trackme21
First c program write in raspberry pi.
Mon Jul 08, 2013 9:13 pm
I'm trying to write my first c program in RPi.
Is there any compiler or editor in RPi?
If not how can i write c program in RPi with command prompt.
Also how can i compile and run it!
Thanks in advance.
mahjongg
Re: First c program write in raspberry pi.
Mon Jul 08, 2013 9:17 pm
any text editor would do, but there are specialized ones with "syntax highlighting"
command line compilers like GCC are often still the power beneath the playful GUI's, but are often faster to use without them.
One of the best known, and best, is still the GNU compiler GCC.
joan
Mon Jul 08, 2013 9:24 pm
Create a file called myprog.c
#include <stdio.h>
int main(int argc, char *argv[])
  if (argc > 1) printf("Your name is %s\n", argv[1]);
  else printf("Your name is not known\n");
Compile with
cc -o myprog myprog.c
Run with
$ ./myprog
$ ./myprog ken
Your name is ken
isaias
Fri Jul 12, 2013 2:48 am
Hey Mahjongg,
Can you suggest please some editor for the RPI to write that C programm so it can check the sintax or something like that ?
Regards
mahjongg
Fri Jul 12, 2013 10:13 am
I don't have a personal preference, but there are many editors that would work.
Nano, and Vim are the first two that come to mind, but I think JED / XJED is more or less standard.
I would suggest trying all of these to see which you like best.
The standard "wordpad" like editor of raspbian is leafpad, it would work but has no syntax highlighting.
isaias
Fri Jul 12, 2013 4:40 pm
Thanks a lot for your info.
I will try nano.
Isaias
kghunt
Fri Jul 12, 2013 9:22 pm
I am using adafruit a web ide as I do not have X installed on my pi.
Sat Jul 13, 2013 4:50 am
I use vi (nvi) on my Pi, or geany on my Debian x86 laptop for editing.
I would use geany on my Pi, but I don't use a desktop on there. Geany has some syntax highlighting and other features, but I mostly use it as a basic text editor.
JRV
Fri Aug 02, 2013 3:07 pm
I use gedit for writing code, and I use this simple GUI that I wrote:
#!/bin/sh
#Front end for GCC compiler.
# filename = C-GUI
WFLOADED=0
cd C
while [ $# -eq 0 ]
do
WORK=`cat WORKFILE.txt`
WORKC=$WORK".c"
WFLOADED=1
   CHOICE=`zenity --title="C-GPIO" --text="Work File:    "$WORK --height=400 --width=300 \
--list --column="Front End For GCC Compiler" "Create or Select Work FIle" "Edit    "$WORKC "Compile    "$WORKC "Execute    "$WORK "Terminal" "Exit"`
 #  clear
   if [ "$CHOICE" = "Create or Select Work FIle" ]; then
      clear
      TEMP=`zenity --entry --entry-text="Currently:  "$WORK --width=300`
      if [ $TEMP ]; then
         WORK=$TEMP
         WORKC=$WORK".c"
         WFLOADED=1
         echo $WORK > WORKFILE.txt
     fi
   fi
   if [ "$CHOICE" = "Edit    "$WORKC ]; then
      if [ $WFLOADED -gt 0 ]; then
         gedit $WORK".c"
      else
         zenity --info --text="Work file is empty, create or select a work file." --timeout=2
      fi
   fi
   if [ "$CHOICE" = "Compile    "$WORKC ]; then
         clear
         cc -o $WORK $WORK.c
      else
      fi
   fi
   if [ "$CHOICE" = "Execute    "$WORK ]; then
         clear
         echo " "
         sudo ./$WORK
         echo " "
         echo -n "Press <Enter> to continue: "
         read WORKHOLD
         clear
      else
      fi
   fi
   if [ "$CHOICE" = "Terminal" ]; then
      clear
      lxterminal
   fi
   if [ "$CHOICE" = "Exit" ]; then
      clear
      exit 0
   fi
done
Copy into a directory named "C", name it "C-GUI".
Make it executable with the command:
chmod +x C-GUI
Create an empty file named "WORKFILE.txt"
The working file name is entered without the ".c" extension.
If you want to use gedit you will need to install it,
or you can change all instances of gedit to leafpad.
This script uses zenity to display the GUI.
I don't remember if zenity is installed by default or if I installed it.
To run open a terminal and type:
C/C-GUI
Select "Create or Select Work File" and enter the filename (without the ".c")
s_erno
Tue Aug 06, 2013 1:50 pm
Not sure how relevant this is now, but geany is really worth a try. Has coloring and such included, and I think it can even compile some stuff if configured right.
AndyInSurrey
Thu Aug 08, 2013 2:56 pm
I like working in the terminal on the RasPi and use nano as my text editor to write c and c++ programs. However, if you are a beginner you would be best advised to use an IDE to help, Geany is a good one on the RasPi, but would strongly advise that you install the debugger plugin for it, which will greatly assist you in understanding why your code isn't working the way you intend.
funk247
Thu Aug 08, 2013 11:54 pm
You might wanna give code::blocks a try as well, its available from the Pi store and is pretty simple to use. Its got the sntax highlighting and limited code completion.
I've been using it quite a lot as it makes organizing things very easy and offers a relatively familiar GUI.
ejames
Wed Aug 14, 2013 2:55 pm
vi or emacs are good choices
and learn to use makefiles asap
http://www.cprogramming.com/tutorial/makefiles.html
Manvir
C programming in Raspbarry Pi
Thu May 15, 2014 3:02 pm
I have started working on RPi two days ago. I have seen some tutorials to program RPi using Python but I do not have any experience in Python. I am very good at C. I do not have time to learn Python because I want to finish my project as soon as possible. I want to read the sensors using I2C. I have a 4 channel board to connect the sensors with the board.
