Ryback
Shell script to edit /boot/config.txt & reboot
Wed Nov 27, 2019 6:58 am
Hi!
I use a raspbian buster light with a service that start a start.sh script on boot, which launches xinit.
In the start.sh script i make a curl download to a server which has a /boot/config.txt
var=$(curl "SERVERURL" -G)
if [[ $var ]]; then
    echo "$var" > /boot/config.txt;
    sleep 5;
    sudo reboot;
fi
The curl download and writing to the config.txt works perfect.
But the "sudo reboot" afterwards didn`t work.
The screen goes blank and the raspi is not reachable anymore.
If i unplug the power and plug it back, the raspi boots normal with the new config.txt.
So the new config.txt can`t be the problem.
If i comment out the "sudo reboot" and do the reboot with a SSH-Login after the start.sh script it works.
So somehow the reboot command within my start.sh script makes a problem.
Maybe someone has a tip what could be the problem?
epoch1970
Re: Shell script to edit /boot/config.txt & reboot
Wed Nov 27, 2019 1:41 pm
Did you try without "sudo"?
If the script is launched at init I guess it runs as root, no need to sudo.
Ryback
Tue Dec 03, 2019 2:40 pm
Thank you for the tip, without sudo the script works.
Strange is only that the reboot takes very long, ca. 90 seconds.
I think thats some kind of timeout because my script is started through a service with the following settings.
Or maybe it`s a problem that the script try to do the reboot command while it`s stille active.
[Unit]
Description=Test
After=network.target
[Service]
Type=idle
RemainAfterExit=no
ExecStart=/usr/bin/test.sh start
ExecStop=/usr/bin/test.sh stop
ExecRestart=/usr/bin/test.sh restart
ExecReload=/usr/bin/test.sh reload
Restart=always
[Install]
WantedBy=multi-user.target
epoch1970
Tue Dec 03, 2019 3:30 pm
There is a systemctl-something command to do reboot (...) Maybe you need to use that instead?
