dirkwillem
Clang++ not compiling C++ code, undefined operator new
Thu May 29, 2014 2:11 pm
Hello
I'm trying to program C++ on my Raspberry Pi. I need to use Clang because my library uses the Blocks API. But the problem is that I can't get Clang to compile a simple program:
class Foo{
int main(){
	Foo* foo = new Foo();
I compile it with the following command:
clang++ -lstdc++ main.cpp -o main
And then it gives me an error:
/tmp/main-E0E0nf.o: In function `main':
main.cpp:(.text+0x18): undefined reference to `operator new(unsigned long)'
clang: error: linker command failed with exit code 1 (use -v to see invocation)
Does anyone know how to solve this?
teh_orph
Re: Clang++ not compiling C++ code, undefined operator new
Thu May 29, 2014 2:43 pm
Aren't linker objects resolved right-to-left? If you put the -lstdc++ on the right do you get the same thing?
Joe Schmoe
Thu May 29, 2014 2:55 pm
teh_orph wrote:Aren't linker objects resolved right-to-left? If you put the -lstdc++ on the right do you get the same thing?
Right idea; wrong terminology.
Things are resolved left-to-right - in a single pass (no back-tracking). The model is "eat only if you need to". I.e., each time a library object is encountered, the linker looks at its list of things that need to be resolved and scans the library object to see if the library object can resolve any of those things that need resolving. Generally, this means that the biggest things need to be at the end.
Which is a little un=intuitive, but that's the way it has always been.
teh_orph
Thu May 29, 2014 4:05 pm
Ah, a handy explanation! Does that apply to just libraries or what if you have 'loose' object files too?
(eg I've always found that loose object files need to have all their undef symbols connected up, but if that was within an unreferenced object file within a library then there would be no problem)
Joe Schmoe
Thu May 29, 2014 4:12 pm
Right. A .o file listed on the command line needs to be fulfilled, but a .o file found in a library (conventionally, either a .a or a .so file) serves as a fulfiller, not a fulfillee.
Note that a .c file listed on the command line is effectively the same thing as a .o file (unless the -c option was supplied).
enhering
Wed Nov 26, 2014 4:00 pm
Hi. I have a similar problem. I can compile individual c++ files into .o files, but when I invoke g++ to link them to the main file I receive the following errors:
[email protected] ~/mms $ make
Compiling for RASPBIAN
GPIBServer
Using built-in specs.
COLLECT_GCC=g++
COLLECT_LTO_WRAPPER=/usr/lib/gcc/arm-linux-gnueabihf/4.6/lto-wrapper
Target: arm-linux-gnueabihf
Configured with: ../src/configure -v --with-pkgversion='Debian 4.6.3-14+rpi1' --with-bugurl=file:///usr/share/doc/gcc-4.6/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.6 --enable-shared --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.6 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --enable-plugin --enable-objc-gc --disable-sjlj-exceptions --with-arch=armv6 --with-fpu=vfp --with-float=hard --enable-checking=release --build=arm-linux-gnueabihf --host=arm-linux-gnueabihf --target=arm-linux-gnueabihf
Thread model: posix
gcc version 4.6.3 (Debian 4.6.3-14+rpi1)
COLLECT_GCC_OPTIONS='-mabi=aapcs-linux' '-fPIE' '-w' '-v' '-I' 'src/classes' '-I' 'src/classes/if' '-I' 'src/classes/inst' '-I' 'src/classes/base' '-I' 'src/classes/exp' '-I' 'src/classes/base_instruments' '-I' '/usr/local/include' '-I' '/usr/local/include/libxml2' '-I' '/usr/local/include/' '-I' '/usr/local/include' '-o' 'bin/GPIBServer' '-shared-libgcc' '-march=armv6' '-mfloat-abi=hard' '-mfpu=vfp'
/usr/lib/gcc/arm-linux-gnueabihf/4.6/cc1plus -quiet -v -I src/classes -I src/classes/if -I src/classes/inst -I src/classes/base -I src/classes/exp -I src/classes/base_instruments -I /usr/local/include -I /usr/local/include/libxml2 -I /usr/local/include/ -I /usr/local/include -imultilib . -imultiarch arm-linux-gnueabihf -D_GNU_SOURCE src/executables/GPIBServer.cpp -quiet -dumpbase GPIBServer.cpp -mabi=aapcs-linux -march=armv6 -mfloat-abi=hard -mfpu=vfp -auxbase GPIBServer -w -version -fPIE -o /tmp/cc8n2Old.s
GNU C++ (Debian 4.6.3-14+rpi1) version 4.6.3 (arm-linux-gnueabihf)
compiled by GNU C version 4.6.3, GMP version 5.0.5, MPFR version 3.1.0-p10, MPC version 0.9
GGC heuristics: --param ggc-min-expand=55 --param ggc-min-heapsize=47855
ignoring nonexistent directory "/usr/local/include/arm-linux-gnueabihf"
ignoring nonexistent directory "/usr/lib/gcc/arm-linux-gnueabihf/4.6/../../../../arm-linux-gnueabihf/include"
ignoring nonexistent directory "src/classes/inst"
ignoring duplicate directory "/usr/local/include"
as it is a non-system directory that duplicates a system directory
ignoring nonexistent directory "/usr/local/include/libxml2"
ignoring duplicate directory "/usr/local/include/"
#include "..." search starts here:
#include <...> search starts here:
src/classes
src/classes/if
src/classes/base
src/classes/exp
/usr/include/c++/4.6/arm-linux-gnueabihf/.
