[email protected]
Perl: Use of uninitialized value $path
Tue Jul 17, 2012 4:35 pm
Hi
I have been stuck on this for days and cannot figure out what is wrong. Whenever I try to install any Perl module I get multiple errors. I am doing the following:
sudo perl -MCPAN -e shell
install XML::Parser
Everything is retrieved from the web fine and then it starts the build process. Then I get hundreds of these messages, two lines repeated:
Use of uninitialized value $_[0] in join or string at /usr/share/perl/5.10/File/Spec/Unix.pm line 41.
Use of uninitialized value $path in pattern match (m//) at /usr/share/perl/5.10/File/Spec/Unix.pm line 121.
Eventually it shows:
CPAN: File::Temp loaded ok (v0.22)
  CPAN.pm: Going to build T/TO/TODDR/XML-Parser-2.41.tar.gz
Warning: No success on command[/usr/bin/perl Makefile.PL INSTALLDIRS=site]
Warning (usually harmless): 'YAML' not installed, will not store persistent state
  /usr/bin/perl Makefile.PL INSTALLDIRS=site -- NOT OK
Running make test
  Make had some problems, won't test
Running make install
  Make had some problems, won't install
Could not read '/root/.cpan/build/XML-Parser-2.41-c8FOyX/META.yml'. Falling back to other methods to determine prerequisites
Failed during this command:
 TODDR/XML-Parser-2.41.tar.gz                 : writemakefile NO '/usr/bin/perl Makefile.PL INSTALLDIRS=site' returned status -1
My Pi is built from the standard Debian image and fully updated. I have tried updating CPAN and installing YAML and I get the same errors. Just simply using 'cpan' results in the same errors.
I am using a user account that I added to the Pi, but using the default 'pi' account produces the same messages.
I thought maybe it has to do with the path variable. This is mine:
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
Any ideas? I am surprised no one else has mentioned this already.
Mark
Gibble
Re: Perl: Use of uninitialized value $path
Tue Jul 17, 2012 7:46 pm
I had problems with cpan, too many to persist with, some relating to memory and it locking up. I ended up using cpanminus which seemed to work a lot better anyway than normal for me...I'm not at a Pi atm, but this is what I did on my lappy to get it going, and I think commands will be similar...
sudo apt-get install curl
sudo curl -L http://cpanmin.us | perl - --sudo App::cpanminus
sudo cpanm XML::Parser
Once the first two commands are sorted, you can just use cpanm <package>
The first line just installs curl which allows you to get files remote easy.
[email protected]
Tue Jul 17, 2012 9:26 pm
Thanks for that. I had seen the answer given elsewhere. The install took a very long time to complete, the process must have asked for my password 25 times!
I am afraid to say I get similar errors. After I try: sudo cpanm XML::Parser, I get this:
--> Working on XML::Parser
Fetching http://www.cpan.org/authors/id/T/TO/TODDR/XML-Parser-2.41.tar.gz ... OK
Configuring XML-Parser-2.41 ... OK
Building and testing XML-Parser-2.41 ... FAIL
! Installing XML::Parser failed. See /root/.cpanm/build.log for details
The last few lines of that log file are, that log file is very long btw:
make[1]: *** [Expat.o] Error 1
make[1]: Leaving directory `/root/.cpanm/work/1342559674.6738/XML-Parser-2.41/Expat'
make: *** [subdirs] Error 2
-> FAIL Installing XML::Parser failed. See /root/.cpanm/build.log for details.
A 'sudo ls -l /root/.cpanm/' shows:
-rw-r--r-- 1 root root 55520 Jul 17 22:15 build.log
lrwxrwxrwx 1 root root    33 Jul 17 22:14 latest-build -> /root/.cpanm/work/1342559674.6738
drwxr-xr-x 4 root root  4096 Jul 17 22:14 work
The '/root/.cpanm/work' folder contains many folders with source code.
At the moment I am still looking for an answer.
