Raspberry Pi 3 headset bluetooth connection
Posted: Thu Dec 15, 2016 6:09 pm
by scale93
Hi guys, I have just read some post about the connection of a bluetooth headset (microphone and speaker), but i still have a lots of problems, i try to connect an USB microphone and it work, i can see it inside pulseaudio as a microphone. instead if i try to connect a Bluetooth headset it is visible inside pulse audio but it doesn't work as a microphone, it work only as a speaker.
Please help me!! ToT
Re: Raspberry Pi 3 headset bluetooth connection
Posted: Thu Dec 15, 2016 6:46 pm
by Douglas6
For a headset, you'll need to configure the Pi for HSP/HFP. I've never seen that done on a Pi. At minimum, it would require installing ofono and/or upgrading PulseAudio, I believe.
Posted: Fri Dec 16, 2016 10:40 am
by youness
You can find a sum up of the situation in this post:
http://youness.net/raspberry-pi/bluetoo ... spberry-pi
As soon as a working solution will be fined I'll post it, for the moment I didn't anyone did it.
Posted: Thu Feb 08, 2018 2:25 pm
by youness