/usr/include/c++/4.6/backward
/usr/lib/gcc/arm-linux-gnueabihf/4.6/include
/usr/local/include
/usr/lib/gcc/arm-linux-gnueabihf/4.6/include-fixed
/usr/include/arm-linux-gnueabihf
/usr/include
End of search list.
Compiler executable checksum: 64a5da90acce21afabe8e916f286e44e
as -march=armv6 -mfloat-abi=hard -mfpu=vfp -meabi=5 -o /tmp/ccWSuWXr.o /tmp/cc8n2Old.s
COMPILER_PATH=/usr/lib/gcc/arm-linux-gnueabihf/4.6/:/usr/lib/gcc/arm-linux-gnueabihf/4.6/:/usr/lib/gcc/arm-linux-gnueabihf/:/usr/lib/gcc/arm-linux-gnueabihf/4.6/:/usr/lib/gcc/arm-linux-gnueabihf/
LIBRARY_PATH=/usr/lib/gcc/arm-linux-gnueabihf/4.6/:/usr/lib/gcc/arm-linux-gnueabihf/4.6/../../../arm-linux-gnueabihf/:/usr/lib/gcc/arm-linux-gnueabihf/4.6/../../../:/lib/arm-linux-gnueabihf/:/lib/:/usr/lib/arm-linux-gnueabihf/:/usr/lib/
/usr/lib/gcc/arm-linux-gnueabihf/4.6/collect2 --sysroot=/ --build-id --no-add-needed --eh-frame-hdr -dynamic-linker /lib/ld-linux-armhf.so.3 -X --hash-style=both -m armelf_linux_eabi -o bin/GPIBServer /usr/lib/gcc/arm-linux-gnueabihf/4.6/../../../arm-linux-gnueabihf/crt1.o /usr/lib/gcc/arm-linux-gnueabihf/4.6/../../../arm-linux-gnueabihf/crti.o /usr/lib/gcc/arm-linux-gnueabihf/4.6/crtbegin.o -L/usr/lib/gcc/arm-linux-gnueabihf/4.6 -L/usr/lib/gcc/arm-linux-gnueabihf/4.6/../../../arm-linux-gnueabihf -L/usr/lib/gcc/arm-linux-gnueabihf/4.6/../../.. -L/lib/arm-linux-gnueabihf -L/usr/lib/arm-linux-gnueabihf /tmp/ccWSuWXr.o bin/o/Logger.o bin/o/TCPServer.o bin/o/FileUtils.o bin/o/PrologixGPIB.o bin/o/GPIBd.o -lncurses -lstdc++ -lstdc++ -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /usr/lib/gcc/arm-linux-gnueabihf/4.6/crtend.o /usr/lib/gcc/arm-linux-gnueabihf/4.6/../../../arm-linux-gnueabihf/crtn.o
bin/o/TCPServer.o: In function `TCPServer::TCPServer()':
src/classes/TCPServer.cpp:(.text+0x74): undefined reference to `operator new(unsigned long)'
bin/o/PrologixGPIB.o: In function `PrologixGPIB::PrologixGPIB()':
src/classes/if/PrologixGPIB.cpp:(.text+0x68): undefined reference to `operator new(unsigned long)'
src/classes/if/PrologixGPIB.cpp:(.text+0xd8): undefined reference to `operator new[](unsigned long)'
bin/o/GPIBd.o: In function `GPIBd::GPIBd()':
src/classes/GPIBd.cpp:(.text+0x7c): undefined reference to `operator new(unsigned long)'
src/classes/GPIBd.cpp:(.text+0xb4): undefined reference to `operator new(unsigned long)'
bin/o/GPIBd.o: In function `GPIBd::SetInterfaceType(GPIBInterfaceType)':
src/classes/GPIBd.cpp:(.text+0x364): undefined reference to `operator new(unsigned long)'
collect2: ld returned 1 exit status
GNUmakefile:234: recipe for target 'bin/GPIBServer' failed
make: *** [bin/GPIBServer] Error 1
Any idea how can I solve this?