Is it possible to read the sensors using C language only? Please help me if somebody has experience to read the GPIO of RPi using C.
Thanks. Waiting for you valuable comments.
Fri May 16, 2014 6:33 am
What sensor and how is it interfaced?
http://wiringpi.com/ & http://abyz.co.uk/rpi/pigpio/ both have good libraries for I2C and SPI.
I've also used https://github.com/quick2wire/quick2wire-python-api because that works with my Q2W boards.
This is a doctor free zone.
Manvir
Fri May 16, 2014 10:08 am
Hello
Thanks for the reply.
I am using angle encoder, a pressure sensor, a voltage sensor and a current sensor. Because RPi hasnt enough GPIO to interface all these sensors, I have ordered one A/D board 4 channel. I can connect all the 4 sensors to this board and read them via I2C.
Thanks. Waiting for your reply.
Fri May 16, 2014 10:14 am
Reading I2C with Gordon's WiringPi library is trivial. The only requirement with WiringPi is that the program runs UID(0), so you have to run it with sudo.
R61zt
Sat May 17, 2014 3:04 pm
You were asking which text editor to use so I'll write out every step which works from the prompt on a default raspian wheezy installation and also works in a terminal after startx has been called.
cd <yournewdirectory>
where <example> brackets indicate something which you must change to what you are using.
nano helloworld.c
opens a blank helloworld.c in one of the text editors
type in some c code to do something, preferably not printf-ing any rude words.
CTRL-O to save
CTRL-X to exit
that will return you to the prompt, where you may type
gcc -o helloworld hellowold.c
ls -l
to list what is there with details.
chmod +x helloworld
if ls-l did not find an "x" for "executable" against helloworld
note that executables might sometimes be coloured green to make them more noticeable from ls.
to run an executable named helloworld
./helloworld
what happens next will be whatever was asked for correctly in your program.
PeterRovman
Fri Sep 15, 2017 4:33 pm
There is something missing (for me):
I wrote the program (using Geany) suggested by Joan but don't know where to save it. When I try the compile it says there is no such directory or file, no matter where I put it or how I specify the directory.
A lot of this post does not look like C that I have used. for example what does -o do, where do I find what $ ./ means ?
Fri Sep 15, 2017 4:41 pm
~ means home directory./means here, current directory
B.Goode
Fri Sep 15, 2017 5:03 pm
what does -o do
From man cc
-o file
Place output in file file. This applies regardless to whatever sort of output is being produced, whether it be an executable file, an object file, an assembler file or preprocessed C code.
If -o is not specified, the default is to put an executable file in a.out, the object file for source.suffix in source.o, its assembler file in source.s, a precompiled header file in source.suffix.gch, and all preprocessed C source on standard output.
PeterRovman
Fri Sep 15, 2017 5:36 pm
Thanks but it does not answer my question.
I assume I open the terminal under Accessories then type
cc -o cprog myprog.c
where is the Pi expecting to find the directory cprog? Should I have saved it in Home or Home\Pi or somewhere else?
No place seems to work. Where is the "command line"? Does this mean the Terminal?
What does -o mean? or is that a zero?
I also assume that cc invokes a C compiler but which one? Is there even one loaded?
I read the guide and RPi Basics but need some other reference to cover these basic steps.
The last post helps with the -o thanks.
Is this stuff I don't understand a Linux thing? It is totally strange to me.
Fri Sep 15, 2017 5:43 pm
It isn't expecting to find a directory called cprog. It is going to write a file called cprog in the current directory. That will be your executable program.
Yes, the "terminal" is where you type commands on a command line.
It is a lower case "O", meaning "output file".
cc is a usually a link to the gcc compiler.
jahboater
Fri Sep 15, 2017 5:49 pm
What directory cprog? "cprog" is a file. In fact it is your new program, and it can go anywhere you like. For a simple hello world program, it might as well go in the current directory and you can run it with ./cprog
Please re-read carefully the previous post by B.Goode.
It will invoke GCC which comes already installed on Raspbian. It is a very good compiler and you can just use it straight away.
You can read most beginner books on C which should help.
Its basic command line stuff. Similar in fact to Windows or IOS at this level. So (at this level) its not a "Linux thing".
PeterRovman
Fri Sep 15, 2017 6:01 pm
Thanks rpdom and jahboater. very helpful
It is all strange to me coming from MS Win, CCS "C", and MPLAB programming PICs.
Where do I look up command line instructions? A book on C? I don't remember seeing or using this in my C programming.
Edit:
Thanks everyone; I now have my first C program running on my RPi.
Here are Joan’s instructions with my comments added for real novices like me. I changed the file and folder names to prevent the confusion I had.
Click top left of the monitor (or bottom right depending on the version), move the cursor over Programming and click on Geany. This opens an editor. Type the following program into this editor:
#include <stdio.h>
Select File, save as, create folder (top right) named cprogs and save the file as myprog.c. Close Geany. This is your source code which you need to compile into an executable program.
Click top left of the monitor, move the cursor over Accessories and select Terminal.
At the $ prompt type
CD cprogs (enter) // to get into the cprogs folder
cc –o newprog myprog.c // to compile the program as file named newprog. See previous post for details.
Now, still at the $ prompt, run your program. Type
./newprog (enter) // no spaces.
Then with your name
./newprog Fred
Return to “C/C++”
