roycejp
WiringPi: question about multiThread program
Mon Mar 31, 2014 12:37 pm
I have made a C program under gcc using wiringPi, which is working well.
I want tp try multi threading to improve performance of certain part of my code.
I'm not clear about the piLock / piUnLock functions.
To quote from the wiringPi reference page,
piLock (int keyNum) ;
piUnlock (int keyNum) ;
These allow you to synchronise variable updates from your main program to any threads running in your program. keyNum is a number from 0 to 3 and represents a “key”. When another process tries to lock the same key, it will be stalled until the first process has unlocked the same key.
So does this mean I can have only 4 (0 to 3) shared variables between my 'main' and all another threads ?
How to handle more shared variables ?
Can anyone shed some light ?
Thanks !
[email protected]
Re: WiringPi: question about multiThread program
Mon Mar 31, 2014 6:26 pm
roycejp wrote:Hello,
Thanks !
You can have millions - they're just there, like a lot of wiringPi as "helpers". To make life easy for you.
If you want more, just look at the source code, (piThread.c) or type: man pthread_mutex_lock
-Gordon
roycejp
Tue Apr 01, 2014 5:51 am
Thank You.
So to increase the number of shared variables I edit this line:
static pthread_mutex_t piMutexes [4] ;
and change the '4' to any value I want ?
BTW,
gives me:
No manual entry for pthread_mutex_lock
[email protected]
Tue Apr 01, 2014 10:23 am
roycejp wrote:Thank You.
Yes - however I'd suggest that if you're at that level, then you might want to look at using the functions directly.
BTW,
gives me:
I think the manual pages might not be installed by default. (as not everyone does C programming on the Pi) Try:
sudo apt-get install glibc-doc
The whole package is called pthreads:
man pthreads
Happy reading!
-Gordon
roycejp
Tue Apr 01, 2014 7:54 pm
Things are not going all that well ...
I'm getting this error (where 'webradio' is the name of my executable) :
*** glibc detected *** ./webradio: double free or corruption (top): 0x00662228 ***
and it aborts.
I'm using 2 threads besides main(), and 2 mutexes in the application.
What does this mean ?
Thank You.
[email protected]
Tue Apr 01, 2014 8:00 pm
roycejp wrote:Things are not going all that well ...
and it aborts.
Thank You.
It means you have a bug in your program - probably calling free() more than once on the same pointer. (or something is, if it's not you)
although wiringPi does use dynamic memory allocation (calloc), it never frees it up, so I'm fairly sure it's not wiringPi producing that error.
Compile it with the -g flag, enable core dumps, run it - get a core file, then run gdb on it and issue the 'where' command.
-Gordon
roycejp
Wed Apr 02, 2014 3:55 pm
I managed to track down the bug.
I was calling a shell command inside one thread using a file pointer which was also being used by the main thread.
I just created separate file pointer for the thread, and the problem went away.
Many thanks for your help !
I'll post further updates here :-)
I plan to eventually release my project to the public.
Return to “C/C++”
