msmithy12
GTK segmentation error
Wed May 01, 2013 9:03 am
Ok so i have a large program that works and i then decided to add a few lines of code that would save my variables as a text file in memory.
This routine cause a segmentation error (139) I removed the code to make a the text file and replaced it with printf("save"). Still i had the segmentation error, so i removed all the code except the window the toolbar and the save button and i still get the segmentation error. Im sure i have made a simple error somewhere but i cant see it for looking. I would be grateful to anyone that can scan the code and hopefully spot my error?
 * segmentation error issue.c
#include <gtk/gtk.h>
#include <stdio.h>
void kill_window(GtkWidget *widget, gpointer data) //kill_window event
	gtk_main_quit(); //exit program
void shutdown(GtkWidget *widget, gpointer data)
	printf("shutdown\n#");
void save(GtkWidget *widget, gpointer data)
	printf("save\n");
int main(int argc, char *argv[])
	GtkWidget *window;		//creates a window
	GtkWidget *hbox;		//creates horizontal box
	GtkWidget *hbox1;
	GtkWidget *hbox2;		//creates a second horizontal box
	GtkWidget *vbox;
	GtkWidget *toolbar;
	GtkToolItem *save;
	GtkToolItem	*sep;
	GtkToolItem *exit;
	GtkToolItem *close;
	gtk_init(&argc, &argv);	//argc ARGUMENTcount argv ARGUMENTvalue
//Main Window ###########################################################
	window = gtk_window_new(GTK_WINDOW_TOPLEVEL);	//declares a main window at top level
	gtk_window_set_position(GTK_WINDOW (window), GTK_WIN_POS_CENTER);
	gtk_window_set_title(GTK_WINDOW (window), "Test");	//sets main window title
	gtk_window_set_resizable (GTK_WINDOW (window), FALSE);
	gtk_window_set_keep_above (GTK_WINDOW (window), TRUE);
	gtk_container_set_border_width	(GTK_CONTAINER (window),2);
//ToolBar###############################################################
	toolbar = gtk_toolbar_new();
	gtk_toolbar_set_style(GTK_TOOLBAR(toolbar),GTK_TOOLBAR_ICONS);
	gtk_container_set_border_width (GTK_CONTAINER (toolbar),2);
	save = gtk_tool_button_new_from_stock(GTK_STOCK_SAVE);
	gtk_toolbar_insert(GTK_TOOLBAR(toolbar), save, 0);
	sep = gtk_separator_tool_item_new();
	gtk_toolbar_insert(GTK_TOOLBAR(toolbar), sep, 0);
	close = gtk_tool_button_new_from_stock(GTK_STOCK_CLOSE);
	gtk_toolbar_insert(GTK_TOOLBAR(toolbar), close, 0);
	exit = gtk_tool_button_new_from_stock(GTK_STOCK_QUIT);
	gtk_toolbar_insert(GTK_TOOLBAR(toolbar), exit, 0);
//boxes ##############################################################
	hbox  = gtk_box_new(TRUE, 4);	//hbox is of type gtk_box_new (TRUE=horizontal)
	hbox1 = gtk_box_new(TRUE,4);	//hbox1 is of type gtk_box_new (TRUE=horizontal)
	hbox2 = gtk_box_new(TRUE,4);	//hbox2 is of type gtk_box_new (TRUE=horizontal)
	vbox  = gtk_box_new(FALSE,2);
//connect window signals to routines #################################
	g_signal_connect(G_OBJECT(window), "destroy", G_CALLBACK(kill_window), NULL);
	g_signal_connect(G_OBJECT(close), "clicked", G_CALLBACK(kill_window), NULL);
	g_signal_connect(G_OBJECT(exit), "clicked", G_CALLBACK(shutdown), NULL);
	g_signal_connect(G_OBJECT(save), "clicked", G_CALLBACK(save), NULL);
//GTK PACKING OPTIONS  ###################################################
	gtk_box_pack_start(GTK_BOX(hbox)	,vbox,		TRUE, TRUE, 2);
	gtk_box_pack_start(GTK_BOX(vbox)	,hbox1,		TRUE, TRUE, 2);
	gtk_box_pack_start(GTK_BOX(vbox)	,hbox2,		TRUE, TRUE, 2);
	gtk_box_pack_start(GTK_BOX(hbox)	,toolbar, 	TRUE, TRUE, 2);
	gtk_container_add(GTK_CONTAINER(window), hbox);
	gtk_widget_show_all(window);
	gtk_main();
	return 0;
Thanks Msmithy12
I assume I know what I`m talking about... I probably don`t
Home: 256mb Made in UK, Rasbmc, 40" Sony Bravia KDL-40v3000
Work: 2b+, Rasbian, 6" Lilliput touchscreen
raspem
Re: GTK segmentation error
Wed May 01, 2013 10:00 am
Compile it for debugging (-g) and run it in the debugger (gdb). It should point you to exactly where the problem is.
My other computer is a MacBook Pro
msmithy12
Wed May 01, 2013 10:05 am
program received signal SIGSEGV, segmentation fault.
0x0007e0d0 in ?? ()
i assume that means my error is in 0x0007e0d0
should i understand that?
PeterO
Wed May 01, 2013 10:58 am
You have two things called "save"...
A global function:
printf("save\n");
A local in the main function:
GtkToolItem *save;
This going to pass the toolitem as the callback address :
Solution is to rename the function to something like "savehandler" and change the g_signal_connect call parameters to
g_signal_connect(G_OBJECT(save), "clicked", G_CALLBACK(savehandler), NULL);
I built the modified code on a Fedora box with
gcc -g -o gtktest gtktest.c $(pkg-config --cflags --libs gtk+-3.0)
and it now works as expected.
PeterO
msmithy12
Wed May 01, 2013 12:50 pm
PeterO thank you,
I cant believe i missed that!
msmithy12
Return to “C/C++”
