BakaOsaka
PHP GD problems - Can't solve
Thu Jul 05, 2012 5:38 pm
Hello all.
I have GD installed on my Debian server (sudo apt-get install php5-gd) and it loads images fine, but whenever I try to use a ttf on it, the text doesn't show at all.
Can someone offer me some help?
array ( 'GD Version' => '2.0', 'FreeType Support' => true, 'FreeType Linkage' => 'with freetype', 'T1Lib Support' => true, 'GIF Read Support' => true, 'GIF Create Support' => true, 'JPEG Support' => true, 'PNG Support' => true, 'WBMP Support' => true, 'XPM Support' => false, 'XBM Support' => false, 'JIS-mapped Japanese Font Support' => false, )imagejpeg: true
imagecreatetruecolor: true
imagedestroy: true
imagecolorallocate: true
imagefilledrectangle: true
imagecolorat: true
imagesetpixel: true
imageline: true
imagefontwidth: true
imagettfbbox: true
imagestring: true
imagettftext: true
That's the output of a php test, and shows I have ttf enabled.
gd
GD Support 	enabled
GD Version 	2.0
FreeType Support 	enabled
FreeType Linkage 	with freetype
FreeType Version 	2.4.2
T1Lib Support 	enabled
GIF Read Support 	enabled
GIF Create Support 	enabled
JPEG Support 	enabled
libJPEG Version 	6b
PNG Support 	enabled
libPNG Version 	1.2.44
WBMP Support 	enabled
That's the output of phpinfo.
empire
Re: PHP GD problems - Can't solve
Thu Jul 05, 2012 11:36 pm
Try running this command too:
sudo apt-get install libgd2-xpm
http://rpi-blog.com - Raspberry Pi guides, tips, tricks, and resources :-)
BakaOsaka
Fri Jul 06, 2012 9:32 am
Seems as if it's already installed.
pi@raspberrypi:~$ sudo apt-get install libgd2-xpm
Reading package lists... Done
Building dependency tree
libgd2-xpm is already the newest version.
libgd2-xpm set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 45 not upgraded.
More info:
pi@raspberrypi:~$ php5 -i | grep -i --color gd
Additional .ini files parsed => /etc/php5/cli/conf.d/gd.ini,
gd
GD Support => enabled
GD Version => 2.0
gd.jpeg_ignore_warning => 0 => 0
Pirx-Danford
Fri Jul 06, 2012 10:05 am
Does PHP show any errors?
If not maybe do
ini_set ( 'display_errors' , '1' );
error_reporting ( 'E_ALL' );
at the start of the script.
BakaOsaka
Fri Jul 06, 2012 10:46 am
Oh what? I chmod 755'd all the files in the directory and it seems to work now! Thanks for the help :D
exe888
Thu Jan 10, 2013 7:41 am
I am having this exact ptoblem too...
you chmodded the files in which directory exactly??
(linux newbie)
exe888
Thu Jan 10, 2013 7:42 am
(linux newbie)
MyRevel
Mon Mar 04, 2013 6:23 pm
I had the same problem.
My problem was solved after adding the php code:
// Set the enviroment variable for GD
putenv('GDFONTPATH=' . realpath('.'));
I found this solution in the description of the imagettftext(), see http://www.php.net/manual/en/function.imagettftext.php
RootShell
Mon Mar 25, 2013 11:54 pm
You could also copy the used font to the same directory as the php file :)
