Toontje
Compiling Ruby 2.4.1 from source
Sun Apr 16, 2017 8:07 am
takes a day or so on a Raspberry Pi 1 Model B.... Should be in the raspbian repos, IMHO.
Re: Compiling Ruby 2.4.1 from source
Sun Apr 16, 2017 8:19 am
There is a version of Ruby in the repo.
Jessie has 1.9.1
Stretch has 2.3.3
It's ancient history because of the way DebIan does their package management.
Toontje
Sun Apr 16, 2017 8:25 am
Yeah but i need 2.4.1. Trying to build this on my old Pi.
Sun Apr 16, 2017 8:32 am
Won't ever happen with DebIan/Raspbian before DebIan Buster (the one after Stretch) comes out.
You may be able to find a Ubuntu armhf package for Ruby that you can install on Raspbian.
Martin Frezman
Sun Apr 16, 2017 8:51 am
There's really nothing out of the ordinary here.
As noted, Debian is conservative w.r.t. keeping up with the latest versions of things. The usual antidote to this conservatism is "If you want it, build it yourself". As you have done, this is what most people do.
Alternatively, you could install Arch Linux on another SD card. Arch is like the diametric opposite of Debian; they always have the latest-and-greatest, bleeding-edge versions of things. Then, once you have it running on Arch, you could probably copy it from there back to Raspbian. If you're lucky, it might actually all work(!).
If this post appears in the wrong forums category, my apologies.
Toontje
Sun Apr 16, 2017 9:03 am
installing default gems:      /usr/local/lib/ruby/gems/2.4.0 (build_info, cache, doc, extensions, gems, specifications)
                              bigdecimal 1.3.0
                              io-console 0.4.6
                              json 2.0.2
                              openssl 2.0.3
                              psych 2.2.2
                              rdoc 5.0.0
installing bundle gems:       /usr/local/lib/ruby/gems/2.4.0 (build_info, cache, doc, extensions, gems, specifications)
                              did_you_mean 1.1.0
                              power_assert 0.4.1
                              test-unit 3.2.3
                              net-telnet 0.1.1
                              xmlrpc 0.2.1
                              rake 12.0.0
                              minitest 5.10.1
installing rdoc:              /usr/local/share/ri/2.4.0/system
installing capi-docs:         /usr/local/share/doc/ruby
pi@pi:~/ruby-2.4.1 $ ruby -v
ruby 2.4.1p111 (2017-03-22 revision 58053) [armv6l-linux-eabihf]
:D
E3V3A
Wed Apr 04, 2018 5:07 pm
Great!!
How did you go about it? how long did it take?
I simply DK why the rpieple doesn't keep their binaries updated or at least available to people for download with rvm.
Wed Apr 04, 2018 5:18 pm
Great!!
You are responding to an out of date Raspbian Jessie post, Jessie is end of life !!
The majority of Raspbian Stretch is just a re-spin of Debian Stretch ARMHF.
If you want Ruby 2.5.x rather than 2.3.x, just point your sources at Buster, install Ruby, then change sources back to Stretch..
..obviously make a full back up first.
