pauljt
linux command chmod
Wed Apr 13, 2016 11:46 pm
when I try to change permissions on the "etc" file I get the reply:
chmod: changing permissions of etc : operation not permitted
I need to add a line to the etc file to enable an add-on lcd screen
is it possible to change the permissions ?
Dutch_Master
Re: linux command chmod
Thu Apr 14, 2016 12:14 am
Use the sudo command. Read up on it with
man sudo
HTH!
MarkHaysHarris777
Thu Apr 14, 2016 2:08 am
pauljt wrote:when I try to change permissions on the "etc" file I get the reply:
Whoa there sundance... etc is a directory (folder) not a file. You don't edit /etc .
You might edit something in /etc like:
gksudo nano /etc/hosts
or
sudo vi /etc/hosts
This is /etc
drwxr-xr-x root root
The d :roll: above stands for 'directory' ... this says that root is the owner with read,write, execute permissions.
This is hosts:
-rw-r--r-- root root ... this says that root (the owner) has read,write permissions (the d is missing)
The hosts file is a 'file' the /etc entry is a 'directory'
(be careful editing system files until you know what you are doing... its dangerous)
marcus
:ugeek:
Thu Apr 14, 2016 5:21 am
Yes, unless you have very good reason it's a bad idea to go around changing permissions on system files on your Unix/Linux systems. That is pretty much anything not in your home directory.
