DaveSemm
Which Node.js?
Wed Mar 04, 2015 6:36 pm
I recently discovered that node.js might be perfect for what I am trying to do (after struggling with python for a while), and decided to try it out. The problem is which one? Adafruit says this is how you install it:
wget http://node-arm.herokuapp.com/node_latest_armhf.deb
nodewiz says this is how:
sudo apt-get install nodejs npm
Their sample apps are different.
I'm assuming these are 2 different implementations. Which should I be using? I am setting up web services and web sites on several Pi's that let me control stuff.
Re: Which Node.js?
Wed Mar 04, 2015 6:44 pm
In my experience the version you get from "apt-get install ...." is way old. node has been changing very fast. Example codes may be different because the application interface to node has changed on occasion.
Certainly you no longer have to install npm separately, it come built in with node.
Luckily the node guys have been providing more recent versions for the Pi. Like node-v0.11.11-linux-arm-pi.tar.gz available here: http://nodejs.org/dist/v0.11.11/
If you poke around in those dist directories you may find a newer version.
Should be good to go, works for me.
Re: Which Node.js?
Wed Mar 04, 2015 6:50 pm
On a Raspberry Pi 2B use
curl -sL https://deb.nodesource.com/setup | sudo bash -
sudo apt-get install -y build-essential python-dev python-rpi.gpio nodejs
On a Raspberry Pi A/B/B+/A+ use
wget http://node-arm.herokuapp.com/node_0.10.36_armhf.deb
sudo dpkg -i node_0.10.36_armhf.deb
sudo apt-get install build-essential python-dev python-rpi.gpio
Note:Having anything remotely humorous in your signature is completely banned on this forum.
DaveSemm
Re: Which Node.js?
Thu Mar 05, 2015 5:03 am
Thanks! I hope to be less of a node.js newbie by the weekend.Thanks to the adafruit article, I started flashing LEDs in no time. I hope to remote control the whole house by the time I'm done.
I see now there is an application framework called express that I'll also look into.
Also, there are apparently a few forks of node.js (io.js?). Are there any problems with node.js that I should know about?
Re: Which Node.js?
Thu Mar 05, 2015 4:52 pm
You don't need to worry about io.js.
Some guys forked node.js into io.js so they could move development along more quickly. Hopefully with time those developments will merge back into node.js.
If you want a stable system go with node.js.
rnbwd
Re: Which Node.js?
Fri Mar 20, 2015 8:49 pm
Actually, iojs is currently the best option for raspberry pi - https://iojs.org. They run tests every release for armv6-raspbian-wheezy - https://jenkins-iojs.nodesource.com/job ... multi/349/ - The most recent version that works with armv6 is (v1.5.1) https://iojs.org/dist/v1.5.1/ (I'm not sure why the current build is failing on armv6) - but at least you know what works.
There's a disscustion here about using iojs on rpi2 - https://github.com/iojs/io.js/issues/1105
Also check out the roadmap: http://roadmap.iojs.org/
r3d4
Re: Which Node.js?
Sat Mar 21, 2015 8:32 am
Take a look at ./n ...
#https://github.com/tj/n/blob/master/bin/n - Simple flavour of node/iojs binary management.
xinad
Re: Which Node.js?
Wed Apr 01, 2015 9:36 pm
I use io.js 1.6.2 actually on Minibian.
Node modules which I use:
onoff, express, dot, async, body-parser, js-yaml, morgan, mocha, nodeunit
[email protected]:~# node -v
v1.6.2
[email protected]:~# iojs -v
v1.6.2
[email protected]:~# npm -v
2.7.1
[email protected]:~# cat /proc/version
Linux version 3.18.10-v7+ ([email protected]) (gcc version 4.8.3 20140303 (prerelease) (crosstool-NG linaro-1.13.1+bzr2650 - Linaro GCC 2014.03) ) #774 SMP PREEMPT Wed Mar 25 14:10:30 GMT 2015
colinmower
Re: Which Node.js?
