ukscone
Clozure CL
Sat Jul 28, 2012 12:10 am
just got tweeted [@ukscone have you seen http://clozure.com/pipermail/openmcl-de ... 13677.html … - clozure cl now runs on raspi] by a friend that ClozureCL now works on ARM devices and has been tested on the Raspberry PI :) yay http://clozure.com/pipermail/openmcl-de ... 13677.html
Attribute Section: aeabi
File Attributes
Tag_CPU_name: "6"
Tag_CPU_arch: v6
Tag_ARM_ISA_use: Yes
Tag_THUMB_ISA_use: Thumb-1
Tag_FP_arch: VFPv2
Tag_ABI_PCS_wchar_t: 4
Tag_ABI_FP_denormal: Needed
Tag_ABI_FP_exceptions: Needed
Tag_ABI_FP_number_model: IEEE 754
Tag_ABI_align_needed: 8-byte
Tag_ABI_enum_size: int
Tag_ABI_HardFP_use: SP and DP
Tag_ABI_VFP_args: VFP registers
Tag_DIV_use: Not allowed
pi@welham ~/ccl $ ./armcl
Welcome to Clozure Common Lisp Version 1.9-dev-r15424M-trunk (LinuxARM32)!
if you want to build it yourself then you'll need to pull the trunk
svn co http://svn.clozure.com/publicsvn/openmc ... nuxarm/ccl
antiloquax
Re: Clozure CL
Thu Aug 02, 2012 1:43 pm
It's good to know that :)
I am just starting to learn a bit of Scheme. I tend to use Guile and MIT-Scheme at the mo, but I will try clozure out at some point!
thanks,
mark
