SupernovaV2
Feed ALSA capture into GPU_FFT
Wed Jan 21, 2015 2:29 pm
Hi Everyone, I have had a search around the forums and it seems that a number of people have tried this, however no one posted finished code in the end. I don't mind doing it again myself, but I want to get this capturing part done and out of the way so I can do some fun stuff with the FFT output!
These threads were super useful in getting to this stage but I just seem to be stuck http://www.raspberrypi.org/forums/viewt ... 7&p=642341 http://www.raspberrypi.org/forums/viewt ... 29&t=88179
I think I'm misunderstanding the number format each part operates in, as I see it ALSA outputs to a frame buffer of short ints, and GPU_FFT wants floats. I tried just duplicating the buffer and casting the ints to floats but it doesn't seem to help. Any help would be much appreciated!
I realise that it's in interleaved frame format which could complicate things but the hardware is only initialised to capture 1 channel so it shouldn't make a difference in this case?
Capturing from ALSA
From Paul David's tutorial : http://equalarea.com/paul/alsa-audio.html
sudo apt-get install libasound2-dev
gcc -o alsa-record-example -lasound alsa-record-example.c && ./alsa-record-example hw:0
GPU_FFT thanks to Andrew Holme
other chunks of ccode copied wholesale from PeterO of raspberrypi.org, many thanks!
#include <stdio.h>
#include <stdlib.h>
#include <alsa/asoundlib.h>
#include <unistd.h>
#include <math.h>
#include <time.h>
#include "mailbox.h"
#include "gpu_fft.h"
main(int argc, char *argv[])
	int i,j;
	int err;
	int16_t *buffer;
	float* float_buffer;
	int buffer_frames = 128;
	unsigned int rate = 44100;
	char* devcID;
	snd_pcm_t *capture_handle;
	snd_pcm_hw_params_t *hw_params;
	snd_pcm_format_t format = SND_PCM_FORMAT_S16_LE;
	devcID = malloc(sizeof(char) * 5);
	if (argc > 1){
		devcID = argv[1];
	else {
		devcID = "hw:0,0"; //doesn't seem to make a difference if this is just hw:0
	if ((err = snd_pcm_open(&capture_handle, devcID, SND_PCM_STREAM_CAPTURE, 0)) < 0) {
		fprintf(stderr, "cannot open audio device %s (%s)\n",devcID,snd_strerror(err));
		exit(1);
	} else {fprintf(stdout, "audio interface opened\n");}
	if ((err = snd_pcm_hw_params_malloc(&hw_params)) < 0) {
		fprintf(stderr, "cannot allocate hardware parameter structure (%s)\n",
			snd_strerror(err));
		exit(1);
	}	else { fprintf(stdout, "hw_params allocated\n"); }
	if ((err = snd_pcm_hw_params_any(capture_handle, hw_params)) < 0) {
		fprintf(stderr, "cannot initialize hardware parameter structure (%s)\n",
			snd_strerror(err));
		exit(1);
	}	else { fprintf(stdout, "hw_params initialized\n"); }
	if ((err = snd_pcm_hw_params_set_access(capture_handle, hw_params, SND_PCM_ACCESS_RW_INTERLEAVED)) < 0) {
		fprintf(stderr, "cannot set access type (%s)\n",
			snd_strerror(err));
		exit(1);
	}	else { fprintf(stdout, "hw_params access set\n"); }
	if ((err = snd_pcm_hw_params_set_format(capture_handle, hw_params, format)) < 0) {
		fprintf(stderr, "cannot set sample format (%s)\n",
			snd_strerror(err));
		exit(1);
	}	else { fprintf(stdout, "hw_params format set\n"); }
	if ((err = snd_pcm_hw_params_set_rate_near(capture_handle, hw_params, &rate, 0)) < 0) {
		fprintf(stderr, "cannot set sample rate (%s)\n",
			snd_strerror(err));
		exit(1);
	}	else { fprintf(stdout, "hw_params rate set\n"); }
	if ((err = snd_pcm_hw_params_set_channels(capture_handle, hw_params, 1)) < 0) {
		fprintf(stderr, "cannot set channel count (%s)\n",
			snd_strerror(err));
		exit(1);
	}	else { fprintf(stdout, "hw_params channels set\n"); }
	if ((err = snd_pcm_hw_params(capture_handle, hw_params)) < 0) {