Mark
Gibble
Wed Jul 18, 2012 11:58 am
make sure you have the expat headers...
sudo apt-get install libexpat1-dev
If it still doesn't work, assuming you have the above, you can
wget http://search.cpan.org/CPAN/authors/id/ ... .36.tar.gz
tar zxvf XML-Parser-2.36.tar.gz
cd XML-Parser-2.36
perl Makefile.PL
make
make install
or something like that
jojopi
Wed Jul 18, 2012 2:59 pm
[email protected] wrote:Use of uninitialized value $_[0] in join or string at /usr/share/perl/5.10/File/Spec/Unix.pm line 41.
These errors go away if you "sudo swapon /dev/mmcblk0p3" before the cpan. So it seems somehow related to running out of memory (and not giving a proper diagnostic).
Is not the best way to install XML::Parser on Debian: "sudo apt-get install libxml-parser-perl" ?
[email protected]
Wed Jul 18, 2012 3:03 pm
Ah, that is interesting.
I accidentally deleted the swap partition when I was resizing the root partition. I will give your suggestions a try later today.
davesedar
Fri Jul 20, 2012 7:58 am
Successfully installed cpanm on Raspberry Pi using clean install of raspbian,
but 'sudo cpanm XML::Parser'
fails to Configure.
/root/.cpanm/build.log contains the line 'Couldn't find your C compiler'
does it actually have one?
davesedar
Fri Jul 20, 2012 8:29 am
ploughing on regardless..
cpanm Math::Trig worked fine
cpanm Time::HiRies failed to find the C compiler
cpanm Device::SerialPort --verbose failed with:
  • checking definition of B2500000... found
    checking definition of B3000000... found
    checking definition of B3500000... found
    checking definition of B4000000... found
    checking serial control via ioctl... yes
    checking read/write of RTS signal... yes
    checking read/write of DTR signal... yes
    checking read access to modem lines... yes
    checking read access to buffer status... yes
    checking read access to serial line status... yes
    checking normal CTS/RTS flow control... yes
    configure: creating ./config.status
    config.status: creating config.h
    Checking if your kit is complete...
    Looks good
    Writing Makefile for Device::SerialPort
    Writing MYMETA.yml
    You're ready to run 'make' now...
    OK
    Checking dependencies from MYMETA.yml ...
    Checking if you have ExtUtils::MakeMaker 0 ... Yes (6.57_05)
    Checking if you have Test::More 0 ... Yes (0.98)
    Building and testing Device-SerialPort-1.04 ... cp SerialPort.pm blib/lib/Device/SerialPort.pm
    /usr/bin/perl /usr/share/perl/5.14/ExtUtils/xsubpp -typemap /usr/share/perl/5.14/ExtUtils/typemap SerialPort.xs > SerialPort.xsc && mv SerialPort.xsc SerialPort.c
    gcc-4.7 -c -I. -D_REENTRANT -D_GNU_SOURCE -DDEBIAN -fstack-protector -fno-strict-aliasing -pipe -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -O2 -g -DVERSION=\"1.04\" -DXS_VERSION=\"1.04\" -fPIC "-I/usr/lib/perl/5.14/CORE" SerialPort.c
    /bin/sh: 1: gcc-4.7: not found
    make: *** [SerialPort.o] Error 127
    FAIL
    ! Installing Device::SerialPort failed. See /home/pi/.cpanm/build.log for details.
Any help appreciated
subogero
Wed Dec 19, 2012 12:35 pm
Don't use CPAN at all. Most known Perl modules are packaged by Raspbian, so install them with apt-get.
The challenge: find out which deb package your module belongs to.
Your module is called XML::Parser, so it's stored as a /usr/.../XML/Parser.pm file.
apt-get install apt-file
apt-file update
apt-file search XML/Parser.pm
And voilá:
libxml-parser-perl: /usr/lib/perl5/XML/Parser.pm
And then:
You're done.
