peterpi
Memory management within a malloc'd block.
Fri May 30, 2014 1:33 pm
In Linux, is there a library that takes a large block of memory (e.g. a megabyte returned from malloc), and then carries out allocations and frees from within that larger block? I sometimes work with games consoles whose SDKs come with similar functions, but I can't find anything like that for Linux.
I don't want a fixed-size pool allocator; the allocation requests will not all be the same size.
It's easy enough to write a naive one (e.g. the K&R C book has an example of a first-fit), but I doubt I'm the first person to want to do so.
teh_orph
Re: Memory management within a malloc'd block.
Fri May 30, 2014 2:43 pm
I think this is the classic one; I've used it many times.
AFAIK some OS allocators are built upon it. It's one c file, and it includes mega comments in the header telling you how to use it.
http://g.oswego.edu/dl/html/malloc.html
Customise it the way you want by settings certain includes and off you go. You will want the functions that start with mspace_*.
Return to “C/C++”