		fprintf(stderr, "cannot set parameters (%s)\n",
			snd_strerror(err));
		exit(1);
	}	else { fprintf(stdout, "hw_params set\n"); }
	snd_pcm_hw_params_free(hw_params);
	fprintf(stdout, "hw_params freed\n");
	if ((err = snd_pcm_prepare(capture_handle)) < 0) {
		fprintf(stderr, "cannot prepare audio interface for use (%s)\n",
			snd_strerror(err));
		exit(1);
	}	else { fprintf(stdout, "audio interface prepared\n"); }
	//allocate buffer of 16bit ints, as specified in PCM_FORMAT
	buffer = malloc(buffer_frames * snd_pcm_format_width(format) / 8 * 2);
	float_buffer = malloc(buffer_frames*sizeof(float));
	fprintf(stdout, "buffer allocated\n");
	float *OutData;
	int NLOG2 = 10;
	unsigned long N = 1 << NLOG2;
	OutData = malloc(N * sizeof(float));
	int Peaki;
	float PeakValue;
	for (i = 0; i < 10000; ++i) {
		//read from audio device into buffer
		if ((err = snd_pcm_readi(capture_handle, buffer, buffer_frames)) != buffer_frames) {
			fprintf(stderr, "read from audio interface failed (%s)\n",
				err, snd_strerror(err));
			exit(1);
		//try to change buffer from short ints to floats for FFT transformation
		for (i = 0; i < buffer_frames; i++){
			float_buffer[i] = (float)buffer[i];
		//printf("Compute FFT  ... ");
		fft_compute_forward(buffer, NLOG2, OutData, 1);
		printf("\n");
		usleep(100);
	free(buffer);
	free(OutData);
	fprintf(stdout, "memory freed\n");
	snd_pcm_close(capture_handle);
	fprintf(stdout, "audio interface closed\n");
	fprintf(stdout,"Press enter to continue\n");
	getchar();
	return(0);
	exit(0);
int fft_compute_forward(float * input, int log2_N, float * output, double sampling_interval)
	int mb = mbox_open();
	int jobs = 1, i;
	unsigned long N = 1 << log2_N;
	float FloatN = (float)N;
	float HalfN = FloatN / 2.0;
	struct GPU_FFT_COMPLEX * base;
	struct GPU_FFT * fft;
	struct GPU_FFT_COMPLEX *DataIn, *DataOut;
	int ret = gpu_fft_prepare(mb, log2_N, GPU_FFT_FWD, jobs, &fft);
	base = fft->in;
	for (i = 0; i<N; i++)
		base[i].re = input[i]; base[i].im = 0.0;
	gpu_fft_execute(fft);
	base = fft->out;
		output[i] = (base[i].re * base[i].re) + (base[i].im * base[i].im);
	gpu_fft_release(fft);
	mbox_close(mb);
Cheers,
Gareth
Andrew Holme
Re: Feed ALSA capture into GPU_FFT
Sun Jan 25, 2015 11:02 pm
Shouldn't this line:
be:
fft_compute_forward(float_buffer, NLOG2, OutData, 1);
PeterO
Mon Jan 26, 2015 10:07 am
Another trick is to avoid the double copy
int alsa buffer -> float buffer -> FFT input array.
Just do int alsa buffer -> FFT input array And while you ar at it you can do some appropriate scaling (such as dividing input by 32768.0 to normalise input to -1.0 .. + 1.0.
And what do you think the "usleep(100)" achieves ? The alsa read will block until there is a full buffers worth of samples available, so everything else ends up sychronous to the sound input.
And yo uonly need to call gpu_fft_prepare ONCE, not before every call to gpu_fft_execute. Likewise only call gpu_fft_release ONCE at the end of your program. Make the "fft structure pointer" a static and only assign to it on the first call.
PeterO
hystrix
Thu Oct 15, 2015 11:40 am
...and still no one posts finished code... :(
Is there any updated information on how to feed ALSA capture into GPU_FFT, which is (relatively) simple to understand, and works?
Many thanks.
PeterO
Thu Oct 15, 2015 12:47 pm
hystrix wrote:...and still no one posts finished code... :(
Many thanks.
No need for updated information as nothing has changed !
PeterO
hystrix
Thu Oct 15, 2015 4:32 pm
I admit that I have not tried the code in the first post, but the sequence of comments following it led me to believe there were issues.
Return to “C/C++”
