UART RX TX problem
Posted: Thu Jul 11, 2013 6:48 pm
by eqooo
Hi everyone..
I have some question.
I'm using RPi rev2 and I generally write code with wiringPi library on C language.
So I write a simple serial code and checked.
Firstly I used P1 header RX and TX pins to communicate with Desktop.
When the code is working, I had some trouble on communication.
When I send a data from pc to Rpi, RPi didn't take the sending data. But when I send
quickly 30 times or 40 times send same data from pc to RPi, that's time he has began working.
and l tried another port sending and receiving data.
I used usb to communicate. And I used same code but only modify in code "/dev/ttyUSB0".
but that's time it is working very well. I could not understand why I can't receive a data from pc .
Has any idea about that???
Re: UART RX TX problem
Posted: Sun Jul 14, 2013 8:56 pm
by PiHeich
i have the same problem.. i need to read and write whit 1200baudrate...
i have this code:
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#include <stdarg.h>
#include <string.h>
#include <termios.h>
#include <unistd.h>
#include <fcntl.h>
#include <sys/ioctl.h>
#include <sys/types.h>
#include <sys/stat.h>
int main()
int fd, retval;
unsigned char lett;
//char apriporta[5]={0x00,0x3E,0x64,0xE7,0x89};
//char rispondi_chiudi[5]={0x00,0xCC,0x64,0xE7,0x17};
//char occhio[5]={0x00,0x4F,0x64,0xE7,0x9A};
// Configurazione seriale
fd = open("/dev/ttyAMA0", O_RDWR);
 if (fd < 0)
    printf ("Non posso aprire la porta seriale: /dev/ttyAMA0\n");
		struct termios options;
		tcgetattr(fd, &options);
		options.c_cflag |= CREAD; //abilito ricezione
		options.c_cflag |= CSIZE + CS8; //8 caratteri
		cfsetispeed(&options, B1200); //boudrate 1200
		//options.c_lflag &= ~(ICANON | ECHO | ISIG); // disabilito terminatore
		tcsetattr(fd, TCSANOW, &options);
		tcflush(fd, TCIOFLUSH);
  	while(1)
		retval = read(fd, &lett, 1);
		printf("\nho letto: %c",lett);
		//tcflush(fd, TCIOFLUSH);
  close(fd);
  printf ("\n") ;
  return 0 ;
}//fine main
I don't know why the raspberry have this lagg...
and when it work after 50-60-...-100 charater when i send A then A then B i read A A A B.... so i have a retard....
Posted: Tue Jul 16, 2013 9:05 am
by PiHeich
HELP :cry: :cry: :cry: :cry: :cry:
Posted: Sun Jul 21, 2013 8:14 am
by liudr
Post your code.
Posted: Mon Jul 22, 2013 12:54 pm
by PiHeich
liudr wrote:Post your code.
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#include <stdarg.h>
#include <string.h>
#include <unistd.h>
#include <fcntl.h>
int main()
int fd, n;
 if (fd < 0)
		cfsetispeed(&options, B2400); //boudrate 1200
  char buf[256];
 while(1)
  n = read(fd, (void*)buf, 255);
  if (n < 0) {
    printf("\nRead failed");
    return -1;
  } else if (n == 0) printf("\nNo data on port");
  else {
    buf[n] = '\0';
    printf("\n%i bytes read : %s", n, buf);
  close(fd);
  printf ("\n") ;
  return 0 ;
}//fine main
Posted: Mon Jul 22, 2013 1:01 pm
by joan
The following code works. You'll need to remove all the irrelevant code.
    #include <stdio.h>   /* Standard input/output definitions */
    #include <stdlib.h>  /* exit */
    #include <string.h>  /* String function definitions */
    #include <unistd.h>  /* UNIX standard function definitions */
    #include <fcntl.h>   /* File control definitions */
    #include <errno.h>   /* Error number definitions */
    #include <termios.h> /* POSIX terminal control definitions */
    #include <ctype.h>   /* isxxx() */
    cc -o 433 433.c
    Usage ./433 [option] ...