My makefile is:
#  This file is part of Multi Measuremendt System (MMS)                 *
#  Copyright (C) 2013  Eduardo Novaes Hering                            *
#  Multi Measurement System is free software: you can redistribute      *
#  it and/or modify it under the terms of the GNU General Public        *
#  License as published by the Free Software Foundation, either         *
#  version 3 of the License, or(at your option) any later version.      *
#  This program is distributed in the hope that it will be useful,      *
#  but WITHOUT ANY WARRANTY; without even the implied warranty of       *
#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the        *
#  GNU General Public License for more details.                         *
#  You should have received a copy of the GNU General Public License    *
#  along with this program.  If not, see <http://www.gnu.org/licenses/> *
CLASSES_SRC_DIR=src/classes
EXEC_SRC_DIR=src/executables
CGIDIR=src/cgi
BINDIR=bin
OBJDIR=$(BINDIR)/o
ifneq ($(wildcard FREEBSD),)
  OS=FREEBSD
endif
ifneq ($(wildcard MACOS),)
  OS=MACOS
endif
ifneq ($(wildcard RASPBIAN),)
  OS=RASPBIAN
endif
ifeq ($(OS),MACOS)
  COMPILER=llvm-g++ -w
  ICGICC=-I/usr/include
  LCGICC=-L/usr/lib -L/Users/enhering/tmp/cgicc-3.2.12/cgicc/.libs -lcgicc
  IGSL=-I/opt/local/include/
  LGSL=-L/opt/local/lib -lgsl
  IMGL=-I/usr/local/include/
  LMGL=-L/usr/local/lib -lmgl
  IXML=-I/opt/local/include/libxml2
  LXML=-L/opt/local/lib -lxml2
  DOCUMENT_ROOT=~/Sites/mms
  CGI_BIN=~/Sites/
endif
ifeq ($(OS),FREEBSD)
  COMPILER=clang++ -w
  ICGICC=-I/usr/local/include
  LCGICC=-L/usr/local/lib -lcgicc
  IGSL=-I/usr/local/include/
  LGSL=-L/usr/local/lib -lgsl
  IXML=-I/usr/local/include/libxml2
  LXML=-L/usr/local/lib -lxml2
  DOCUMENT_ROOT=/usr/home/$(USERNAME)/public_html
  CGI_BIN=/usr/home/$(USERNAME)/public_html
endif
ifeq ($(OS),RASPBIAN)
  COMPILER=g++ -mabi=aapcs-linux -fPIE -w -v
endif
INCLUDES=-Isrc/classes -Isrc/classes/if -Isrc/classes/inst -Isrc/classes/base -Isrc/classes/exp -Isrc/classes/base_instruments $(ICGICC) $(IXML) $(IGSL) $(IMGL)
HGURL=ssh://xp-dev.com/multi-measurement-system
all: space os $(BINDIR)/GPIBServer $(BINDIR)/Example  done count
experimental: $(OBJDIR)/MMSProtocol.o $(BINDIR)/ProtocolTest
os:
	@echo 'Compiling for '$(OS)
done:
	@echo "done."
