wadesaunders
DMX Controller
Mon Aug 08, 2016 12:48 pm
Hey guys so basically what I want to do is send commands to my Pi and have my Pi respond by sending DMX commands through a USB to DMX converter. (Hope I've worded that correctly but you get the idea) I want to set up a bunch of presets for some RGB lights and basically tell the Pi which preset to use.
karrika
Re: DMX Controller
Mon Aug 08, 2016 5:51 pm
Welcome to the club. If you have an USB - DMX dongle already it probably works out of the box with OLA or QLC+. There is also card using the UART to generate DMX directly like http://www.discohat.com
wadesaunders
Re: DMX Controller
Tue Aug 09, 2016 3:16 pm
I have no issue with controlling them that way but I'd like to know if I could control them via terminal or something, I'm training in crestron programming and would like my crestron controller to send commands to the Pi which controls the lights
karrika
Re: DMX Controller
Tue Aug 09, 2016 6:44 pm
You can control the lights by several remote techniques. I am using OSC for triggering scenes. But my understanding is that you can use OSC also to send values to the channels.
#!/usr/bin/env python
import liblo, sys
# send all messages to port 7770 on the local machine
try:
    target = liblo.Address(7770)
except liblo.AddressError, err:
    print str(err)
    sys.exit()
# send message "/foo/message1" with int, float and string arguments
liblo.send(target, "/foo/message1", 1)
The idea is that an universe can have one input function like GPIO pins or OSC and one output function like DMX. It is then up to you to do the mapping from the input function to the lights you have purchased.
Arjan
Re: DMX Controller
Mon Jul 31, 2017 7:55 pm
Raspberry Pi Art-Net 3 (Wifi) ->DMX Out / RDM Controller / Pixel controller [Plug & Play]
http://www.raspberrypi-dmx.org/raspberr ... et-dmx-out
Raspberry Pi RDM Responder / Pixel controller [Plug & Play]
http://www.raspberrypi-dmx.org/raspberr ... -responder
Raspberry Pi OSC (Wifi) / Pixel controller [Plug & Play]
http://www.raspberrypi-dmx.org/raspberr ... spi-bridge
Open Source DMX/RDM/MIDI/OSC/Art-Net/sACN solutions
Return to “Other languages”
Who is online
Users browsing this forum: No registered users and 7 guests
