usul27
Checking board revision
Mon Jul 21, 2014 4:45 pm
As some alternative pins have changed from model B to B+, I need to update the kernel driver. I would like to distinguish between "old" and new B+ revision. How can I do this in a kernel driver?
ShiftPlusOne
Re: Checking board revision
Mon Jul 21, 2014 5:42 pm
usul27
Tue Jul 22, 2014 7:34 pm
Ok, is there already a kernel routine to do this or do I have to implement it by myself? Couldn't see something yet. I just don't want to duplicate code that exists already.
MrEngman
Tue Jul 22, 2014 8:18 pm
What about cat /proc/cpuinfo
Shows for my Pis.
B+       - Revision        : 0010
B2 512MB - Revision        : 000e
A        - Revision        : 0008
B2 256MB - Revision        : 0004
B1       - Revision        : 0002
Plus various other stuff.
MrEngman
Tue Jul 22, 2014 8:20 pm
MrEngman wrote:What about cat /proc/cpuinfo
That needs Linux running. This is the "bare metal" forum so that may not be the case.
usul27
Tue Jul 22, 2014 8:21 pm
I can't use this from a kernel module, but I now know all revisions, which also helps.
Daniel
usul27
Tue Jul 22, 2014 8:39 pm
I need it on Linux, but in a kernel module. However the solution was much easier than expected:
extern int system_rev;
does the job :-)
usul27
Tue Jul 22, 2014 9:03 pm
Is there any documentation how revisions will be handled in the future? Checking for revision>=0x10 works for now to distinguish between model B+ and "older" Raspberry Pis. But is there a risk that there will be new A or B versions with revisions>0x10?
Tue Jul 22, 2014 9:17 pm
I think you'll need to build a look-up table.
http://elinux.org/RPi_HardwareHistory
Also beware that you'll get a different revision value for a CM.
ShiftPlusOne
Wed Jul 23, 2014 7:05 am
To avoid confusion, I've moved the topic out of the bare metal sub-forum. The way you would do things in Linux kernel and user space is very different to how you would do it your own bare metal kernel, so you didn't get a helpful answer straight away.
Future revisions are not documented, since they're assigned as they're needed. You'll need to keep an eye out for new revisions as they pop up. Perhaps adding a message asking the user to email you when the revision is not recognised may help.
AndrewS
Thu Jul 24, 2014 4:57 pm
Just for the sake of completeness, here's another method https://github.com/raspberrypi/noobs/bl ... il.cpp#L99
Return to “C/C++”