Sun May 31, 2015 7:24 pm
Hi all
I've been following the instructions to install Node-RED on my RPi B+, but am failing during install. I have gone back to the beginning and think it could be down to some missing Node.js files...see error below. This is the final command as per Dougie's instructions in the install process - the other two worked successfully.
Does anyone know if I should be using a different command or if the files have moved somewhere else please?
Colin
*************** Output from command *******************
[email protected] ~ $ sudo apt-get install build-essential python-dev python-rpi.gpio
Reading package lists... Done
Building dependency tree
build-essential is already the newest version.
python-rpi.gpio is already the newest version.
The following package was automatically installed and is no longer required:
libgail-3-0
Use 'apt-get autoremove' to remove it.
The following extra packages will be installed:
libexpat1-dev libssl-dev libssl-doc python2.7-dev
The following NEW packages will be installed:
libexpat1-dev libssl-dev libssl-doc python-dev python2.7-dev
0 upgraded, 5 newly installed, 0 to remove and 0 not upgraded.
Need to get 2,709 kB/31.6 MB of archives.
After this operation, 42.2 MB of additional disk space will be used.
Do you want to continue [Y/n]? Y
Err http://mirrordirector.raspbian.org/raspbian/ wheezy/main libssl-dev armhf 1.0.1e-2+rvt+deb7u13
404 Not Found
Err http://mirrordirector.raspbian.org/raspbian/ wheezy/main libssl-doc all 1.0.1e-2+rvt+deb7u13
404 Not Found
Failed to fetch http://mirrordirector.raspbian.org/rasp ... _armhf.deb 404 Not Found
Failed to fetch http://mirrordirector.raspbian.org/rasp ... 13_all.deb 404 Not Found
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Re: Which Node.js?
Sun May 31, 2015 9:15 pm
rnbwd,
Wow, you are right. io.js is taking good care of the raspi and racing ahead of developments.
I was nervous though that it may be so far ahead that lot's of useful modules are broken for it. Basically just worrying about advising anything other than the stability of node.js itself.
seulater
Re: Which Node.js?
Mon Dec 07, 2015 1:10 pm
DougieLawson wrote:On a Raspberry Pi 2B use
Thanks for the instructions, but might you have the time to clarify some things for me.
I am trying this on a Pi Zero. I am confused on a couple things
#1) I see on Node.js site the latest is 5.1.1. Why is it suggested to get it from an alternate place such as wget http://node-arm.herokuapp.com/node_0.10.36_armhf.deb ?
#2) Cannot we just grab the source from https://nodejs.org/dist/latest/ and use that ?
Thank you
Re: Which Node.js?
Mon Dec 07, 2015 4:44 pm
I got those instructions from the NodeRED website.
NodeRED is now included with the very latest 2015-11-21 Jessie so there MUST be a version of Node.JS already installed.
Get new Jessie and do nothing more.
[email protected] ~ # which node
/usr/bin/node
[email protected] ~ # node -v
v0.10.29
Re: Which Node.js?
Mon Dec 07, 2015 7:25 pm
seulater,
I am currently using a package from https://nodejs.org/dist/....
It's version 5 point something. Whatever was latest at the time. Works very well.
You might have to be careful to get the arm6 or arm7 package depending on what PI you have.
If Raspbian Jessie is installing node version 0.10.29 then that is well out of date and only of historical interest.
By the way, that is not the source you get from https://nodejs.org/dist/ but the runnable binary.
r3d4
Re: Which Node.js?
Mon Dec 07, 2015 9:53 pm
DougieLawson wrote:NodeRED is now included with the very latest 2015-11-21 Jessie so there MUST be a version of Node.JS already installed.
Unless
you expect to use anything that might depend on a "native add-on" ...........
fivdi wrote: The variant of Node.js v0.10.29 that comes preinstalled with Raspbian Jessie 2015-11-21 is broken. It's not possible to install Node.js native add-ons with this variant of Node.js.
viewtopic.php?f=66&t=127939
joan
Re: Which Node.js?
