Dreeass
GPIO Read Infrared Input
Fri May 10, 2013 2:59 pm
So I got my Infrared receiver connected to GPIO pin 18 and would like to know how I decode the signals I'm getting. I am a noob C developer and would like to know whether this is possible.
Increase attachment and avatar size limit or use a third party system?
joan
Re: GPIO Read Infrared Input
Fri May 10, 2013 3:17 pm
There are quite a few different standards. Have a look at http://www.vecoven.com/elec/ir/ir.html
You'll need to be able to time pulses down to about 50 microseconds.
Dreeass
Fri May 10, 2013 3:24 pm
joan wrote:There are quite a few different standards. Have a look at http://www.vecoven.com/elec/ir/ir.html
I'm a beginner with C and don't understand it actually. Adafruit's tutorial explains this with an Arduino, how can I do the same with a RPi?
0xFF
Fri May 10, 2013 3:32 pm
Dreeass wrote:So I got my Infrared receiver connected to GPIO pin 18 and would like to know how I decode the signals I'm getting. I am a noob C developer and would like to know whether this is possible.
Stop LIRC daemon:
 /etc/init.d/lirc stop
Enter mode2 command, then push some buttons on remote.
If receiver works, you will see output - something like that:
space 10226593
pulse 2708
space 830
pulse 511
space 814
pulse 510
Dreeass
Fri May 10, 2013 3:37 pm
Stop LIRC daemon:
space 10226593
pulse 2708
space 830
pulse 511
space 814
pulse 510
I have tried LIRC and get the following error when entering mode2:
mode2: could not get file information for /dev/lirc
mode2: default_init(): no such file or directory
0xFF
Sat May 11, 2013 8:43 am
You have to load LIRC modules:
modprobe lirc_rpi
modprobe lirc_dev
Dreeass
Sat May 11, 2013 10:46 am
0xFF wrote:You have to load LIRC modules:
modprobe lirc_rpi
modprobe lirc_dev
Doesn't change anything.
mtnbikerjoshua
Sat Feb 03, 2018 5:54 am
I also had the error that read:
The solution in this forum worked for me: https://www.reddit.com/r/raspberry_pi/c ... ning_lirc/
Return to “C/C++”
