hjimbens
Compiling for Raspberry Pi 2
Mon Feb 02, 2015 8:38 am
When I compile for Raspberry Pi 1 with gcc I use:
CFLAGS+=-DSTANDALONE -D__STDC_CONSTANT_MACROS -D__STDC_LIMIT_MACROS -DTARGET_POSIX -D_LINUX -fPIC -DPIC -D_REENTRANT -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -U_FORTIFY_SOURCE -Wall -g -DHAVE_LIBOPENMAX=2 -DOMX -DOMX_SKIP64BIT -ftree-vectorize -pipe -DUSE_EXTERNAL_OMX -DHAVE_LIBBCM_HOST -DUSE_EXTERNAL_LIBBCM_HOST -DUSE_VCHIQ_ARM -Wno-psabi
When I use clang I add:
CFLAGS+= -ccc-host-triple armv6-unknown-eabi -march=armv6 -mfpu=vfp -mcpu=arm1176jzf-s -mtune=arm1176jzf-s -mfloat-abi=hard
I suspect that these clang flags are hardwired in the gcc that comes with Raspbian.
What do I have to do when I want to compile for Pi 2 and get the best performance?
Re: Compiling for Raspberry Pi 2
Mon Feb 02, 2015 10:14 am
I think that currently the gcc on Raspbian does not support cortex-a7-NEON. BUT, the linaro cross compiler on the Raspi github does support cortex-A7 NEON, so you can use that.
I get a huge speed up on the x264 library - up to 32x faster.
PeterO
Tue Feb 03, 2015 10:16 am
I can't quite remember the details, but when I wanted to build an I2S kernal module the othe week the instructions I followed included an upgrade to gcc. I **think** it moved from version 4.8 to 4.9. 4.9 documents do suggest that A7 and NEON are supported
https://gcc.gnu.org/onlinedocs/gcc/ARM-Options.html
I'll be trying some things when I get to try my PI2 (probably not before Wednesday evening) .
PeterO
jahboater
Wed Feb 04, 2015 6:47 pm
For gcc 4.8 I use
gcc-4.8 -mcpu=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard
This gave me the best code and was the only option that enabled sdiv/udiv.
To get gcc 4.8 just do
sudo apt-get install gcc-4.8
For gcc 4.6 (the default compiler on rasbian)
gcc -march=armv7-a -mfpu=neon-vfpv4 -mfloat-abi=hard
For a Pi 1 (B+)
gcc -mcpu=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard
Hope this helps.
Pi4 8GB running PIOS64
gregeric
Fri Feb 06, 2015 5:33 pm
And when compiling large projects on the Pi2, use "make -j 4" to take advantage of the extra cores .
RoyLongbottom
Sun Feb 08, 2015 3:01 pm
jahboater wrote:For gcc 4.8 I use
Thanks for those. I am running my benchmarks on the RPi 2. One of the first to try was the Linpack benchmark. With those gcc 4.6 parameters, speeds were little different to my original (gcc linpack.c cpuidc.c -lm -lrt -O3 -march=armv6 -mfloat-abi=hard -mfpu=vfp -o linpackPiA6). I installed gcc 4.8 and that was 28% faster (with your parameters), but results of numeric calculations were different - need to think about it.
I have posted the first results (original MP-MFLOPs) to show MP use. The gcc 4.8 version was up to 9% faster with one numeric result slightly different, suggesting different rounding. Performance results are here:
http://www.raspberrypi.org/forums/viewt ... 25#p688425
PeterO
Sun Feb 08, 2015 5:43 pm
I'm pretty sure the Neon extensions are only single precision (float) rather than double precison (double) instructions..
The FFTW I'm using came out with all the functions called fftwf_xxxxxx (which doesn't seem to be documented anywhere I could find).
PeterO
PiGraham
Sun Feb 08, 2015 9:01 pm
Optimal build for Quake3?
Please suggest tweeks.
#!/bin/bash
# this script builds q3 with SDL
# invoke with ./build.sh
# or ./build.sh clean to clean before build
# directory containing the ARM shared libraries (rootfs, lib/ of SD card)
# specifically libEGL.so and libGLESv2.so
ARM_LIBS=/opt/vc/lib
SDL_LIB=lib
# directory containing baseq3/ containing .pk3 files - baseq3 on CD
BASEQ3_DIR="/home/${USER}/"
