Bitmap in Linux
Posted: Wed Oct 08, 2014 8:19 pm
unsigned long *word;
*w = bitmap_weight(word, BATADV_TQ_LOCAL_WINDOW_SIZE);
/* shift the packet array by n places. */
static void batadv_bitmap_shift_left(unsigned long *seq_bits, int32_t n)
if (n <= 0 || n >= BATADV_TQ_LOCAL_WINDOW_SIZE)
return;
bitmap_shift_left(seq_bits, seq_bits, n, BATADV_TQ_LOCAL_WINDOW_SIZE);
/* receive and process one packet within the sequence number window.
* returns:
* 1 if the window was moved (either new or very old)
* 0 if the window was not moved/shifted.
int batadv_bit_get_packet(void *priv, unsigned long *seq_bits,
int32_t seq_num_diff, int set_mark)
struct batadv_priv *bat_priv = priv;
/* sequence number is slightly older. We already got a sequence number
* higher than this one, so we just mark it.
if (seq_num_diff <= 0 && seq_num_diff > -BATADV_TQ_LOCAL_WINDOW_SIZE) {
if (set_mark)
batadv_set_bit(seq_bits, -seq_num_diff);
return 0;
/* sequence number is slightly newer, so we shift the window and
* set the mark if required
if (seq_num_diff > 0 && seq_num_diff < BATADV_TQ_LOCAL_WINDOW_SIZE) {
batadv_bitmap_shift_left(seq_bits, seq_num_diff);
if (set_mark)
batadv_set_bit(seq_bits, 0);
return 1;
/* sequence number is much newer, probably missed a lot of packets */
if (seq_num_diff >= BATADV_TQ_LOCAL_WINDOW_SIZE &&
seq_num_diff < BATADV_EXPECTED_SEQNO_RANGE) {
batadv_dbg(BATADV_DBG_BATMAN, bat_priv,
"We missed a lot of packets (%i) !\n",
seq_num_diff - 1);
bitmap_zero(seq_bits, BATADV_TQ_LOCAL_WINDOW_SIZE);
if (set_mark)
return 1;
/* received a much older packet. The other host either restarted
* or the old packet got delayed somewhere in the network. The
* packet should be dropped without calling this function if the
* seqno window is protected.
* seq_num_diff <= -BATADV_TQ_LOCAL_WINDOW_SIZE
* or
* seq_num_diff >= BATADV_EXPECTED_SEQNO_RANGE
"Other host probably restarted!\n");
if (set_mark)
return 1;
}2)why the need to use bitmap from above?