space:
	@echo ''
	@echo ''
	@echo ''
#EXPERIMENTAL CODE
$(OBJDIR)/MMSProtocol.o: $(CLASSES_SRC_DIR)/exp/MMSProtocol.cpp $(CLASSES_SRC_DIR)/exp/MMSProtocol.h
	@echo 'Experimental MMSProtocol.o'
	@$(COMPILER) -c $(CLASSES_SRC_DIR)/exp/MMSProtocol.cpp $(INCLUDES) -o $(OBJDIR)/MMSProtocol.o
$(OBJDIR)/Parser.o: $(CLASSES_SRC_DIR)/exp/Parser.cpp $(CLASSES_SRC_DIR)/exp/Parser.h $(OBJDIR)/Lexer.o
	@echo 'Experimental Parser.o'
	@$(COMPILER) -c $(CLASSES_SRC_DIR)/exp/Parser.cpp $(INCLUDES) -o $(OBJDIR)/Parser.o
$(OBJDIR)/Lexer.o: $(CLASSES_SRC_DIR)/exp/Lexer.cpp $(CLASSES_SRC_DIR)/exp/Lexer.h $(OBJDIR)/Token.o
	@echo 'Experimental Lexer.o'
	@$(COMPILER) -c $(CLASSES_SRC_DIR)/exp/Lexer.cpp $(INCLUDES) -o $(OBJDIR)/Lexer.o
$(OBJDIR)/Token.o: $(CLASSES_SRC_DIR)/exp/Token.cpp $(CLASSES_SRC_DIR)/exp/Token.h
	@echo 'Experimental Token.o'
	@$(COMPILER) -c $(CLASSES_SRC_DIR)/exp/Token.cpp $(INCLUDES) -o $(OBJDIR)/Token.o
# TESTED CODE
$(BINDIR)/ProtocolTest: $(EXEC_SRC_DIR)/ProtocolTest.cpp $(EXEC_SRC_DIR)/ProtocolTest.h $(OBJDIR)/MMSProtocol.o $(OBJDIR)/MMSClass.o $(OBJDIR)/FileUtils.o
	@echo 'ProtocolTest'
	@$(COMPILER) $(EXEC_SRC_DIR)/ProtocolTest.cpp             \
							 $(OBJDIR)/MMSProtocol.o 											\
							 $(OBJDIR)/MMSClass.o 												\
							 $(OBJDIR)/MMSError.o 												\
							 $(OBJDIR)/MMSConfig.o                        \
							 $(OBJDIR)/Logger.o                           \
							 $(OBJDIR)/FileUtils.o                        \
							 $(INCLUDES) $(LXML) -lncurses                \
							 -o $(BINDIR)/ProtocolTest
$(BINDIR)/CreateCalibTable: $(EXEC_SRC_DIR)/CreateCalibTable.cpp $(EXEC_SRC_DIR)/CreateCalibTable.h
	@echo 'CreateCalibTable'
	@$(COMPILER) $(EXEC_SRC_DIR)/CreateCalibTable.cpp $(INCLUDES) -o $(BINDIR)/CreateCalibTable
$(BINDIR)/Setup1: $(EXEC_SRC_DIR)/Setup1.cpp $(EXEC_SRC_DIR)/Setup1.h $(OBJDIR)/CryoCon62.o $(OBJDIR)/FileUtils.o
	@echo 'Setup1'
	@$(COMPILER) $(EXEC_SRC_DIR)/Setup1.cpp  \
               $(OBJDIR)/TCPClient.o       \
               $(OBJDIR)/GPIBInstrument.o  \
               $(OBJDIR)/CryoCon62.o       \
               $(INCLUDES)                 \
               -o $(BINDIR)/Setup1
$(CGIDIR)/TempControllerCGI.cgi: $(EXEC_SRC_DIR)/TempControllerCGI.cpp $(EXEC_SRC_DIR)/TempControllerCGI.h $(OBJDIR)/MMSCGI.o $(OBJDIR)/GenTempControllerCGI.o
	@echo 'TempControllerCGI.cgi'
	@$(COMPILER) $(EXEC_SRC_DIR)/TempControllerCGI.cpp  \
               $(OBJDIR)/ConfigTempController.o       \
               $(OBJDIR)/GenTempControllerCGI.o       \
               $(OBJDIR)/MMSCGI.o                     \
               $(INCLUDES) $(LCGICC) $(LMGL) $(LXML)  \
               -o $(CGIDIR)/TempControllerCGI.cgi
$(BINDIR)/TempController: $(EXEC_SRC_DIR)/TempController.cpp $(EXEC_SRC_DIR)/TempController.h $(OBJDIR)/GenTempController.o $(OBJDIR)/ConfigTempController.o
