McGregor80
Performance difference on PI2
Tue Feb 10, 2015 5:58 pm
I made an application compiled on gcc 4.7. It was made for raspbian 2013.09 (somewhere around this date) installed on RPi B.
The application uses I2C, UART, some GPIO.
Today i tried to run it on The RPi2 (latest raspbian 2015.01.31). I made some small changes related to DT(device tree) and gpio address area to simply run all the interfaces and.
It works, but... it seems to be slower on PI2 than on PI1. As i have both versions i rebooted them at the same time and this what took PI1 5 minutes takes PI2 at least 12 minutes.
What can it be?
New kernel? More background tasks ? (raspbian 2015 takes twice as much hd space comparing with Raspbian 2013)
Or maybe i should compile with native raspberry gcc to squeeze more from the HW?
Is there any other gcc compilator version which supports the 4 cores SoC?
Interesting is that when i look att "sudo top" i see it takes much less processor power on Pi2 than Pi1
Re: Performance difference on PI2
Tue Feb 10, 2015 6:46 pm
If CPU usage is less, then it is waiting for stuff to happen, rather than being slow.
Since you are using HW, I'd think time-outs going odd somewhere, or perhaps the higher speed of the cores is missing something that it previously caught.
FTrevorGowen
Thu Feb 12, 2015 9:38 am
Are you using the same kernel on both Pi's? (ie. has Raspbian on the B been updated etc.)
Are you "exporting" GPIO pins - if so this thread may be relevant:
http://www.raspberrypi.org/forums/viewt ... 44&t=99113
Trev.
gregeric
Thu Feb 12, 2015 10:51 am
Could it be related to this:
http://www.raspberrypi.org/forums/viewt ... 25#p684326
identified as:
http://www.raspberrypi.org/forums/viewt ... 50#p684457
(I think I saw some commit from Phil_E which addressed this, but could not find link right now)
I'm having issues with RTLSDR-Airband - the textual waterfall display runs at least half speed on the 2B vs B+, and it sounds like Norman Collier is piloting the planes. So far I've identified it's not the gpu_fft code, so next to investigate the sample collection from the usb sdr dongle.
McGregor80
Sat Feb 21, 2015 7:57 pm
FTrevorGowen wrote:Are you using the same kernel on both Pi's? (ie. has Raspbian on the B been updated etc.)
Trev.
Thanks but i guess it is not the issue on my application.
I wrote it in c and i map memory for the pin access.
I noticed however that the i2c display i have tends to be really slow. I don't know why.
dom
Sat Feb 21, 2015 8:00 pm
What does "vcgencmd version" report?
I suspect it is the issue @gregeric linked to, which has been fixed in newer firmware.
gregeric
Thu Feb 26, 2015 10:47 pm
gregeric wrote:I'm having issues with RTLSDR-Airband - the textual waterfall display runs at least half speed on the 2B vs B+, and it sounds like Norman Collier is piloting the planes. So far I've identified it's not the gpu_fft code, so next to investigate the sample collection from the usb sdr dongle.
In this case, I've pinpointed the slow-down to some vfp optimised assembly which runs like treacle on the Pi2.
Reverting to the author's c routine from the commit before the assembly was substituted has got things working.
enedil
Thu Feb 26, 2015 11:16 pm
Does the issue still exist if you compile your app using LLVM/clang (avaliable in repositories)?
- What Can a Thoughtful Man Hope for Mankind on Earth, Given the Experience of the Past Million Years?
- Nothing.
Kurt Vonnegut, Cat's Cradle
gregeric
Mon Mar 02, 2015 2:13 pm
Hi - thanks for the suggestion. With llvm-g++ it errors out:
as -o rtl_airband_asm.o rtl_airband_asm.s -mcpu=arm1176jzf-s -march=armv6zk -mfpu=vfp
llvm-g++ -L/opt/vc/lib/ -lbcm_host -I/opt/vc/include -I/opt/vc/include/interface/vcos/pthreads -I/opt/vc/include/interface/vmcs_host/linux -lrt -lm -lvorbisenc -lmp3lame -lshout -lpthread -lrtlsdr -o rtl_airband -O3 -mtune=arm1176jzf-s -mcpu=arm1176jzf-s -march=armv6zk -mfpu=vfp  rtl_airband.cpp hello_fft/mailbox.c hello_fft/gpu_fft.c hello_fft/gpu_fft_base.c hello_fft/gpu_fft_twiddles.c hello_fft/gpu_fft_shaders.c rtl_airband_asm.s
Potential incompatible plugin version. GCC: 4.6 (20120301). Expected: 4.6 (20121127)
Defines 'dragonegg_disable_version_check' as env variable to remove this warning
Please note that unexpected errors might occur.