# directory to find khronos linux make files (with include/ containing
# headers! Make needs them.)
INCLUDES="-I/opt/vc/include -I/opt/vc/include/interface/vcos/pthreads"
# prefix of arm cross compiler installed
#CROSS_COMPILE=bcm2708-
# clean
if [ $# -ge 1 ] && [ $1 = clean ]; then
   echo "clean build"
   rm -rf build/*
fi
# sdl not disabled
make -j4 -f Makefile COPYDIR="$BASEQ3_DIR" ARCH=arm \
        CC=""$CROSS_COMPILE"gcc-4.8" USE_SVN=0 USE_CURL=0 USE_OPENAL=0 \
        CFLAGS="-DVCMODS_MISC -DVCMODS_OPENGLES -DVCMODS_DEPTH -DVCMODS_REPLACET                                                     RIG $INCLUDES -mcpu=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard" \
        LDFLAGS="-L"$ARM_LIBS" -L$SDL_LIB -lSDL -lvchostif -lvmcs_rpc_client -lv                                                     cfiled_check -lbcm_host -lkhrn_static -lvchiq_arm -lopenmaxil -lEGL -lGLESv2 -lv                                                     cos -lrt"
# copy the required pak3 files over
# cp "$BASEQ3_DIR"/baseq3/*.pk3 "build/release-linux-arm/baseq3/"
# cp -a lib build/release-linux-arm/baseq3/
exit 0
Performance is VERY impressive.
Overclock arm freq 1100, overvolt 6
Video mode 1280x1024
Lighting Vertex
Geometric detail high
Texture detail all the way up the slider
Texture quality 32bit
Texture filter Trilinear
90fps in the demo, a good 60+ in multiplayer with 5 bots
Never below 30fps with 12 bots and lots of action.
RoyLongbottom
Mon Feb 09, 2015 10:23 am
PeterO wrote:I'm pretty sure the Neon extensions are only single precision
PeterO
I found that my Linpack performance gains were through using vfp4 that provides fused multiply and add. I have a C program for NEON Linpack for Android to convert for RPi. When produced, NEON could only handle single precision and there was no automatic vectorisation. Intrinsics had to be used instead. Following is the code used for the performance dependent daxpy function (instead of #ifdef ROLL or UNROLL):
#ifdef NEON
    float  cf[4];
    float32x4_t x41, y41, c41, r41;
    float32_t   *ptrx1 = (float32_t *)dx;
    float32_t   *ptry1 = (float32_t *)dy;
    float32_t   *ptrc1 = (float32_t *)cf;
    for (i=0; i<4; i++)
     cf[i] = da;
    m = n % 4;
    if ( m != 0)
            for (i = 0; i < m; i++)
                    dy[i] = dy[i] + da*dx[i];
            if (n < 4) return;
    ptrx1 = ptrx1 + m;
    ptry1 = ptry1 + m;
    c41 = vld1q_f32(ptrc1);
    for (i = m; i < n; i=i+4)
        x41 = vld1q_f32(ptrx1);
        y41 = vld1q_f32(ptry1);
        r41 = vmlaq_f32(y41, x41, c41);
        vst1q_f32(ptry1, r41);
        ptrx1 = ptrx1 + 4;
        ptry1 = ptry1 + 4;
#endif
mrvn
Sat Feb 14, 2015 12:23 pm
Under Debian (jessie/sid) one can use the gcc-arm-none-eabi cross compiler package. That gcc is compiled with a number of libgcc flavour for different cpu cores. One has to pick the right flags to get the optimized libgcc for the RPi2 and to optimize the source itself. /usr/share/doc/gcc-arm-none-eabi/readme.txt.gz shows all the possible options. Relevant for the RPi2 are the three last:
  • Cortex-A* (No FP): [-mthumb] -march=armv7-a
  • Cortex-A* (Soft FP): [-mthumb] -march=armv7-a -mfloat-abi=softfp -mfpu=vfpv3-d16
  • Cortex-A* (Hard FP): [-mthumb] -march=armv7-a -mfloat-abi=hard -mfpu=vfpv3-d16
Sat Feb 14, 2015 12:43 pm
Neon floating point doesn't adhere entirely to the IEEE standard.
From https://gcc.gnu.org/onlinedocs/gcc/ARM-Options.html
If the selected floating-point hardware includes the NEON extension (e.g. -mfpu=‘neon’), note that floating-point operations are not generated by GCC's auto-vectorization pass unless -funsafe-math-optimizations is also specified. This is because NEON hardware does not fully implement the IEEE 754 standard for floating-point arithmetic (in particular denormal values are treated as zero), so the use of NEON instructions may lead to a loss of precision.
jbeale
Sun Feb 15, 2015 4:04 pm
I tried recompiling some C code on RP2 that does a single-precision 2D inverse FFT with 4096 x 4096 elements, using the current Raspbian gcc without special flags, and also gcc-4.8 with them. I did 4 runs with each version, and the time in the FFT routine averaged 62 seconds in both cases. Is this expected, or should there be an improvement? There was one tiny difference; the older GCC code took 62 or 63 seconds on each run. The newer code varied from 61 to 64 seconds. The system was otherwise unloaded (except for 'top' running, showing the FFT code at 99.8% ... 100.3% cpu) in both cases.