	@echo 'TempController'
	@$(COMPILER) $(EXEC_SRC_DIR)/TempController.cpp  \
               $(OBJDIR)/GenTempController.o       \
               $(INCLUDES) $(LXML)                 \
              -o $(BINDIR)/TempController
$(OBJDIR)/CryoCon62.o: $(CLASSES_SRC_DIR)/inst/CryoCon62.cpp $(CLASSES_SRC_DIR)/inst/CryoCon62.h $(OBJDIR)/GPIBInstrument.o
	@echo 'CryoCon62.o'
	@$(COMPILER) -c $(CLASSES_SRC_DIR)/inst/CryoCon62.cpp $(INCLUDES) -o $(OBJDIR)/CryoCon62.o
$(OBJDIR)/GenTempControllerCGI.o: $(CLASSES_SRC_DIR)/GenTempControllerCGI.cpp $(CLASSES_SRC_DIR)/GenTempControllerCGI.h $(OBJDIR)/ConfigTempController.o
	@echo 'GenTempControllerCGI.o'
	@$(COMPILER) -c $(CLASSES_SRC_DIR)/GenTempControllerCGI.cpp $(INCLUDES) $(LXML) $(LGS) $(LMGL) $(LCGICC) -o $(OBJDIR)/GenTempControllerCGI.o
$(OBJDIR)/MMSCGI.o: $(CLASSES_SRC_DIR)/MMSCGI.cpp $(CLASSES_SRC_DIR)/MMSCGI.h
	@echo 'MMSCGI.o'
	@$(COMPILER) -c $(CLASSES_SRC_DIR)/MMSCGI.cpp $(INCLUDES) $(LMGL) $(LCGICC) -o $(OBJDIR)/MMSCGI.o
$(OBJDIR)/GenTempController.o: $(CLASSES_SRC_DIR)/GenTempController.cpp $(CLASSES_SRC_DIR)/GenTempController.h $(OBJDIR)/ConfigTempController.o
	@echo 'GenTempController.o'
	@$(COMPILER) -c $(CLASSES_SRC_DIR)/GenTempController.cpp $(INCLUDES) $(LXML) -o $(OBJDIR)/GenTempController.o
$(OBJDIR)/ConfigTempController.o: $(CLASSES_SRC_DIR)/ConfigTempController.cpp $(CLASSES_SRC_DIR)/ConfigTempController.h
	@echo 'ConfigTempController.o'
	@$(COMPILER) -c $(CLASSES_SRC_DIR)/ConfigTempController.cpp $(INCLUDES) $(LXML) -o $(OBJDIR)/ConfigTempController.o
$(BINDIR)/Example: $(EXEC_SRC_DIR)/Example.cpp $(EXEC_SRC_DIR)/Example.h $(OBJDIR)/MMSInstrument.o
	@echo 'Example'
	@$(COMPILER) $(EXEC_SRC_DIR)/Example.cpp     \
               $(OBJDIR)/MMSInstrument.o       \
               -lncurses                       \
               -o $(BINDIR)/Example
$(OBJDIR)/MMSInstrument.o: $(CLASSES_SRC_DIR)/base_instruments/MMSInstrument.cpp $(CLASSES_SRC_DIR)/base_instruments/MMSInstrument.h $(OBJDIR)/GPIBInstrument.o
	@echo 'MMSInstrument.o'
	@$(COMPILER) -c $(CLASSES_SRC_DIR)/base_instruments/MMSInstrument.cpp $(INCLUDES) -o $(OBJDIR)/MMSInstrument.o
$(OBJDIR)/GPIBInstrument.o: $(CLASSES_SRC_DIR)/base_instruments/GPIBInstrument.cpp $(CLASSES_SRC_DIR)/base_instruments/GPIBInstrument.h $(OBJDIR)/MMSClass.o $(OBJDIR)/TCPClient.o
	@echo 'GPIBInstrument.o'
	@$(COMPILER) -c $(CLASSES_SRC_DIR)/base_instruments/GPIBInstrument.cpp $(INCLUDES) -o $(OBJDIR)/GPIBInstrument.o
$(OBJDIR)/TCPClient.o: $(CLASSES_SRC_DIR)/TCPClient.cpp $(CLASSES_SRC_DIR)/TCPClient.h $(OBJDIR)/MMSClass.o
	@echo 'TCPClient.o'
	@$(COMPILER) -c $(CLASSES_SRC_DIR)/TCPClient.cpp $(INCLUDES) -o $(OBJDIR)/TCPClient.o
