jack01best
How to compile C++ on Raspberry Pi
Tue Nov 12, 2013 6:20 pm
I want to compile c++ program which includes "wiringPi.h" header file on Raspberry Pi, but I do not how to compile it correctly.
Could you please tell me how to compile it correctly?
Thank you very much
Sincerely
Re: How to compile C++ on Raspberry Pi
Tue Nov 12, 2013 6:23 pm
You need to use the gcc compiler, which is installed as standard. Or, if you already have project, there is probably a make file you need to use
So (briefly)
gcc <name of c program>
or
make
Tue Nov 12, 2013 6:45 pm
jamesh wrote:You need to use the gcc compiler, which is installed as standard. Or, if you already have project, there is probably a make file you need to use
So (briefly)
or
make
Re-read the question from the OP.
You can't compile a "wiringPi.h" file. You have to #include it into a xyzzy.c or foobar.cpp program.
So we need our OP to give a better description of what he's doing and what he's trying to achieve and why he's determined that "wiringPi.h" is the thing he needs to do it with.
jack01best
Tue Nov 12, 2013 7:46 pm
So (briefly)
or
make
Sorry, I means that I want to compile a c++ program which includes "wiringPi.h" header file, I don't know how to compile it.
aksommerville
Tue Nov 12, 2013 7:54 pm
What have you tried so far, and what happened?
Normally, it's just 'make' to compile C or C++ programs.
AndyD
Tue Nov 12, 2013 8:18 pm
I assume you have installed Wiring Pi using the instructions here.
The C++ compiler that most people use in Linux is g++.
You can follow Gordon's blink example here, just use g++ instead of gcc.
i.e.
gcc -Wall -o blink blink.c -lwiringPi
sudo ./blink
jack01best
Tue Nov 12, 2013 8:55 pm
aksommerville wrote:What have you tried so far, and what happened?
I want to compile C++ program but it is failure.
There are several errors as shown:
error: invalid suffix "HIGH" on floating constant
error: invalid suffix "LOW" on floating constant
I used the following command to compile:
g++ -std=c++0xBlink.cpp -oBlink -lwiringPi
jack01best
Tue Nov 12, 2013 8:57 pm
AndyD wrote:I assume you have installed Wiring Pi using the instructions here.
i.e.
sudo ./blink
So you means that I can use the following command to compile C++ program?
g++ -Wall -o blink blink.cpp -lwiringPi
AndyD
Tue Nov 12, 2013 9:40 pm
jack01best wrote: There are several errors as shown:
That is odd. I get ...
g++ -std=c++0x -Wall -o blink blink.cpp -lwiringPi
blink.cpp:2:7: warning: ISO C++ forbids declaration of ‘main’ with no type [-Wreturn-type]
Which is fair enough (main should be int main(void) in c++).
ganeshpadgalwar23
Thu Jul 12, 2018 10:48 am
I'm combinely using wiringPi Library and Rpi-rgb-led-matrix library in my .CC code
while doing this i'm getting below error ....if anyone know about this please reply...thank you ...in advance
example.cc -lwiringPi
/tmp/ccoNCX6j.o: In function `main':
text-example.cc:(.text+0x1fd0c): undefined reference to `rgb_matrix::GPIO::GPIO()'
text-example.cc:(.text+0x1fd1c): undefined reference to `rgb_matrix::GPIO::Init(int)'
text-example.cc:(.text+0x1fd7c): undefined reference to `rgb_matrix::RGBMatrix::RGBMatrix(rgb_matrix::GPIO*, int, int, int)'
collect2: error: ld returned 1 exit status
markkuk
Thu Jul 12, 2018 12:03 pm
If you are using multiple libraries then you must link your code with all of them.
g++ example.cc -o example -lwiringPi -lrgbmatrix
Return to “C/C++”