Compile flags:
(Case 1) gcc -ansi -pedantic -Wall -O4   (Raspbian gcc version 4.6.3)
(Case 2) gcc-4.8 -ansi -pedantic -Wall -O4 -mcpu=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -funsafe-math-optimizations
If anyone's interested, the code is http://www.bealecorner.org/best/gforge/Hflab095.zip and inside the interpreter my test was:
cfill 4096; tic; ifft; toc
EDIT: using the built-in repeat function the variability went away, but still nearly the same speed.
HL>repeat 10 cfill 4096; tic; ifft; toc; pop
62 seconds.
62 seconds.
61 seconds.
62 seconds.
62 seconds.
62 seconds.
62 seconds.
61 seconds.
62 seconds.
62 seconds.
HL-ARMv7>repeat 10 cfill 4096; tic; ifft; toc; pop
62 seconds.
62 seconds.
61 seconds.
61 seconds.
61 seconds.
61 seconds.
61 seconds.
61 seconds.
61 seconds.
61 seconds.
Note: with 4 threads each at 100% CPU, my power meter says 0.47 A @ 5.02V = 2.36 W, and after a few minutes cpu temperature = 53 C
Interestingly, if I run four instances of the "hl" program each doing a large FFT job, each one takes about 156 seconds to complete instead of 62 seconds, so with all four CPUs busy, each thread is running at 40% of the full speed it had when running alone. I guess the problem is the memory bus access, since each 4096x4096 complex array takes up 134 MB it won't fit in any kind of local cache, and the FFT process is highly non-local, accessing every element frequently.
PeterO
Mon Feb 16, 2015 5:31 pm
I can't check now, but I think I've read somewhere that you have to use "compiler intrinsics" to get gcc to generate code that uses NEON. The compiler switch in not enough by itself.
NOTE: I don't have any experience with using said intrinsics !
PeterO
RoyLongbottom
Tue Feb 17, 2015 3:23 pm
My Linpack NEON code for Linux is above. This runs on ARM CPUs via Android:
http://www.raspberrypi.org/forums/viewt ... 90#p689390
Besides this #include <arm_neon.h> is needed and can be compiled on the RPi with the following (but not some of the other things suggested)
gcc linpackneon.c cpuidc.c -lm -lrt -O3 -mcpu=cortex-a7 -mfloat-abi=hard -mfpu=neon-vfpv4 -o linpackNEONPi
The benchmark runs and appears to obtain the same speed as ARM via Android, with a similar CPU MHz, but numerical calculations end up as nan (not a number).
Any suggestions?
hydra3333
Thu Feb 19, 2015 6:16 am
I am starting to learn about compiling for the Pi. api's, abi's ... so confusing.
There are many different search results on what arguments to use with "make", and which GCC compiler version to use, (4.9.2 apparently requires a patch http://www.intestinate.com/pilfs/patche ... ault.patch ) https://gcc.gnu.org/onlinedocs/gcc/ARM-Options.html
A surprising find indicates "neon" on the Cortex-A7 (neon-vfpv4 ?) can produce either unexpected calculation results or "not a number" results.
I don't know what the bottom line from it is, however could it be "use neon at your own risk" ?
if the selected floating-point hardware includes the NEON extension (e.g. -mfpu=‘neon’), note that floating-point operations are not generated by GCC's auto-vectorization pass unless -funsafe-math-optimizations is also specified. This is because NEON hardware does not fully implement the IEEE 754 standard for floating-point arithmetic (in particular denormal values are treated as zero), so the use of NEON instructions may lead to a loss of precision.
http://www.raspberrypi.org/forums/viewt ... 53#p688601
http://www.raspberrypi.org/forums/viewt ... 53#p697401
http://en.wikipedia.org/wiki/ARM_archit ... _.28VFP.29
seems to indicate either VFPv4-D16 or VFPv4
Anyway, for compiling ffmpeg and a few of it's dependencies from the latest sources, I'm unsure what to use and how, so I could someone confirm whether it's like this ?
./configure -j 4 --enable-static ?--arch=armhf? --target-os=linux --enable-static --disable-asm --enable-gpl --prefix=/usr --enable-nonfree -mcpu=cortex-a7 -mfpu=vfpv4 -march=armv7-a -mfpu=vfpv4 -mfloat-abi=hard -funsafe-math-optimizations -mtune=cortex-a7 -mcpu=cortex-a7
sudo make
sudo make install
Also, which compiler ? Should I install gcc 4.9.2 just because it's the latest ? If so, I'll google it. And would it work with the arguments above ?
jamesh wrote:I get a huge speed up on the x264 library - up to 32x faster.
