HerpaMoTeH
C# Modbus RTU problem
Mon Nov 05, 2012 9:42 am
Hi guys,
I have the following problem. When I try to connect to a USB to serial Converter the Rpi freezes. The library I'm using is nmodbus. Has someone been able to connect with a Modbus rtu device and if yes using what library?
HerpaMoTeH
Re: C# Modbus RTU problem
Mon Nov 05, 2012 11:57 am
After some tests I found out that the Rpi freezes when you try to connect to the USB converter.
rickthenick
Fri Nov 09, 2012 1:22 am
Yes, I am using libmodbus-3.0.3 with raspbian and FTDI USB-RS485 Cable.
It works fine, but there is something wrong with the USB driver that hangs thi pi. You can read more about this on http://www.raspberrypi.org/phpBB3/viewt ... 0&p=210013
HerpaMoTeH
Fri Nov 09, 2012 6:58 am
Edit: The problem doesn't seem to be the power consumption of the converter, since it only draws 20 to 25 mA from the USB.
Return to “Other languages”
Who is online
Users browsing this forum: No registered users and 2 guests
