CatherineH
Raspberry pi Camera not reading any bytes
Tue Feb 18, 2014 8:44 pm
I am attempting to use Chris Cumming's Raspberry Pi Camera API.
http://robotblogging.blogspot.ca/2013/1 ... i-for.html
The sample code compiles, and seems to work as expected. Attempting to write a very basic frame grab seems to result in no bytes being read however. Here's my sample code:
#include <stdio.h>
#include <unistd.h>
#include "camera.h"
#include "graphics.h"
#define MAIN_TEXTURE_WIDTH 512
#define MAIN_TEXTURE_HEIGHT 512
char tmpbuff[MAIN_TEXTURE_WIDTH*MAIN_TEXTURE_HEIGHT*4];
int main(int argc, const char **argv)
	CCamera* cam = StartCamera(MAIN_TEXTURE_WIDTH, MAIN_TEXTURE_HEIGHT,30,1,true);
	int val = cam->ReadFrame(0,tmpbuff,sizeof(tmpbuff));
	printf("Bytes read: %d\n",val);
This returns:
[email protected] ~/picamerademo $ ./picamdemo
Init camera output with 512/512
Creating pool with 3 buffers of size 1048576
Camera successfully created
Bytes read: 0
So... I'm confused as to why no bytes were read, yet no error was reported. I'm wondering if I'm supposed to do something else between StartCamera() and ReadFrame().
CatherineH
Re: Raspberry pi Camera not reading any bytes
Tue Feb 18, 2014 9:59 pm
Okay, so it turns out that if I add a call to the function BeginFrame(), it can get data locally, but it also takes over the screen, which I don't want. I'm looking into some of the other header files to see why it gets info in this call, or how to disable showing it to the screen.
CatherineH
Tue Feb 18, 2014 10:10 pm
Okay, so I think I now have my code doing what I need.
As they are defined, BeginFrame() and EndFrame() are as follows:
void BeginFrame()
	// Prepare viewport
	glViewport ( 0, 0, GScreenWidth, GScreenHeight );
	check();
	// Clear the background
	glClear(GL_COLOR_BUFFER_BIT|GL_DEPTH_BUFFER_BIT);
	check();
void EndFrame()
	eglSwapBuffers(GDisplay,GSurface);
	check();
So if I only call EndFrame() without calling BeginFrame(), it copies the camera data into a buffer without pushing into the screen.
There's probably a better way of doing this though.
wibble82
Tue Apr 15, 2014 7:45 pm
HI Catherine
The library uses opengl to do a lot of work, which is why you need to do a begin and end frame. Most opengl commands really just queue up instructions for the gpu, which get submitted when swap buffers is called. I beleive you might be able to use an opengl flush command instead to make them all happen without taking over the screen though.
Off the top of my head I can't think of simple instructions on how to use opengl without affecting the screen at all I'm afraid, although obviously you can insert all your own rendering within that begin/end frame.
-Chris
Return to “C/C++”