$(BINDIR)/GPIBServer: $(EXEC_SRC_DIR)/GPIBServer.cpp $(EXEC_SRC_DIR)/GPIBServer.h $(OBJDIR)/GPIBd.o $(OBJDIR)/FileUtils.o
	@echo 'GPIBServer'
	@$(COMPILER) $(EXEC_SRC_DIR)/GPIBServer.cpp  \
               $(OBJDIR)/TCPServer.o           \
               $(OBJDIR)/PrologixGPIB.o        \
               $(OBJDIR)/GPIBd.o               \
               $(INCLUDES)                     \
               -lncurses                       \
               -o $(BINDIR)/GPIBServer         \
               -lstdc++                        \
$(OBJDIR)/GPIBd.o: $(CLASSES_SRC_DIR)/GPIBd.cpp $(CLASSES_SRC_DIR)/GPIBd.h $(OBJDIR)/TCPServer.o $(OBJDIR)/PrologixGPIB.o
	@echo 'GPIBd.o'
	@$(COMPILER) -c $(CLASSES_SRC_DIR)/GPIBd.cpp $(INCLUDES) -DUSEPROLOGIXGPIB=1 -o $(OBJDIR)/GPIBd.o
$(OBJDIR)/TCPServer.o: $(CLASSES_SRC_DIR)/TCPServer.cpp $(CLASSES_SRC_DIR)/TCPServer.h $(OBJDIR)/Logger.o
	@echo 'TCPServer.o'
	@$(COMPILER) $(RASP_PI) -c $(CLASSES_SRC_DIR)/TCPServer.cpp $(INCLUDES) -o $(OBJDIR)/TCPServer.o
$(OBJDIR)/PrologixGPIB.o: $(CLASSES_SRC_DIR)/if/PrologixGPIB.cpp $(CLASSES_SRC_DIR)/if/PrologixGPIB.h
	@echo 'PrologixGPIB.o'
	@$(COMPILER) -c $(CLASSES_SRC_DIR)/if/PrologixGPIB.cpp $(INCLUDES) -o $(OBJDIR)/PrologixGPIB.o
$(OBJDIR)/MMSClass.o: $(CLASSES_SRC_DIR)/base/MMSClass.cpp $(CLASSES_SRC_DIR)/base/MMSClass.h $(OBJDIR)/Logger.o $(OBJDIR)/MMSError.o $(OBJDIR)/MMSConfig.o
	@echo 'MMSClass.o'
	@$(COMPILER) -c $(CLASSES_SRC_DIR)/base/MMSClass.cpp $(INCLUDES) -o $(OBJDIR)/MMSClass.o
$(OBJDIR)/MMSConfig.o: $(CLASSES_SRC_DIR)/base/MMSConfig.cpp $(CLASSES_SRC_DIR)/base/MMSConfig.h $(OBJDIR)/Logger.o $(OBJDIR)/MMSError.o
	@echo 'MMSConfig.o'
	@$(COMPILER) -c $(CLASSES_SRC_DIR)/base/MMSConfig.cpp $(INCLUDES) -o $(OBJDIR)/MMSConfig.o
$(OBJDIR)/MMSError.o: $(CLASSES_SRC_DIR)/base/MMSError.cpp $(CLASSES_SRC_DIR)/base/MMSError.h $(OBJDIR)/Logger.o
	@echo 'MMSError.o'
	@$(COMPILER) -c $(CLASSES_SRC_DIR)/base/MMSError.cpp -o $(OBJDIR)/MMSError.o
$(OBJDIR)/Logger.o: $(CLASSES_SRC_DIR)/base/Logger.cpp $(CLASSES_SRC_DIR)/base/Logger.h $(OBJDIR)/FileUtils.o
	@echo 'Logger.o'
	@$(COMPILER) -c $(CLASSES_SRC_DIR)/base/Logger.cpp -o $(OBJDIR)/Logger.o
$(OBJDIR)/FileUtils.o: $(CLASSES_SRC_DIR)/base/FileUtils.cpp $(CLASSES_SRC_DIR)/base/FileUtils.h
	@echo 'FileUtils.o'
	@$(COMPILER) -c $(CLASSES_SRC_DIR)/base/FileUtils.cpp -o $(OBJDIR)/FileUtils.o
clean:
	@rm -rf $(BINDIR)/GPIBServer*
	@rm -rf $(BINDIR)/CreateCalibTable*
	@rm -rf $(BINDIR)/Setup1*
	@rm -rf $(BINDIR)/ProtocolTest*
	@rm -rf $(BINDIR)/TempController*
	@rm -rf $(BINDIR)/Example*
	@rm -rf $(CGIDIR)/TempControllerCGI.cgi*
	@rm -rf $(OBJDIR)/GenTempControllerCGI.o*
	@rm -rf $(OBJDIR)/*.log
	@rm -rf $(BINDIR)/*.log
	@rm -rf bin/o/*
	@touch bin/o/OBJECT_FILES_HERE
	@rm -rf src/WebInterface/cgi/GenTempControllerCGI.cgi
	@echo "Cleaned."
