honey
Solved installing vscode apt is for pi4
Thu Jul 22, 2021 4:04 pm
Im install the vscode in my raspaberry pi b+ using apt , but the it give an error
Invalid instrution , im undering if its possible to rebuild the pack vbcode from this side
https://github.com/microsoft/vscode wat is the executable under debian?
Re: Installing vscode apt is for pi4
Thu Jul 22, 2021 4:19 pm
removed response not helpful....
Last edited by fruitoftheloom on Tue Jul 27, 2021 10:22 am, edited 1 time in total.
Take what I advise as advice not the utopian holy grail, and it is gratis !!
honey
Mon Jul 26, 2021 5:55 pm
Thanks any way
craigevil
Mon Jul 26, 2021 9:35 pm
https://code.visualstudio.com/docs/setup/raspberry-pi
System requirements#
VS Code is supported on these Raspberry Pi models running a 32-bit or 64-bit version of Raspberry Pi OS:
Raspberry Pi 3 Model B/B+
Raspberry Pi 4 Model B
Raspberry Pi 400
While 1 GB of memory (RAM) meets the minimum system requirements, users will benefit from installing VS Code on a Raspberry Pi 4 with more memory.
First-generation Raspberry Pi modules and Raspberry Pi Zero are not supported as they only include an ARMv6 CPU.
Raspberry PI 400 Raspberry Pi OS (Debian Bookworm/sid) Kernel: 5.10.63-v8+ aarch64 DE: MATE Ram 4GB
Debian - "If you can't apt install something, it isn't useful or doesn't exist"
honey
Sun Aug 01, 2021 9:24 pm
Im as hope you help me to compile from the zero all the code ;to bypass the out of instrution is miss out :)
Im see is not possible thanks any way :)
Im give up im waiting microsoft build a more advencing code :)
ejolson
Sun Aug 01, 2021 11:49 pm
The vscode source repository
https://github.com/Microsoft/vscode/wik ... Contribute
recommends node-js 14.x while the last stable ARMv6 binaries at
https://nodejs.org/dist/
are for node-js 10.x, see also
https://nodejs.org/en/about/releases/
This suggests recent versions of node-js are too fashionable to run on the Pi Zero. As a result, it appears the needed tools for vscode are not available.
While one might have thought open source that once ran on a particular architecture would continue to do so, the fact that it often doesn't is sometimes called bit rot. If developing a program to run on the Pi Zero, my recommendation would be to use the full version of vim
$ sudo apt-get install vim
and write the program in C. In my opinion, the C development tool chain for the Zero is unlikely to rot anytime soon.
There may be a way to use vscode on the Zero. I just don't know how. It would be nice to hear if someone else managed.
honey
Wed Aug 04, 2021 10:35 am
