veryevil
RPI2 Eclipse CDT Install
Thu Feb 05, 2015 3:40 pm
Now the PI has some more horsepower would it be possible to get eclipse installed on the PI and compile and test locally?
The version of eclipse in the raspbian repo is really old but i dont know how to get one of the newer ones running? Can I compile eclipse from source or am I missing something?
PeterO
Re: RPI2 Eclipse CDT Install
Thu Feb 05, 2015 3:42 pm
veryevil wrote:Now the PI has some more horsepower would it be possible to get eclipse installed on the PI and compile and test locally?
It's a java application, so just down load a tar ball, untar it somewhere like /opt and then run "/opt/eclipse/bin/ecipse"
https://eclipse.org/downloads/packages/ ... pers/lunar is where to get the C/C++ developers version from.
The 32 bit Linux version should work... eclipse-cpp-luna-R-linux-gtk.tar.gz
BUT, it is a memory hog, so although it will be better on a PI2 it may still be a bit slow. Let us know how you get on.
PeterO
veryevil
Thu Feb 05, 2015 3:47 pm
I've downloaded eclipse-cpp-luna-R-linux-gtk.tar.gz but it has a binary file eclipse which won't run?
Is there a different file I should have downloaded?
PeterO
Thu Feb 05, 2015 3:50 pm
Hmmmm ... I'm surprised but checking on a PC here it is a shell script, BUT in then runs a binary.... I can't help anymore until I'm infront of a PI at home this evening.
Sorry,
PeterO
veryevil
Thu Feb 05, 2015 7:06 pm
I've had another gonthis evening but not got anywhere.
Cannot find any source even for the binary.
PeterO
Thu Feb 05, 2015 7:56 pm
Maybe the best course is to ask for the version in Raspbian to be updated if possible ?
PeterO
remo67
Tue May 12, 2015 1:24 am
Is there a newer version of Eclipse that will run on the Pi 2? If so, what does one do to get it installed and working?
adamski69
Wed May 13, 2015 3:48 pm
I've been trying to solve this today and no joy. My results are documented here:
http://www.raspberry-projects.com/pi/pr ... berry-pi-2
Looks like eclipse with cdt is currently too unstable for the RPi2?
cwasilei
Thu Jun 04, 2015 3:19 pm
I've found a workaround in order to get a working eclipse CDT on the raspberry pi. Here are the steps:
  • Open a terminal window and install eclipse by typing
    sudo apt-get install eclipse
  • Start it from Menu -> Programming -> Eclipse and choose a workspace
  • Import an existing JAVA project
  • Close eclipse
  • Now type in your terminal
    sudo apt-get install eclipse-cdt
  • Start eclipse once again and you get CDT support
Hope this helps.
hactic
Tue Jun 09, 2015 6:35 pm
veryevil wrote:I've downloaded eclipse-cpp-luna-R-linux-gtk.tar.gz but it has a binary file eclipse which won't run?
I ran into the same binary file for Eclipse startup. Then I tried to start a jar directly but no success so far.
viewtopic.php?f=34&t=20503&p=0&e=0
Return to “C/C++”
