sandysound
A question about mariadb logging and more
Mon Apr 19, 2021 9:56 pm
I have a script, that turns a pump on and off depending on the water level of the reservoir:
#!/usr/bin/env python3
#XKC-Y25-PNP Non Contact Water Level Sensor
from time import sleep
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(23, GPIO.IN) #level sensor
GPIO.setup(17, GPIO.OUT) #Relay1
def liquidsensor():
    return GPIO.input(23)
def pumpon():
    GPIO.output(17,0)
def pumpoff():
    GPIO.output(17,1)
try:
    while True:
        if liquidsensor() == 1:
            pumpoff()
            print "Tank Full"
            sleep(1)
            break
            GPIO.cleanup()
        else:
            pumpon()
            print "Tank Empty"
            sleep(1)
except KeyboardInterrupt:
    GPIO.cleanup()
This is working fine, but now I would like to log the status of the pump control pin, so I can know how long the pump is running for. Is this possible?
I have been trying to log to a database, but I am seriously confused as to how to implement it within this script.
My attempt:
import time
import datetime
import mariadb
#GPIO SETUP
GPIO.setup(17, GPIO.OUT) #Pump Relay
#db setup
db = mariadb.connect(host="localhost", user="sensor", passwd="password", db="database")
cur = db.cursur()
def timeread():
        stamp = time.time()*1000
        return stamp
def liquidsensor():
def pump():
    return GPIO.output(17)
def pumpon():
    GPIO.output(17,0)
#    return GPIO.output(17)
def pumpoff():
    GPIO.output(17,1)
stamp = timeread()
liqsensor = liquidsensor()
pumpon = pumpon()
pumpoff = pumpoff()
sql = ("""INSERT INTO hware (Stamp,liqlevel,Pump) VALUES(%s,%s,%s)""", (stamp,liqsensor,pump))
try:
    while True:
            pumpoff()
            print("Tank Full")
            sleep(1)
            pump()
            sleep(1)
            cur.execute(*sql)
            db.commit()
            sleep(1)
            break
            GPIO.cleanup()
            cur.close()
            db.close()
        else:
            pumpon()
            print("Tank Empty")
            sleep(1)
            pump()
            sleep(1)
            cur.execute(*sql)
            db.commit()
            sleep(1)
    GPIO.cleanup()
    cur.close
    db.close
Its not working, it returns:
$ python3 watersensetodb.py
watersensetodb.py:13: RuntimeWarning: This channel is already in use, continuing anyway.  Use GPIO.setwarnings(False) to disable warnings.
  File "watersensetodb.py", line 20, in <module>
    cur = db.cursur()
AttributeError: 'mariadb.connection' object has no attribute 'cursur'
So I have an issue there, but will this approach work? Or is it better to keep the logging seperate?
I guess it's easier for me to use a different script, but will the pin like being referenced at the same time by two different scripts?
Or should I use another script, that uses a different pin as an input, and is connected to the pump control pin, which I could use to monitor what the pump is doing...?
It's probably even better to monitor the actual power usage of the pump, for ultimate feedback, but that might be a step too far for me at this stage.
It would be efficient to only log when the pump is turned on and then off, essentially capturing its running time. So I don't have to have a script running constantly, can I "trigger" the logging script to start when the water level check script starts? How would I do that?
So many questions, thanks in advance for your insights!
Cheers,
Sandy
Re: A question about mariadb logging and more
Mon Apr 19, 2021 11:04 pm
How's your table defined?
It's cursor not cursur.
stamp = timeread()
pumpon = pumpon()
pumpoff = pumpoff()
How is that pump variable created?
I'd create the table as
CREATE TABLE hware (Stamp TIMESTAMP NOT NULL DEFAULT CURRENT_TIMESTAMP, liqlevel float, Pump int);
I'd insert a row with
sql = (""" INSERT INTO hware(liqlevel, Pump) VALUES(%S, %S)""", (liqsensor, pump))
the timestamp column (called Stamp) will look after itself.
sandysound
Tue Apr 20, 2021 9:34 pm
Thanks Dougie! Your a Leg End!
I have been reading up on edge detection and callbacks. Perhaps this is the best way to achieve what I am trying to do?
Am I correct in thinking that doing it this way it can run in the background (setup before the loop), then while the loop is happening can detect the status changes and log them to the database without affecting the running loop?
Cheers,
Sandy
Wed Apr 21, 2021 12:09 am
Post all of your code.