pull:
	@hg pull $(HGURL)
	@echo "Pulled last version from repo."
	@hg update
	@echo "Updated working version."
push:
	@hg push $(HGURL)
	@echo "Pushed current version to repo."
resolve-theirs-good:
	@hg resolve -t internal:other --all
install-web:
	@echo "Installing web interface:"
	@rm -rf $(DOCUMENT_ROOT)
	@rm -rf $(CGI_BIN)/*
	@mkdir $(DOCUMENT_ROOT)
	@chmod 755 $(DOCUMENT_ROOT)
	@echo "  Removed and recreated mms directory on apache server."
	@cp -Rf $(CGIDIR)/html/* $(DOCUMENT_ROOT)
	@chmod -R 755 $(DOCUMENT_ROOT)
	@cp $(CGIDIR)/css/MyStyle.css $(CGI_BIN)
	@cp $(CGIDIR)/TempControllerCGI.cgi $(CGI_BIN)
	@chmod -R 777 $(CGI_BIN)
	@echo "  Copied html files to their locations."
	@rm -f $(CGI_BIN)/logs
	@ln -s `pwd`/logs $(CGI_BIN)/logs
	@chmod -R 755 $(CGI_BIN)/logs
	@echo "  Linked logs directory to its location."
	@rm -f $(CGI_BIN)/config.xml
	@ln -s `pwd`/conf/cryocon62-1.xml $(CGI_BIN)/config.xml
	@echo "  Linked configuration files."
	@echo "Done."
count:
	@counters/increase_build_counter.sh
enhering
Wed Nov 26, 2014 6:09 pm
Solved.
ARM g++ compiler apparently does not know anything about the operators new and delete. Check these references to see if you understand why:
http://www.mbedded.ninja/programming/mi ... oc-creator
http://stackoverflow.com/questions/7015 ... deletevoid
So I created a file called MMSEmbedded.cpp with the following content:
#ifndef __MMSEMBEDDED_CPP_
#define __MMSEMBEDDED_CPP_
  #if ARM_PLATFORM==1
  #include <stdlib.h>
  void* operator new(size_t size) {
    return malloc(size);
  void operator delete(void* ptr) {
    free(ptr);
  void * operator new[](size_t size) {
  void operator delete[](void * ptr) {
    free(ptr);
  #endif
#endif
and linked it to the main executable using the following call on the makefile of the post above:
$(BINDIR)/GPIBServer: $(EXEC_SRC_DIR)/GPIBServer.cpp $(EXEC_SRC_DIR)/GPIBServer.h $(OBJDIR)/GPIBd.o $(OBJDIR)/FileUtils.o $(OBJDIR)/MMSEmbedded.o
	@echo 'GPIBServer'
	             $(OBJDIR)/MMSEmbedded.o         \
               $(OBJDIR)/GPIBd.o               \
               $(INCLUDES)                     \
               -lncurses                       \
And now it is compiling on Raspberry Pi.
Thanks for your attention. I hope this helps.
Return to “C/C++”