/usr/bin/ld: error: rtl_airband uses VFP register arguments, /tmp/cctp8Ghw.o does not
/usr/bin/ld: failed to merge target specific data of file /tmp/cctp8Ghw.o
/usr/bin/ld: error: rtl_airband uses VFP register arguments, /tmp/ccShZDMc.o does not
/usr/bin/ld: failed to merge target specific data of file /tmp/ccShZDMc.o
/usr/bin/ld: error: rtl_airband uses VFP register arguments, /tmp/ccdcmMvd.o does not
/usr/bin/ld: failed to merge target specific data of file /tmp/ccdcmMvd.o
/usr/bin/ld: error: rtl_airband uses VFP register arguments, /tmp/ccnHITRT.o does not
/usr/bin/ld: failed to merge target specific data of file /tmp/ccnHITRT.o
/usr/bin/ld: error: rtl_airband uses VFP register arguments, /tmp/ccS7q7h0.o does not
/usr/bin/ld: failed to merge target specific data of file /tmp/ccS7q7h0.o
/usr/bin/ld: error: rtl_airband uses VFP register arguments, /tmp/ccW0eft0.o does not
/usr/bin/ld: failed to merge target specific data of file /tmp/ccW0eft0.o
collect2: ld returned 1 exit status
makefile:28: recipe for target 'rtl_airband' failed
make: *** [rtl_airband] Error 1
Are those errors meaningful to you?
enedil
Tue Mar 03, 2015 6:37 pm
I don't know what are you using, but you should install package clang and run compiler
clang++ file.cpp -o file
- Nothing.
Tue Mar 03, 2015 7:00 pm
That's interesting. Can you flag up which function is causing the problems on the Pi2, that clearly needs to be checked.
gregeric
Wed Mar 04, 2015 12:51 pm
Hi James - it's the samplefft() assembly routine which applies a window function prior to calling gpu_fft(). Here's my fork:
https://github.com/campag/RTLSDR-Airban ... band_asm.s
In the makefile there are configurations to build for arm6 or arm7. The arm6 build runs fine on the older models.
To get it to work on the Pi2B, I inserted a define so as to swap out the asm for samplefft(), instead using original author microtony's deprecated c code to apply the window function. The other asm routine, fftwave(), which does the am demodulation, is retained & works.
You will need an rtl2832 dongle to test the code as-is, or create a new test program which calls the asm.
Edit: Could it be the .align 2? I'll try .align 4 later.
Edit2: Nope, that didn't fix (or break) it.
gregeric
Wed Mar 04, 2015 12:54 pm
enedil wrote:I don't know what are you using, but you should install package clang and run compiler
I installed clang now, was using llvm before. There were some warnings on compiling in both the asm parts and c parts of the source (sorry, no access to it right now). Will post later. Resultant binary perfoms similarly: OK on Pi1, NOK on Pi2
Edit: Here's the compiler output when trying to build for Pi1, runs badly on Pi2:
clang++ -L/opt/vc/lib/ -lbcm_host -I/opt/vc/include -I/opt/vc/include/interface/vcos/pthreads -I/opt/vc/include/interface/vmcs_host/linux -lrt -lm -lvorbisenc -lmp3lame -lshout -lpthread -lrtlsdr -o rtl_airband -O3 -mtune=arm1176jzf-s -mcpu=arm1176jzf-s -march=armv6zk -mfpu=vfp  rtl_airband.cpp hello_fft/mailbox.c hello_fft/gpu_fft.c hello_fft/gpu_fft_base.c hello_fft/gpu_fft_twiddles.c hello_fft/gpu_fft_shaders.c rtl_airband_asm.s
clang: warning: treating 'c' input as 'c++' when in C++ mode, this behavior is deprecated
rtl_airband.cpp:344:1: warning: control reaches end of non-void function [-Wreturn-type]
rtl_airband.cpp:663:50: warning: '&&' within '||' [-Wlogical-op-parentheses]
                        if (channel->agcsq == -1 && channel->agcavgslow < 2.4f * channel->agcmin || channel->agclow == AGC_EXTRA - 12) {
rtl_airband.cpp:663:50: note: place parentheses around the '&&' expression to silence this warning
2 warnings generated.
/tmp/gpu_fft-wZYH7n.s: Assembler messages:
/tmp/gpu_fft-wZYH7n.s:75: Rd and Rm should be different in mul
/tmp/gpu_fft-wZYH7n.s:125: Rd and Rm should be different in mla
/tmp/gpu_fft-wZYH7n.s:240: Rd and Rm should be different in mla
Return to “C/C++”
