blog post.
/Mike Biel
DirkS
Wed Dec 13, 2017 4:45 pm
/Mike Biel
Did the step before that run without errors?
sudo pip3 install jupyter
You could try to run that again to see if it's installed properly
