MickTheGeek3
Julia Programming Lang. Installation On Pi 3
Tue Dec 12, 2017 3:27 pm
Good Day. My name is Mike and I need some help installing the Julia programming language on my Raspberry Pi 3. The Pi is running the latest version of Raspian Stretch. Here is the error message I am receiving:
[email protected]:~ $ julia -e 'Pkg.build("IJulia");'
INFO: Building MbedTLS
INFO: Building Conda
INFO: Building ZMQ
INFO: Building IJulia
INFO: Found Jupyter version 5.2.2: jupyter
INFO: Installing Julia kernelspec julia-0.6
=================================[ ERROR: IJulia ]=================================
LoadError: could not spawn `jupyter-kernelspec install --replace --user /tmp/julia-0.6`: no such file or directory (ENOENT)
while loading /home/pi/.julia/v0.6/IJulia/deps/build.jl, in expression starting on line 103
=================================[ BUILD ERRORS ]==================================
WARNING: IJulia had build errors.
- packages with build errors remain installed in /home/pi/.julia/v0.6
- build the package(s) and all dependencies with `Pkg.build("IJulia")`
- build a single package by running its `deps/build.jl` script
If anyone has a solution to this issue, please let me know. Thanks for the help.
/Mike Biel
Re: Julia Programming Lang. Installation On Pi 3
Tue Dec 12, 2017 6:33 pm
INFO: Building ZMQ
/Mike Biel
You do not state what guide you are following, but this is the Official Blog:
https://www.raspberrypi.org/blog/julia- ... pberry-pi/
Adieu
MickTheGeek3
Wed Dec 13, 2017 4:36 pm
The guide I followed is the official Raspberry Pi Blog post.
/Mike Biel
DirkS
Wed Dec 13, 2017 4:45 pm
/Mike Biel
Did the step before that run without errors?
sudo pip3 install jupyter
You could try to run that again to see if it's installed properly
Who is online
Users browsing this forum: No registered users and 2 guests
