qkoots
install rails gem
Fri Aug 28, 2015 8:55 pm
I have been trying to install the "rails gem" the whole day but without any result!
I get this error:
Error: While executing gem.. (ArgumentError)
marshal data too short
What can I do? I did everything in this post but no result :
viewtopic.php?f=34&t=72858&p=530762&hil ... rt#p530762
Thank you !
atmosx
Re: install rails gem
Tue Sep 08, 2015 9:49 pm
Remove ruby installation from you RPi and install ruby and rails via rvm using the following command:
\curl -sSL https://get.rvm.io | bash -s stable --rails
Everything should be fine.
