Installing JDK 7u6 on Raspian soft-float ABI
Posted: Sat Aug 18, 2012 9:01 pm
by step1041
I was wondering if anyone had any instructions for getting it installed properly, I have been working at it for a couple of hours now with no success.
I made sure to use a fresh copy of Raspian with the soft-float ABI, which is supported by the Oracle JDK 7u6.
Re: Installing JDK 7u6 on Raspian soft-float ABI
Posted: Sun Aug 19, 2012 10:05 pm
by elatllat
why not just use:
apt-get intall openjdk-7-jdk
Posted: Mon Aug 20, 2012 6:37 am
by fruitloaf
What are you having a problem with? It was pretty much extract and go for me.
Posted: Wed Aug 22, 2012 6:30 am
by savageautomate
Here is a blog post with detailed instructions on how to install the Oracle JRE on the Debian Squeeze and Debian Wheezy builds for your Raspberry Pi:
http://www.savagehomeautomation.com/pro ... t-jre.html
Good Luck!
-Robert
Posted: Wed Aug 22, 2012 6:36 am
by savageautomate
This apt-get command will install the Open JDK, not the Oracle JRE.
This is perfectly fine for simple Java programs, but its performance is pretty limited and the Oracle JRE runs about twice as fast when compared against the Open JDK using the cacao VM option.
See chrisg's benchmark results in this post for a comparison:
http://www.raspberrypi.org/phpBB3/viewt ... =34&t=6369
Posted: Sat Aug 25, 2012 8:46 pm
by savageautomate
New article with step-by-step instructions on how to install the new Oracle JDK on your Raspberry Pi.
http://www.savagehomeautomation.com/pro ... -170u.html
Posted: Sat Aug 25, 2012 9:49 pm
by step1041
savageautomate wrote:New article with step-by-step instructions on how to install the new Oracle JDK on your Raspberry Pi.
Thanks Robert!
That post is exactly what I was looking for. Hopefully others will see it and learn to get Java running on their Pi.