       -r, receiver (default)
       -t, transmitter
       -s BPS, bits per second, default 2400
          (300, 600, 1200, 1800, 2400, 4800, 9600, 19200)
       -m COUNT, test messages, default 1000
    ./433 -t -s4800 -m500 run as transmitter send 500 messages at 4800 bps
    ./433 -r -s4800       run as receiver (default), receive at 4800 bps
    #define PREAMBLE 0x21
    #define SYNC     0xAA
    int     rx       = 1;     /* defaults to receiver end */
    int     messages = 1000;  /* default send 1000 test messages */
    speed_t speed    = B2400; /* default to 2400 bps */
    struct termios orig;
    int filedesc;
    /* prototypes */
    int  openSerialPort (char * device, int bps);
    void tx_message     (int fd, int mlen, char * dat);
    int  rx_message     (int fd, char * dat);
    int  initOpts       (int argc, char *argv[]);
    void tidyup(void);
    int main(int argc, char *argv[])
       int i, c;
       char buf[512];
       initOpts(argc, argv);
       filedesc = openSerialPort("/dev/ttyAMA0", speed);
       if (filedesc == -1) exit(1);
       atexit(tidyup);
       if (rx)
          while(1)
             usleep(100);
             c = rx_message(filedesc, buf);
             if (c > 0)
                buf[c]=0;
                printf(buf);
       else
          for (i=1; i<=messages; i++)
             sprintf(buf, "message #%d\n", i);
             tx_message(filedesc, strlen(buf), buf);
             usleep(500); /* delay between messages */
    void tidyup(void)
       fflush(NULL); /* flush output */
       /* important to use TCSAFLUSH, otherwise buffered messages will be lost */
       tcsetattr(filedesc, TCSAFLUSH, &orig); /* restore original serial settings */
    int openSerialPort(char * device, int bps)
       int fd;
       struct termios new;
       char buf[128];
       fd = open(device, O_RDWR | O_NOCTTY | O_NDELAY | O_NONBLOCK);
       if (fd == -1)
          sprintf(buf, "openSerialPort %s error", device);
          perror(buf);
       else
          tcgetattr(fd, &orig); /* save current serial settings */
          tcgetattr(fd, &new);
          cfmakeraw(&new);
          fprintf(stderr, "speed=%d\n", bps);
          cfsetispeed(&new, bps);
          cfsetospeed(&new, bps);
          tcsetattr(fd, TCSANOW, &new); /* set new serial settings */
          fcntl (fd, F_SETFL, O_RDWR);
       return fd;
    int checksum(int len, char * dat)
       int cksm;
       int i;
       cksm = 0;
       for (i=0; i<len; i++)  cksm ^= dat[i];
       return cksm;
    void tx_message(int fd, int mlen, char * dat)
       char buf[300];
       char cksm;
       int wrote;
       buf[0] = SYNC; /* gives time for the receiving uart to sync */
       buf[1] = SYNC; /* gives time for the receiving uart to sync */
       buf[2] = PREAMBLE;
       buf[3] = mlen;
       memcpy(buf+4, dat, mlen);
       cksm = checksum(mlen+2, buf+2);
       buf[mlen+4] = cksm;
       wrote = write(fd, buf, mlen+5);
       if (wrote != (mlen+5)) printf("short write %d\n", wrote);
    void printBuf(char * buf, int bufLen)
       int i;
       for (i=0; i<bufLen; i++)
          if (isprint(buf[i])) printf("%c ", buf[i]);
          else                 printf("%02X ", buf[i]);
       printf("\n");
    int rx_message(int fd, char * dat)
       static int  posBuf=0;
       static char msgBuf[512];
       int i, scanning, mlen, validMessage;
       char cksm;
       char * ptr;
       validMessage = 0;
       i = read(fd, msgBuf+posBuf, sizeof(msgBuf)-posBuf);
       if (i>0)
          posBuf += i;
          scanning = 1;
          while (scanning)
             if (msgBuf[0] != PREAMBLE)
                /* find message start */
                ptr = memchr(msgBuf, PREAMBLE, posBuf);
                if (ptr != NULL)
                   /* preamble found, discard previous junk */
                   i = ptr - msgBuf;
                   posBuf -= i;
                   memmove(msgBuf, ptr, posBuf);
                else
                   /* no preamble found, discard junk */
                   posBuf = 0;
                   scanning = 0;
             if (posBuf > 2)
                /* we have enough to calculate size */
                mlen = msgBuf[1];
                if (posBuf > (mlen+2))
                   /* we have enough for a message */
                   cksm = checksum(mlen+2, msgBuf);
                   if (msgBuf[mlen+2] == cksm)
                      /* valid message received */
                      validMessage = 1;
                      /* copy message to callers buffer */
                      memmove(dat, msgBuf+2, mlen);
                      /* remove from receive buffer */
                      posBuf -= (mlen+3);
                      if (posBuf) memmove(msgBuf, msgBuf+mlen+3, posBuf);
                      scanning = 0;
                   else
                      /* corrupt message or invalid preamble.
