mariusco
bluez-1.10 arm-linux-gnueabihf-g++" fails sanity check
Thu Nov 21, 2013 7:02 pm
Got the tool-chain from
sudo git clone git://github.com/raspberrypi/tools.git
and put it in $TCHAIN
I am trying to build bluez-5.10 from https://www.kernel.org/pub/linux/blueto ... .10.tar.xz
I am running ./configure as :
./configure --disable-systemd \
             --enable-library \
             --host=gcc-linaro-arm-linux-gnueabihf-raspbian \
             --libdir=$CC_TCHAIN/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/lib \
             --includedir=$CC_TCHAIN/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/include
The output is:
checking for gcc-linaro-arm-linux-gnueabihf-raspbian-gcc... /home/xxx/folder/cross-compiler/pi/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/bin/arm-linux-gnueabihf-gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... yes
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether /home/xxx/folder/cross-compiler/pi/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/bin/arm-linux-gnueabihf-gcc accepts -g... yes
checking for /home/xxx/folder/cross-compiler/pi/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/bin/arm-linux-gnueabihf-gcc option to accept ISO C89... none needed
checking dependency style of /home/xxx/folder/cross-compiler/pi/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/bin/arm-linux-gnueabihf-gcc... gcc3
checking how to run the C preprocessor... /home/xxx/folder/cross-compiler/pi/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/bin/arm-linux-gnueabihf-g++
configure: error: in `/home//external/bluez-5.10':
configure: error: C preprocessor "/home/xxx/folder/cross-compiler/pi/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian/bin/arm-linux-gnueabihf-g++" fails sanity check
Thank you
Return to “C/C++”