Would you be able to post all your commandlines ? (including wget's etc) ?
jahboater
Thu Feb 19, 2015 8:41 am
I would remove the -march flag.
gcc-4.8 fails
error: switch -mcpu=cortex-a7 conflicts with -march=armv7-a switch
and its not needed anyway.
Thu Feb 19, 2015 9:10 am
You will need to change the CCJPREFIX line to point to where you have installed the linaro cross compiler (from raspi github tools repo)
git clone git://git.videolan.org/x264.git
cd x264
export CCJPREFIX="/home/james/projects/raspberrypi/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian-x64/bin/arm-linux-gnueabihf-"
./configure --host=arm-linux --cross-prefix=${CCJPREFIX} --enable-static --extra-cflags="-mcpu=cortex-a7 -mfpu=neon-vfpv4"
make
hydra3333
Re: Compiling for Raspberry Pi 2 (ffmpeg external libraries)
Sat Feb 21, 2015 5:17 am
I thought I'd try a native Pi2 compile using standard gcc 4.6.3 on the Pi2 for the Pi2 ... why not.
My first attempt is from-scratch download and building from source of many of the ffmpeg external libraries, prior to building ffmpeg.
I fluked getting most external libraries working with some trial and error. A few I could not, and as a newbie I am still unsure what to do with them (as noted in the .sh below).
In line with Pi2's gcc 4.6.3 as at 2015.02.21 and prior to more googling, most external library builds use
snip, out of date
edit: slightly updated
edit2: outdated code, removed
also: stop posting this here and referred over to forum http://www.raspberrypi.org/forums/viewt ... 7&t=100108
eriktheitalian
Tue Mar 17, 2015 9:28 am
I'm respect raspberry developers. I'm happy with Rpi2. But...
I'm tired with kernel compilation processes. I'm not using cross-compiller. I'm using full time raspberry. There is no optimized kernel building documentation. When i'm used debian over x86 i'm founded lots of optimized kernel documentation. Sample: I'm building core i7 ivy bridge optimized kernel. I can't do fine tunning over raspbian kernel.
I'm building raspbian kernel. I'm not know is this armv6 optimized or v7 optimized.
I'm tried what is mean for "-march=native" for gcc 4.9.2. This is resulting "armv7ve".
My "gcc -v" output including "-march=armv6"
I cant using enough English language. My writings can be wrong grammer.$
"in micro$oft we not trust"
eriktheitalian
Tue Mar 17, 2015 9:39 am
What is mean of optimized kernel building documentation for me ?
Real time process optimized kernel.
Xorg, GUI response/latency optimized kernel.
Server optimized kernel.
Memory usage optimized kernel.
IO transfer optimized kernel.
Gpu optimized.
Power management focused kernel.
And more...
eriktheitalian
Sat Mar 28, 2015 8:09 am
I'm working on finding performance related gcc flags for rpi2. I'm confused. Lots document. Lots idea. I cant find clean simple source.(This is not raspberry's problem. This is s universal) I need test options one by one.
eriktheitalian
Sat Mar 28, 2015 8:20 am
I'm founded about what is mean of -O3 or -O4
"gcc -c -Q -O3 --help=optimizers | grep enabled"
eriktheitalian
Sat Mar 28, 2015 10:01 am
RoyLongbottom wrote:My Linpack NEON code for Linux is above. This runs on ARM CPUs via Android:
Any suggestions?
Thanks for important benchmark. Its very useful for one by one test.
AlessandroFerri
Fri Apr 24, 2015 5:33 pm
Thank you all for having dealt with the topic.
In fact I have compiled pulseaudio and other programs in raspberry Pi2 in the same way in which I have compiled for raspberry B+. I followed the instructions on this post:
viewtopic.php?f=29&t=87138
But now I realized that doing so PulseAudio works with only one core on raspberry Pi2 and not with four cores. I see by running top. I think that must be given other parameters to be included on ./configure and make.
You have any suggestions?
ejolson
Tue Apr 28, 2015 2:51 am
AlessandroFerri wrote:Thank you all for having dealt with the topic.
Your question is about parallel and threaded processing. I don't think pulse audio is written in a way that scales to multi-core architectures. For this you probably want JACK2
https://en.wikipedia.org/wiki/JACK_Audio_Connection_Kit
which reportedly has SMP multi-processor scalability. It would be nice to have a separate forum topic about parallel processing where this and related topics could be discussed.
Return to “C/C++”
