C/C++ Problem with pointers, advice please.
Posted: Mon Aug 18, 2014 11:22 am
by mad-hatter
I've got a lot of QGroupBox's on a QMainWindow an am showing a QPushbutton in all of them.
The QPushbutton layout is the same in all QGoupBox's, the only difference is the caption and the slot called.
What I'm trying to do is set up a function to construct the QPushButtons.
I'm having trouble getting the returned QPushButton from the function.
This is due to my lack of knowledge of C++!!!
If I call the function, and omit the return statement, it works as expected.
Rather than trying do it this way, would it be more correct to create a class for the QpushButton?
Any help would and advice would be appreciated.
Regards
Main form:-
myProg::myProg()
    myNewButton = showStartButton(G9);
    myNewButton->setText("Start");
    QObject::connect(myNewButton, SIGNAL(pressed()), this, slot(mySub()));
header:-
private:
    QPushButton *myNewButton, *myButton;
QPushButton myProg::showStartButton(QWidget *parent)
    myButton = new QPushButton(parent) ;
    myButton->setGeometry(5,
                          parent->height() - 30,
                          40,
                          24);
    return(myButton);
Error message:-
could not convert '((myProg*(this)->myProg::myButton' from 'QPushButton*' to 'QPushButton'
Re: C/C++ Problem with pointers, advice please.
Posted: Mon Aug 18, 2014 12:10 pm
by laurent
Some remarks :
- Your return value lacks a '*', because it must be a pointer according your requirements : QPushButton * myProg::showStartButton(QWidget *parent).
- At the end of your function, you can simply write "return myButton;".
- Since myButton is a pointer directly used after calling your function, keeping it as an attribute of your class is no longer needed. A local variable could nicely do the job.
Hope it helps.
Regards
Posted: Mon Aug 18, 2014 1:12 pm
by mad-hatter
Hello laurent,
Many thanks, I always have trouble with pointers, can never work it out.
Your explanation helps.
Regards
