I'm getting the following after running `sudo apt-get -f dist-upgrade'
debconf: Perl may be unconfigured (Can't locate warnings/register.pm in @INC (you may need to install the warnings::register module) (@INC contains: /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabihf/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl .) at /usr/share/perl/5.20/vars.pm line 7.
BEGIN failed--compilation aborted at /usr/share/perl/5.20/vars.pm line 7.
Compilation failed in require at /usr/share/perl/5.20/base.pm line 4.
BEGIN failed--compilation aborted at /usr/share/perl/5.20/base.pm line 4.
Compilation failed in require at /usr/share/perl5/Debconf/Log.pm line 7.
BEGIN failed--compilation aborted at /usr/share/perl5/Debconf/Log.pm line 7.
Compilation failed in require at (eval 1) line 4.
BEGIN failed--compilation aborted at (eval 1) line 4.
) -- aborting
(Reading database ... 122197 files and directories currently installed.)
Preparing to unpack .../libc6_2.19-18+deb8u6_armhf.deb ...
Compilation failed in require at /usr/share/perl5/Debconf/Db.pm line 7.
BEGIN failed--compilation aborted at /usr/share/perl5/Debconf/Db.pm line 7.
Compilation failed in require at /usr/share/debconf/frontend line 6.
BEGIN failed--compilation aborted at /usr/share/debconf/frontend line 6.
dpkg: error processing archive /var/cache/apt/archives/libc6_2.19-18+deb8u6_armhf.deb (--unpack):
subprocess new pre-installation script returned error exit status 2
I am unable to use apt at all without getting this error. I can't even launch a CPAN shell. Anyone know how to correct this?
