lllypyn
SPI
Sat Mar 02, 2013 7:37 pm
Sorry for my english.
I need a library for the work with SPI.
lllypyn
Re: SPI
Sun Mar 03, 2013 11:05 am
big thanks
[email protected]
Re: SPI
Sun Mar 03, 2013 6:52 pm
What sort of SPI device are you interfacing to?
-Gordon
Gordons projects: https://projects.drogon.net/
lllypyn
Re: SPI
Mon Mar 11, 2013 4:42 pm
I want to use LED Display on MAX7219 + PI. Сan I use this library?
[email protected]
Re: SPI
Mon Mar 11, 2013 7:31 pm
lllypyn wrote:I want to use LED Display on MAX7219 + PI. Сan I use this library?
Sure. Looks an easy chip to interface to too. You send it 16-bit data blocks (ie 2 bytes) the bottom 8-bits is data, the bottom 4 bits of the next byte is the command byte. Simples. You send both bytes in a single transaction using write(2) or wiringPiSPIDataRW ()
-Gordon
lllypyn
Re: SPI
Mon Mar 18, 2013 4:14 pm
Sorry I don't understand. How send the 8 bits to MAX7219? What command should I send?
Return to “C/C++”
