pt254
wiringPi undefined Reference
Tue Jun 05, 2012 8:16 pm
Hallo,
I want to use the gpio pins and the wiring Pi lib looked good to me (thanks for writing it, if the programmer sees this here).
But when I try to compile my programm I get the errors:
undefined reference to 'wiringPiSetup()'
undefined reference to 'pinMode(int,int)'
undefined reference to 'digitalRead(int)'
collect2: ld returned 1 exit status
I use: g++ pins.cpp -I/usr/local/include -L/usr/local/lib -lwiringPi
my code:
#include <wiringPi.h>
#include <iostream>
using namespace std;
int main()
    if (wiringPiSetup()==-1)
    return 1;
    pinMode(0,INPUT);
    bool wasPressed=false;
    int a;
    while (true)
    a=digitalRead(0);
    if (a==0 && wasPressed) wasPressed=false;
    if (a==1 && !wasPressed)
    cout<<"pressed"<<endl;
    wasPressed=true;
i copied the command from the wiring pi page (modified it a little as i want to use c++)
what am I doing wrong?
higwoth1
Re: wiringPi undefined Reference
Wed Jun 06, 2012 10:15 am
If you use gcc instead of g++ it will compile, yes?
I know that doesn't fix your problem as you want to use c++, but it might be a clue as to what is going wrong, for you or somebody else to figure out.
tufty
Wed Jun 06, 2012 10:33 am
If it works with gcc and not g++, it's probably wiringPi.h that's missing the habitual
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
C++ wrapper for C functions. Without this, the compiler mangles the names into something C++ like, and then (unsurprisingly) can't find them in the linked library.
Simon
pt254
Wed Jun 06, 2012 4:06 pm
thank you, there was no wrapper in the lib. after adding that i works.
Ced
Fri Jan 04, 2013 10:33 pm
pt254 wrote:thank you, there was no wrapper in the lib. after adding that i works.
What did you change to it work ?
IanH2
Sat Jan 05, 2013 8:06 am
Something like this will work:
extern "C" {
To see a symbol which has been compiled with a C compiler (the wiringPi functions) from within a C++ program (this one) you need to use extern "C" when declaring it. Fortunately C++ is fairly forgiving about where you do this, so the idiom above works perfectly well.
Some C libraries have 'C++ friendly' header files which do this automatically, but it looks like wiringPi isn't one of them (yet).
https://github.com/IanHarvey
Ced
Sat Jan 05, 2013 3:32 pm
extern "C" {
where you added these lignes ?
[email protected]
Sat Jan 05, 2013 4:01 pm
wiringPi has had those wrappers for a very long time now. (6+ months) Where did you get wiringPi?
The correct way to get it now is via GIT:
cd
git clone git://git.drogon.net/wiringPi
cd wiringPi
./build
-Gordon
Gordons projects: https://projects.drogon.net/
[email protected]
Sat Jan 05, 2013 4:03 pm
IanH2 wrote: Some C libraries have 'C++ friendly' header files which do this automatically, but it looks like wiringPi isn't one of them (yet).
witingPi is one of them and has been for a long time now.
something else is going on - possibly not having the right linker flags. Just as you need -lm to include the maths library, you need -lwiringPi to include the wiringPi library.
-Gordon
Ced
Sun Jan 06, 2013 1:27 am
cd
cd wiringPi
./build
-Gordon
i install whith this way, but i have this message i compile :
"main.cpp:(.text.startup+0x147): undefined reference to `digitalRead'"
[email protected]
Sun Jan 06, 2013 9:11 am
cd
cd wiringPi
./build
-Gordon
How are you compiling/linking? You need to add -lwiringPi to the compile line.
-Gordon
Ced
Mon Jan 07, 2013 7:04 pm
i include wiringPi in the main
#include <QCoreApplication>
#include <iostream>
#include <unistd.h>
#include <stdlib.h>
#include <chauffage.h>
#include <eclairage.h>
#include <led_strip.h>
#include <pompe_air.h>
#include <pompe_eau.h>
[email protected]
Mon Jan 07, 2013 7:19 pm
Ced wrote:i include wiringPi in the main
#include <iostream>
#include <unistd.h>
#include <stdlib.h>
That's good, but if you get an "undefined reference" error, then it means that the compiled program has not been linked with the wiringPi library.
If you are compiling by hand, then you need to add -lwiringPi to the command-line. If you are using some sort of IDE, then you must work out how to include the wiringPi library inside that IDE.
-Gordon
Ced
Mon Jan 07, 2013 10:18 pm
I solve my problem, for those who use qt creator. You must add a line in the file .pro
LIBS += -L/usr/local/include -lwiringPi
photomankc
Sat Jan 26, 2013 6:32 am
I have not been able to get past the undefined reference errors either. I'm using Arch and installed the library via the package system. It compiles fine but fails to link. Below is the output from the make file:
[email protected] battmond]$ make
g++ -Wall -std=c++0x -c  -c i2c.cpp -o build/i2c.o
g++ -Wall -std=c++0x -c  -c battmond.cpp -o build/battmond.o
battmond.cpp: In function 'int main()':
battmond.cpp:68:9: warning: unused variable 'status' [-Wunused-variable]
g++ -Wall -std=c++0x -c  -c ADC_MCP3221.cpp -o build/ADC_MCP3221.o
g++ -lwiringPi build/i2c.o build/battmond.o build/ADC_MCP3221.o -o ./bin/battmond
build/battmond.o: In function `configureGPIO()':
battmond.cpp:(.text+0x644): undefined reference to `wiringPiSetup'
collect2: error: ld returned 1 exit status
make: *** [all] Error 1
I'm at a loss to understand where I go from here?
photomankc
Sat Jan 26, 2013 6:59 am
Never mind. Discovered that it matters where the library directive is included. Had to change the "all" target to this:
all: $(OBJECTS)
        $(LD) $(LDFLAGS) $(OBJECTS) -o $(BIN) -lwiringPi
so that the compile line generated became this:
g++ -L/usr/lib build/i2c.o build/battmond.o build/ADC_MCP3221.o -o ./bin/battmond -lwiringPi
Then it compiled and linked correctly. Sorry, always seems like you figure it out 5 minutes after you post in frustration.
