[email protected]
Re: Qt with Wiring PI
Thu Sep 08, 2016 5:16 pm
DougieLawson wrote:
[email protected] wrote:
gauravsharma0190 wrote: in this code my gui window pop up and i am able to press the button but only 1 time only .
if i again press button ,My gui close and a message pop up says
you must only call this once per programe run.this is fatal error.
Yes, it is a fatal error to call wiringPiSetup() more than once in a program. You need to move the setup call to outside your main loop.
The reason is that I'm fed-up with people emailing me telling me wiringPi is broken when they repeatedly call the setup code in a loop and their program subsequently runs out of file handles some time later...
-Gordon
Surely it's not beyond the realms of sensibility to set a flag when wiringPiSetup() is run that you test before doing any initialisation. Second call to wiringPiSetup() effectively becomes a NOP (with a branch to function exit, as the job's already done).
Sure (and I have done that in the next version I'll release after another round of bleating) It's still a fault on the users part though.
-Gordon
Gordons projects: https://projects.drogon.net/
CristianJuretich
Tue Feb 20, 2018 8:27 pm
bgreat wrote:
Sat Feb 16, 2013 2:23 am
You are confusing the library and include sections in the .pro file.
In your .pro:
# So wiringPi include files can be found during compile
INCLUDEPATH    += /usr/local/include
# To link the wiringPi library when making the executable
LIBS += -L/usr/local/lib -lwiringPi
Enjoy!
Bill
Hi everybody,
my problem was How to make to WiringPi "works" in my project, and it (the above answer) is "the solution" for me.
Return to “C/C++”
