cyberieur
[C#] Problem with System.Speech
Sat Feb 09, 2013 11:40 pm
Hello
When I run my program of speech recognition in C #, I get this error:
Unhandled Exception: System.DllNotFoundException: ole32.dll
  at (wrapper managed-to-native) System.__ComObject:CoCreateInstance (System.Guid,intptr,uint,System.Guid,intptr&)
  at System.__ComObject.Initialize (System.Type t) [0x00000] in <filename unknown>:0
  at (wrapper remoting-invoke-with-check) System.__ComObject:Initialize (System.Type)
  at Mono.Interop.ComInteropProxy.CreateProxy (System.Type t) [0x00000] in <filename unknown>:0
  at System.Runtime.Remoting.RemotingServices.CreateClientProxyForComInterop (System.Type type) [0x00000] in <filename unknown>:0
  at System.Runtime.Remoting.Activation.ActivationServices.CreateProxyForType (System.Type type) [0x00000] in <filename unknown>:0
  at System.Speech.Internal.SapiInterop.SapiRecognizer..ctor (RecognizerType type) [0x00000] in <filename unknown>:0
  at System.Speech.Recognition.SpeechRecognitionEngine.Initialize (System.Speech.Recognition.RecognizerInfo recognizerInfo) [0x00000] in <filename unknown>:0
  at System.Speech.Recognition.SpeechRecognitionEngine..ctor () [0x00000] in <filename unknown>:0
  at speechreco.Program.Main (System.String[] args) [0x00000] in <filename unknown>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.DllNotFoundException: ole32.dll
To start my program I first download System.Speech.dll otherwise I had this error:
Program.cs(5,14): error CS0234: The type or namespace name `Speech' does not exist in the namespace `System'. Are you missing an assembly reference?
Then I made this command to compile:
mcs Program.cs -r:System.Speech.dll
And to launch I did this command:
mono Program.exe
How to fix the error?
I was handling it good to start my program?
Where does the error?
sorry for my bad english
Thank you in advance.
bfagioli
Re: [C#] Problem with System.Speech
Sun Feb 10, 2013 4:57 am
First of all which Pi distro are you using. If you are using Raspbian “wheezy” there are many know issues with mono and this distro. Many of us are waiting for an updated version of mono that better supports this hard-float distro. Although I don't use it, I have been told the Soft-float Debian “wheezy” supports mono much better so you might want to try that if you have an extra SD card.
However, the error you are seeing looks like the Speech assembly want to CoCreate a COM object. I'm not sure if COM objects are even supported on non-Microsoft systems so this may never work. I think there is a mono tool you can run to determine if your program is "compatible" with mono. Can't remember it right now.
Unhandled Exception: System.DllNotFoundException: ole32.dll at (wrapper managed-to-native) System.__ComObject:CoCreateInstance
Looks like
stever29
Wed Feb 27, 2013 7:01 pm
From what you've said, it sounds like you've downloaded the windows implementation of the System.Speech assembly.. you need the mono one for any chance in getting this to work.
Nevertheless, have you had any luck with this since you posted? I'm keen to do the same thing, but its unclear to me which version (if any) of mono has this implemented
Return to “C/C++”