Mon Dec 07, 2015 10:04 pm
Unless
you expect to use " native add-ons" ...........
If you want to stick to the standard repositories you would need to update to Raspbian testing. That has nodejs at version 4.2.2 which supports native add-ons. Of course moving to Raspbian testing is not something to be undertaken lightly.
seulater
Re: Which Node.js?
Mon Dec 07, 2015 10:33 pm
Thanks guys. What I wound up doing was this, and so far all works well on the Zero.
wget https://nodejs.org/dist/latest/node-v5.1.1-linux-armv6l.tar.gz
tar -xvf https://nodejs.org/dist/latest/node-v5.1.1-linux-armv6l.tar.gz
cd node-v5.1.1-linux-armv6l/
sudo cp -R * /usr/local/
callahanp
Contact: Facebook Google+ Skype
Re: Which Node.js?
Tue May 17, 2016 10:02 pm
I tried 5.1.1, 6.1 and 0.10.29 and got errors trying the example code for rpi-gpio.
sudo node example.js
/home/pi/node_modules/rpi-gpio/rpi-gpio.js:329
return currentPins[channel] + '';
TypeError: Cannot read property '11' of undefined
at getPinRpi (/home/pi/node_modules/rpi-gpio/rpi-gpio.js:329:27)
at Gpio.write.output (/home/pi/node_modules/rpi-gpio/rpi-gpio.js:222:19)
at write (/home/pi/experimental/node-example/example.js:11:10)
at Object.<anonymous> (/home/pi/experimental/node-example/example.js:17:1)
at Module._compile (module.js:413:34)
at Object.Module._extensions..js (module.js:422:10)
at Module.load (module.js:357:32)
at Function.Module._load (module.js:314:12)
at Function.Module.runMain (module.js:447:10)
at startup (node.js:148:18)
asandford
Re: Which Node.js?
Tue May 17, 2016 10:08 pm
callahanp wrote:I tried 5.1.1, 6.1 and 0.10.29 and got errors trying the example code for rpi-gpio.
You may need to provide a bit more information as to what you want to achieve
Re: Which Node.js?
Wed May 18, 2016 11:50 am
callahanp,
What did you actually do? Show us the code in your example.js.
All seems to work fine here.
I like to live dangerously so I just grab the latest node version from node.js.org See here:
https://nodejs.org/en/download/releases/
So for example I do this:
$ cd /usr/local/
$ sudo wget https://nodejs.org/download/release/v6.2.0/node-v6.2.0-linux-armv7l.tar.gz
$ sudo tar --strip-components=1 -xvf node-v6.2.0-linux-armv7l.tar.gz
$ node -v
v6.2.0
Now let's try rpi-gpio...
$ cd
$ mkdir temp
$ cd temp/
$ npm install rpi-gpio
Create a file containing the first two examples from the rpi-gpio pages like so:
'use strict';
var gpio = require('rpi-gpio');
gpio.setup(7, gpio.DIR_IN, readInput);
function readInput() {
    gpio.read(7, function(err, value) {
        console.log('The value is ' + value);
gpio.setup(8, gpio.DIR_OUT, write);
function write() {
    gpio.write(8, true, function(err) {
        if (err) throw err;
        console.log('Written to pin');
And run it:
$ sudo node temp.js
Written to pin
The value is true
Seems to work just fine.
Personally I prefer pigpio https://www.npmjs.com/package/pigpio
I would not use the nodejs that is packaged in Raspbian, it's ancient.
joerg.hampel
Re: Which Node.js?