                         Delete preamble and search for another
                      msgBuf[0] = 0;
                else scanning = 0;
             else scanning = 0;
       if (validMessage) return mlen; else return 0;
    int initOpts(int argc, char *argv[])
       int opt;
       while ((opt = getopt(argc, argv, "m:rs:t")) != -1)
          switch (opt)
             case 'm':
                opt = atoi(optarg);
                if (opt>0) messages = opt;
                break;
             case 'r':
                rx = 1;
                break;
             case 's':
                opt = atoi(optarg);
                if      (opt ==   300) speed =   B300;
                else if (opt ==   600) speed =   B600;
                else if (opt ==  1200) speed =  B1200;
                else if (opt ==  1800) speed =  B1800;
                else if (opt ==  2400) speed =  B2400;
                else if (opt ==  4800) speed =  B4800;
                else if (opt ==  9600) speed =  B9600;
                else if (opt == 19200) speed = B19200;
                break;
             case 't':
                rx = 0;
                break;
       return 0;
Posted: Tue Jul 23, 2013 11:44 am
by PiHeich
joan wrote:The following code works. You'll need to remove all the irrelevant code.
    cc -o 433 433.c
       -t, transmitter
    #define SYNC     0xAA
    int filedesc;
    /* prototypes */
    void tidyup(void);
       int i, c;
       char buf[512];
       atexit(tidyup);
       if (rx)
          while(1)
             usleep(100);
             if (c > 0)
                buf[c]=0;
                printf(buf);
       else
    void tidyup(void)
       int fd;
       struct termios new;
       char buf[128];
       if (fd == -1)
          perror(buf);
       else
          cfmakeraw(&new);
       return fd;
       int cksm;
       int i;
       cksm = 0;
       return cksm;
       char buf[300];
       char cksm;
       int wrote;
       buf[2] = PREAMBLE;
       buf[3] = mlen;
       buf[mlen+4] = cksm;
       int i;
       printf("\n");
       char cksm;
       char * ptr;
       validMessage = 0;
       if (i>0)
          posBuf += i;
          scanning = 1;
          while (scanning)
                if (ptr != NULL)
                   i = ptr - msgBuf;
                   posBuf -= i;
                else
                   posBuf = 0;
                   scanning = 0;
             if (posBuf > 2)
                mlen = msgBuf[1];
                      validMessage = 1;
                      posBuf -= (mlen+3);
                      scanning = 0;
                   else
                      msgBuf[0] = 0;
                else scanning = 0;
             else scanning = 0;
       int opt;
          switch (opt)
             case 'm':
                opt = atoi(optarg);
                break;
             case 'r':
                rx = 1;
                break;
             case 's':
                opt = atoi(optarg);
                break;
             case 't':
                rx = 0;
                break;
       return 0;
Same problem.
Posted: Tue Jul 23, 2013 12:02 pm
by joan
To me that would suggest a problem with the connections or with the Pi. Bad connections would seem more likely.
Posted: Fri Jul 26, 2013 2:50 pm
by PiHeich