[email protected]
Sat Jan 26, 2013 11:28 am
photomankc wrote: Then it compiled and linked correctly. Sorry, always seems like you figure it out 5 minutes after you post in frustration.
Yes, -lwiringPi is the trick. I've been re-writing some of the on-line documention for it, and have included this now. It's one of those obvious things if you've been doing it for the past 30 years, but...
https://projects.drogon.net/raspberry-p ... functions/
Also, if installing it on Arch, the system doesn't include /usr/local/lib by default, so you need to add that into /etc/ld.so.conf and then run sudo ldconfig
-Gordon
JakouC
Wed Dec 17, 2014 7:18 pm
Solution is easier than it looks like,
You must think that library is necesary to compile, so if you compile it in your PC without the RPi compilator it never will work. So you have 2 options.
1.- Compile it in the raspberry (is easier) you only need to compile the libraries and then copy the .so to your libs directory
2.- Make another cross compile for this library in your pc.
I'm working in this way and I can cross debugging and execute it remotely.
Austin911
Tue May 26, 2015 11:37 am
Hello, i had the same problem with the "Geany " editor.
" undifened reference " when build.
Just insert " -lwiringPi " in the " build " menu / " set build commands " / " build " command
it gives : gcc -Wall -lwiringPi -o "%e" "%f"
Thanks to Gordon for " WiringPi " :P
Nauti
Fri Dec 09, 2016 12:25 am
Since I was struggling with this ridiculous task of compiling a lousy little file (nes.c) for nearly two hours, before a friend came to the rescue, I feel I should contribute to save others the frustration. I kept getting the error:
/tmp/ccYcuirL.o: In function `main':
nes.c:(.text+0x60): undefined reference to `setupNesJoystick'
nes.c:(.text+0x98): undefined reference to `readNesJoystick'
Tried to solve it in many ways with no desireable result. Tried other files in the example folder with up to 30 errors. His solution was simple: "gcc -lwiringPi -lwiringPiDev nes.c" and it compiled straight away.
[email protected]
Fri Dec 09, 2016 6:22 am
Nauti wrote:Since I was struggling with this ridiculous task of compiling a lousy little file (nes.c) for nearly two hours, before a friend came to the rescue, I feel I should contribute to save others the frustration. I kept getting the error:
Or, since there is a Makefile, just type:
  make nes
-Gordon
Lineaxe
Fri Dec 09, 2016 1:29 pm
I managed to get it all going with QT c++ . This gives you a drag & drop environment to create windows & widgets as well as interface with wiring pi GPIO . Are you using Eclipse or Visual Studio to create c++ instead of QT ? I Can't help hook into those IDE's :)
Akhilesh_Mehta
Fri Mar 16, 2018 5:38 am
I am using Raspberry Pi Model B V1.1
i want to blink the LED with Raspberry Pi Board
i have installed wiringPi as per below link.
http://www.electronicwings.com/raspberr ... spberry-pi
When I am compiling the program as below :
#include <stdio.h>
#define LedPin 0
int main(void) {
if(wiringPiSetup() == -1) { //when initialize wiringPi failed, print message to screen
printf("setup wiringPi failed !\n");
return -1;
pinMode(LedPin, OUTPUT);
while(1) {
digitalWrite(LedPin, LOW); //led on
printf("led on\n");
delay(1000); // wait 1 sec
digitalWrite(LedPin, HIGH); //led off
printf("led off\n");
return 0;
though i have inserted -lwiringPi in my make file. (Linked with Library)
It is showing Error messages like :
gcc -Wall -I.. -O3 -c -o SPI_LCD.o SPI_LCD.c
gcc -o SPI_LCD SPI_LCD.c -lwiringPi
/usr/lib/gcc/arm-linux-gnueabihf/5/../../../../lib/libwiringPi.so: undefined reference to `crypt'
Makefile:22: recipe for target 'SPI_LCD' failed
/usr/lib/gcc/arm-linux-gnueabihf/5/../../../../lib/libwiringPi.so: undefined reference to `rint'
/usr/lib/gcc/arm-linux-gnueabihf/5/../../../../lib/libwiringPi.so: undefined reference to `pthread_join'
/usr/lib/gcc/arm-linux-gnueabihf/5/../../../../lib/libwiringPi.so: undefined reference to `pthread_create'
/usr/lib/gcc/arm-linux-gnueabihf/5/../../../../lib/libwiringPi.so: undefined reference to `pow'
/usr/lib/gcc/arm-linux-gnueabihf/5/../../../../lib/libwiringPi.so: undefined reference to `shm_open'
/usr/lib/gcc/arm-linux-gnueabihf/5/../../../../lib/libwiringPi.so: undefined reference to `pthread_cancel'
make: *** [SPI_LCD] Error 1
Please help me as soon as possible.
SteveSpencer
Fri Mar 16, 2018 11:41 am
As well as -lwiringpi, you need -lpthread -lcrypt -lm, as these undefined references are in those libraries, respectively.
Steve S
No, I can't think of anything funny that won't offend someone if they want it to...
Return to “C/C++”