Mon Sep 19, 2016 1:06 pm
I'm experiencing the same problems when trying to call a function containing the gpio.write() function from setInterval. Somehow, the scope is messed up so that I end up with:
webic-root-0 TypeError: Cannot read property '16' of undefined
webic-root-0     at getPinRpi (/var/local/webic/node_modules/rpi-gpio/rpi-gpio.js:329:27)
webic-root-0     at Gpio.write.output (/var/local/webic/node_modules/rpi-gpio/rpi-gpio.js:222:19)
webic-root-0     at setLed (/var/local/webic/webic-root/webic-root.js:198:8)
webic-root-0     at blinkYellowLed [as _repeat] (/var/local/webic/webic-root/webic-root.js:207:3)
webic-root-0     at wrapper [as _onTimeout] (timers.js:275:11)
webic-root-0     at Timer.listOnTimeout (timers.js:92:15)
When calling the very same function setLed() directly or from a socket event everything works as expected. This is the (I think) relevant part of my code:
var ledState;
function getPinNumber(name) {
  switch(name){
    case "yellow":
      return configuration.yellowPin;
    case "red":
      return configuration.redPin;
  return 0;
function setLed(data) {
  var pinNumber = getPinNumber(data.Color);
  if(pinNumber != 0) {
    gpio.write(pinNumber, data.State, function(err) {
      if (err) throw err;
      console.log('Set!');
function blinkYellowLed() {
  ledState = !ledState;
  setLed({ "Color": "yellow", "State": ledState });
var ledIntval = setInterval(blinkYellowLed, 500);
I understand that I'm having trouble with the scope, but I cannot work out how to fix this.
Thanks in advance for any help!
Re: Which Node.js?
Mon Sep 19, 2016 5:12 pm
joerg,
Your scope is just fine.
The problem is you don't setup the pin for output. When I add that your code runs just fine. As shown below.
See rpi-gpio instructions "Setup and read the value of a pin" here: https://www.npmjs.com/package/rpi-gpio
I have a feeling pigpio is easier to use https://www.npmjs.com/package/pigpio
'use strict';
let gpio = require('rpi-gpio');
let ledState = false;
//  Set up pin and write intial value
gpio.setup(16, gpio.DIR_OUT, () => {
    gpio.write(16, ledState, (err) => {
        if (err) throw err;
        console.log(`Pin 16 initialize to ${ledState}`);
let configuration = {
    yellowPin: 16,
    redPin: 17
    switch (name) {
    case 'yellow':
    case 'red':
    return 0;
    if (pinNumber !== 0) {
            if (err) throw err;
                console.log('Set!', pinNumber, data.State);
    setLed({'Color': 'yellow', 'State': ledState});
[email protected]:~$ node -v
v6.3.1
[email protected]:~$ sudo node index.js
Pin 16 initialize to false
Set! 16 true
Set! 16 false
Set! 16 true
Set! 16 false
Set! 16 true
Set! 16 false
Set! 16 true
joerg.hampel
Re: Which Node.js?
Thu Sep 22, 2016 1:36 pm
@heater, you are a beauty!
I had left out the setup in the "(I think) relevant part of my code". So, I had already implemented the setup function. I think that it was the 'use strict' together with 'let' that made the difference.
One thing that cost me some time: I was so into testing that I forgot to run node with root rights (otherwise the GPIOs cannot be accessed). Only when I threw the error not only when writing, but also in the setup function did I see what was going wrong:
gpio.setup(16, gpio.DIR_OUT, (err) => {
  if (err) throw err;
    gpio.write(16, false, (err) => {
        if (err) throw err;
        // do something project-specific here...
However, it works no. Thanks a lot!
pi2r2
Re: Which Node.js?
Thu Sep 22, 2016 2:54 pm
From experience, this is most reliable way to install nodejs: https://github.com/creationix/nvm
Re: Which Node.js?
Thu Sep 22, 2016 4:48 pm
Yes, nvm is a wonderful thing.
Re: Which Node.js?
Mon Oct 30, 2017 7:05 pm
I already reported that last post as SPAM.
But really, when we hire developers for JS we expect that they actually have some idea of computer science or at least programming and have more on their CV than just experience the latest flavor of the month JS library or framework.
